Отговори на тема  [ 23 мнения ]  Отиди на страница Предишна  1, 2
къде е термистора на платката,или е в проца
Мнение Re: къде е термистора на платката,или е в проца
СПРИ СЕ БЕ, ЧОВЕК!
Пон Фев 27, 2017 11:22 am
am stereo Това ли ти е блока: https://www.google.bg/maps/place/43%C2% ... 3806?hl=en
Пон Фев 27, 2017 12:28 pm
СПРИ СЕ БЕ, ЧОВЕК!
..пошел в разнос ... за подлите русофили като мен, вече дали трябва да е пошел или ушел ...
Пон Фев 27, 2017 3:09 pm
ike написа:
абе където щеш 8) но не мога да намеря пълния ексиф виевър :arrow: http://www.exifdata.com/ :arrow: и най-вече https://www.thexifer.net/#geo-tags :roll:
2017-02-27_235421.JPG [ 462.21 KiB | Прегледано 3104 пъти ]
Вто Фев 28, 2017 12:59 am
ТОВА Е по-яко
had to import my videos from my HDR-GW55VE with the Play Memories Home Software, I simply copied the CLIPINF and STREAM folders (including all the .CPI and .MTS files contained within these folders) from the SD card to my HDD. However, as I only discovered now, I did a mistake by not copying the PLAYLIST folder, and the INDEX.BDM and MOVIEOBJ.BDM files.
When I learnt that I had to import the videos via PMH in order to have all the management information included, I recreated the AVCHD folder structure according to what I read in the forums and did the following:
- put files on an SD card
- insert SD card in camera
- let camera repair the file structure (by placing the file I had copied to a newly created AVCHD_BK folder)
- insert SD card in computer
- start import from SD card with PMH.
PMH recognised my SD card and imported the videos but I got the message “Import videos without management information”.
Once videos were imported via PMH, I noticed that:
- file extensions are changed from .MTS to .M2TS (which is normal)
- files have not been renamed with date/time information, e.g. files are named XXXXX.M2TS instead of YYYYMMDDHHMM.M2TS
- PMH does not see any GPS data (I find this strange since the GPS data is included in the Exif information of the .MTS files)
I know that I can manually set the GPS data in [map view], but since I have some 200 files, this would be quite cumbersome.
Is there any way to recreate the missing .BDM and .MPL files so that files are imported with the proper GPS data? What else could I do in order to have PMH recognise the GPS data?
For illustration, I copy below the Exif information of a sample file.
Any help would be much appreciated.
Cheers,
Teekai
ExifTool Version Number : 9.78
File Name : 00031.MTS
Directory : I:/PRIVATE/AVCHD_BK/BDMV/STREAM
File Size : 39 MB
File Modification Date/Time : 2014:07:14 09:27:58+01:00
File Access Date/Time : 2014:12:28 00:00:00+01:00
File Creation Date/Time : 2014:12:27 19:40:42+01:00
File Permissions : rw-rw-rw-
File Type : M2TS
MIME Type : video/m2ts
Video Stream Type : H.264 Video
Audio Stream Type : A52/AC-3 Audio
Audio Bitrate : 256 kbps
Surround Mode : Not indicated
Audio Channels : 2
Image Width : 1440
Image Height : 1080
Date/Time Original : 2014:07:14 10:27:28+01:00
Aperture Setting : Auto
Gain : 0 dB
Exposure Program : Program AE
White Balance : Auto
Focus : Auto (3.15)
Image Stabilization : On (0x3f)
Exposure Time : 1/1004
F Number : 3.4
GPS Version ID : 2.2.0.0
GPS Latitude Ref : North
GPS Longitude Ref : East
GPS Altitude Ref : Above Sea Level
GPS Time Stamp : 09:27:30
GPS Status : Measurement Active
GPS Measure Mode : 3-Dimensional Measurement
GPS Dilution Of Precision : 1.46
GPS Speed Ref : km/h
GPS Speed : 0.468
GPS Track Ref : True North
GPS Track : 55.9
GPS Map Datum : WGS-84
Make : Sony
Camera Model Name : HDR-GW55VE
Audio Sample Rate : 48000
Duration : 0:00:30
Aperture : 3.4
GPS Altitude : 1918.9 m Above Sea Level
GPS Latitude : 47 deg 2' 22.78" N
GPS Longitude : 10 deg 34' 1.18" E
GPS Position : 47 deg 2' 22.78" N, 10 deg 34' 1.18" E
Image Size : 1440x1080
Shutter Speed : 1/1004
Вто Фев 28, 2017 10:33 am
Вто Фев 28, 2017 1:44 pm
Преди 20-на години един приятел почти беше успял да го свали целия интернет на CD-та :D
Вто Фев 28, 2017 2:26 pm
просто търсех това цялостно описание на ексифа :arrow: http://www.picmeta.com/metadata/makernote-tags.htm
Сря Мар 01, 2017 6:25 am
