CCS priority бъпрос4е
Местоположение: Стара Загора
Мнение CCS priority бъпрос4е
>>> Warning 224 "C:\PROGRA~1\PICC\drivers\pic18_usb.h" Line 928(1,1): Interrupt level changed USB: NORMAL=>HIGH
>>> Warning 224 "D:\Projects\mplab_prj\usb\ex_usb_serial.c" Line 144(1,1): Interrupt level changed EXT: NORMAL=>HIGH
Има ли начин да го накарам да не ги прави тези простотии CCS-а ? Версията е 4.013. Благодаря!
Вто Ное 28, 2006 5:22 pm
E, нито един от ексертите по CCS ли няма да се обади? :cry: Не искам компилатора сам да ми определя кое прекъсване на какъв приоритет ще работи, а не мога да го откажа автоматично да вдига приоритетите. Дори в пдф-а му нищо не пише за този warning :evil:
Чет Ное 30, 2006 2:45 pm
Е кажи какво пише на този ред:
в тоя файл, че да не ровим из сорсовете
И още нещо, погледни в хелпа на CCS какво пише за приоритетите:
A summary of the different kinds of PIC18 interrupts:
#INT_xxxx
Normal (low priority) interrupt. Compiler saves/restores key registers.
This interrupt will not interrupt any interrupt in progress.
#INT_xxxx FAST
High priority interrupt. Compiler DOES NOT save/restore key registers.
This interrupt will interrupt any normal interrupt in progress.
Only one is allowed in a program.
#INT_xxxx HIGH
High priority interrupt. Compiler saves/restores key registers.
#INT_GLOBAL
Compiler generates no interrupt code. User function is located
at address 8 for user interrupt handling.
Syntax:
#priority ints
Elements:
ints is a list of one or more interrupts separated by commas.
export makes the functions generated from this directive available to other compilation units within the link.
Purpose:
The priority directive may be used to set the interrupt priority. The highest priority items are first in the list. If an interrupt is active it is never interrupted. If two interrupts occur at around the same time then the higher one in this list will be serviced first. When linking multiple compilation units be aware only the one in the last compilation unit is used.
Examples:
#priority rtcc,rb
Чет Ное 30, 2006 4:31 pm
Това ясно, Predator :)
#int_ext
Ето това пише там. Когато в сорса добавиш #device HIGH_INTS=1 (разрешаваме приоритетите на прекъсванията ) компилатора автоматически решава че определени прекъсвания - сред които int_ext и int_usb, може да има и други, не знам, ТРЯБВА да са високопроритетни. Без да си написал #int_edi_kwo_si high . Кой знае защо. А точно това на мен ми пречи в случая. A #global не ми се ще да го ползвам.
А#priority нищо не прави. Само определя кое от две равноприоритетни прекъсвания ще се изпълни първо. Но не и едното да прекъсва другото.
Чет Ное 30, 2006 5:20 pm
Значи прекъсвания, които си дефинирал с High се поставят 0x000008 , прекъсвания, на които не дефинираш приоритет би трябвало да стоят в 0x00018, ако компилатора ти сам поставя прекъсвания в High Priority секцията, сигурно го прави защото нямаш други прекъсвания, но си дефинирал #device HIGH_INTS=1. Имаш ли все пак други прекъсвания или само тези двете, за които ти вади "Warning" ?
Чет Ное 30, 2006 5:58 pm
Имам и от UART-a. За него обаче няма никакви претенции. За ext1, ext2 също няма претенции.
Чет Ное 30, 2006 6:56 pm
Местоположение: US
Обърни се към www.ccsinfo.com/forum . Опита ли с по-стара версия на компилатора ?
Чет Ное 30, 2006 8:47 pm
Гледах вече на техния форум. Нищо. ОК, явно никой не се е блъскал върху това. Ще се оправя някак си... :cry:
Пет Дек 01, 2006 3:01 pm
Местоположение: US
Да, явно никой не се е сблъсквал с такъв дерт. Ако имаш възможност, постни проекта, можеш да затриш код, който ти е важен и не е за показване, или пък остави празни функциите, да пробваме и ние, имам различни версии на компилатора, все ще излезне нещичко.
Не съм имал такъв проблем, тъй като използвам варианта с #INT_GLOBAL , първо прекъсването се изпълнява по-бързо, второ заема по-малко памет. Но това е при 16-ките, при 18-ките оставям компилатора да се грижи за тия неща.
Пет Дек 01, 2006 4:05 pm
Ами аз тоя код с приоритетните прекъсвания не го запазих... след като видях че не става. За проба е достатъчно да разрешат #device HIGH_INTS=1 в някой от семплите за usb да речем и да го видим какво ще направи..
Сря Дек 06, 2006 10:35 am
Верно, CCS v.3.249 не се наглася сам приоритетите... за сметка на това обаче #org се бъгне при него :evil: Аман!
Сря Дек 06, 2006 4:17 pm
Местоположение: Сливен
setoy написа:
ЕЕЕЕ нямаш ли още ВЕЛИКАТА 4 -та версия . Ако си със слабо сърце не ти препоръчвам да я слагаш ..........
Сря Дек 06, 2006 6:23 pm
