Semiconductor downturn 2008/2009
Мнение Semiconductor downturn 2008/2009
Отварям темата като продължение на тази за Nortel.
Цитатите са от eetimes.com
Layoffs at TI?
TI will finalize an early retirement later this month for 50 year-plus employees. This will result in a 5 percent staff cut.
Then, it will announce a layoff during the quarterly earnings report, which will result in a 20 percent staff cut.
Combined, the layoff should reduce TI's headcount by about 25 percent. Wow!
Ericsson posts results, cuts 5,000 jobs
Ericsson said it was stepping up its cost-savings efforts and cutting 5,000 jobs, aiming to reach annual savings of 10 billion crowns by the second half of 2010.
Intel to close plants, cuts up to 6,000 jobs
The other shoe has dropped at Intel Corp., as the chip giant will close two fabs and three IC-assembly factories.
The actions at what comes to four sites, when combined with associated support functions, are expected to affect between 5,000-to-6,000 employees worldwide.
AMD
Recently Advanced Micro Devices Inc. said it plans to cut an additional 900 jobs during the first quarter of 2009 as part of a series of moves designed to reduce the chip maker's workforce by about 9 percent.
AMD (Sunnyvale, Calif.) will shed another 200 jobs through a combination of attrition and the previously announced divestiture of its handheld business, the company said.
AMD had two major rounds of layoffs in 2008. Late last year, AMD reduced its workforce by about 600 employees. Last July, it announced the layoff of 10 percent of its workers.
Чет Яну 22, 2009 5:52 pm
на тези гъзари от ериксон да не им излиза 1 job = 200 000 eur?
Чет Яну 22, 2009 6:03 pm
Очевидно нямат намерение само да освобождават кадри, но и да затварят подразделения.
Едно развойно отделение от стотина човека в Европа съвсем спокойно излиза на фирмата около 8 000 000 евро годишно.
В тази сума влизат не само заплати, но и наеми на сгради, оборудване, консумативи и т.н.
Само за софтуерни лицензи сумата е 7 цифрена.
Чет Яну 22, 2009 6:25 pm
Мен сумата от 8 млн за 100 човека в западна европа ми се струва малко, особенно за развойна дейност, така че.....
Чет Яну 22, 2009 7:16 pm
малка е разбира се...
виж, за индия може да е добре. и без никакви лиценции за софтуер.
понастоящем масово хардуера е китайски с индийски софтуер писан от пакистанци-емигранти.
какво ли бъдеще ни чака (като потребители)?
Чет Яну 22, 2009 7:41 pm
Мисля, че няма да мине много време и "китайски хардуер" и "индийски софтуер"
няма да са нарицателни за "бананови продукти", поне не повече от западната продукция.
А може и да е дошъл този момент.
През изминалите месеци имах удоволствието да работя в екип с колеги от Китайската народна република
и не бих казал, че работата им се различава от европейската, виж манталитетът им е друга тема :)
Живот и здраве се надявам в близко бъдеще да поживея и поработя на тяхна почва.
А осемте милиона са приблизителна цифра за 60 човека екип на източно-германска територия с high-end софтуер и измервателна екипировка :wink:
Пет Яну 23, 2009 1:11 am
аз сметнах че ако аз трябва да организирам 100 човека в софия цифрата ще е 4 милиона евро годишно затова 8 милиона в германия наистина изглежда ниска, за китайския хардуер и особено софтуер може много да си говорим, не че не могат да правят но нямат опит а се впускат и в най-сложните начинания без никаква подготовка и без да им пука после всичко се прави на крак
ако попиташ китаец може ли да направи една совалка ще отговори без да се замисля - разбира се после за един месец ще я сглоби, друг е въпроса дали совалката ще излети, над това едва ли много се е замислял докато я прави
Пет Яну 23, 2009 10:44 am
HCL написа:
за съжаление е вярно.
но не защото много са напреднали азиатците, а защото "западното" ниво падна твърде много.
и май вместо ние да станем като тях - те станаха като нас.
HCL написа:
интересно, ще споделиш ли мотивацията си (освен че си млад и си настроен авантюристично :wink:)
3aek написа:
... ако аз трябва да организирам 100 човека в софия ...
няма да събереш и 30. а ако трябва и да са можещи, 5-10 е горната граница
Пет Яну 23, 2009 11:13 am
The negotiations to save struggling memory chip maker Qimonda apparently have got stuck.
Qimonda's insolvency does not come as a surprise to the industry. Neither should one think the company will remain
the only victim of the ongoing shake-out in the DRAM market. The reasons are as complex as the consequences.
While in normal markets competition is the regulating factor, with price, quality and technical innovation as its parameters,
this is not the case when governments step in. They did so to an extend that analyst Penn was motivated to use a strong comparison.
"This is the economical equivalent of World War III", he said.
NXP and Infineon next ?
Пет Яну 23, 2009 6:57 pm
Ами тук какво става ... спрени проекти на големи фирми....
еми какво се чува за А1 и Глобул.
Работата ми е свързана много тясно с развитието на телекомуникацийте и въвеждане на най-новите технологий,
сега всичко е в застой, направо е неподвижно. Чакаме рестарт на проектите... иначе лошо.
Пет Яну 23, 2009 7:06 pm
Става дърво, голямо и дебело, скоро ще има специлисти .... Дедо, то и в германия не е лесно да събереш 100 специалиста, наистна специалисти, и там работи не малко пълнеж, мениджмънта решава проблема с липсата на гении, а и това е по добрия вариант като цяло. Киров и Син съкратиха 75%, далеч еот нашите занимания но е показателно, а и не са единствените, те може би ще са първата по гляма жертва на кризата в строителството, да се готвят циментовите заводи, и вносителите на строителни материали.
HCL относно манталитета, точно това им е проблема, както и на нас, лично за мен манталитета е много по решаващ от знанията и потенциалните възможности, когато си си циганин по душа, и работата ти е циганска ....
Пет Яну 23, 2009 7:43 pm
RM написа:
.... телекомуникацийте и въвеждане на най-новите технологий....
абе еййй,
досира ми се, като видя такова безобразно използване на "Й"
телекомуникацийте -> телекомуникациите
технологий->технологии
откъде реши, че за множественото число трябва да слагаш Й :?:
не че аз много спазвам правилата на правописа ама това си е безобразие :!:
Пет Яну 23, 2009 8:21 pm
Да цитирам една светла мисъл на една светла личност - "С какъвто се събереш ..... все свиня ставаш".
Пет Яну 23, 2009 9:09 pm
Голямото падане продължава.
IBM cuts jobs as workers reach boiling point
As reported, IBM last week cut some 2,800 workers from its software, sales and distribution units.
Then, on Tuesday (Jan. 25), IBM slashed 1,200 more jobs within its Systems and Technology Group worldwide. That group includes its system and chip units.
Freescale posts $4B loss in Q4, $8B loss in '08
Freescale Semiconductor Inc. continues to spill red ink. It lost nearly $8 billion in 2008, but real question is clear: How long can this go on?
Toshiba delays fabs, cuts capex and jobs
Hit hard by the IC downturn, Japan's Toshiba Corp. outlined several cost-cutting moves, including plans to delay two NAND flash fabs. The company also reduced its capital spending and will cut 4,500 temporary workers
Sony sinks to Q3 loss
Sony Corp. fell into the red in the latest quarter and reiterated its forecast for a record annual loss due to sliding demand and a stronger yen.
ST to cut 4,500 jobs amid weak results
Amid a loss and a poor outlook, STMicroelectronics Inc. outlined a major cost-cutting effort in 2009, including a plan to shed 4,500 jobs.
Нещата се ускориха. Допреди месец си мислeх, че положението ще се стабилизира чак в средата на 2010.
Сега съм на мнение, че още Q3 тази година ще има проблясъци. Сякаш индустрията се сгромолясва под
някакво бреме от което така или иначе трябваше да се освободи.
Тези пари не изчезват в черна дупка в крайна сметка. Има ли бъдеще електрониката? Аз мисля, че да.
Kакво е вашето мнение по въпроса?
Пет Яну 30, 2009 2:20 am
Абе то ако няма бъдеще електрониката, няма бъдеще въобще. Нали не мислиш, че ще се връщаме пак към дървеното сметало. Така, че не се мъчи да мислиш варианти :)
Твова което е сигурно, е че ще има голямо преразпределение на пазара. Някой фирми ще изчезнат съвсем, други ще пострадат сериозно. Трети сигурно ще експанзират...
Пет Яну 30, 2009 11:42 am
Потребители разглеждащи този форум: Google [Bot] и 22 госта
