Темата е заключена, не можете да променяте мнения.  [ 205 мнения ]  Отиди на страница Предишна  1, 2, 3, 4, 5, 6, 7 ... 14  Следваща
Така не се прави!
Отговори с цитат
Мнение Re: Така не се прави!
> CrowdStrike IT Outage Explained by a Windows Developer
Dave explains the Crowdstrike IT outage, focusing in on its role as a kernel mode driver.
> CrowdStrike Update: Latest News, Lessons Learned from a Retired Microsoft Engineer
Dave brings you up to date on the CrowdStrike IT outage and considers its broader implications.
1. Introduction to the CrowdStrike Falcon IT Outage:
• Overview of the recent CrowdStrike Falcon IT outage and its impact on various industries.
2. Technical Details of the Outage:
• Explanation of the faulty sensor configuration update and how it led to system crashes (BSOD) on Windows systems.
• Specifics about the corrupted “Channel File 291.”
3. Impact and Response:
• Description of the scale of the outage, affecting approximately 8.5 million devices worldwide.
• Steps taken by CrowdStrike to deploy a fix and provide mitigation guidance to affected customers.
4. Previous Issues with Linux Systems:
• Recap of earlier incidents where CrowdStrike updates caused crashes on Debian and Rocky Linux systems.
5. CrowdStrike on macOS:
• Discussion about CrowdStrike’s security solutions for macOS and their use of Apple’s System Extensions.
6. Kernel vs. User Mode in Security Software:
• Analysis of why kernel-mode access is used by CrowdStrike and the associated risks.
• Historical context of kernel vs. user mode in Windows drivers.
7. Regulatory Challenges:
• Narrative on Microsoft’s attempt to introduce an API to prevent such issues and the regulatory hurdles faced from the European Union, which deemed it anticompetitive.
8. Conspiracy Theories and Broader Lessons:
• Overview of conspiracy theories that emerged around the outage.
• Lessons to be learned from the incident, drawing a parallel to the Tylenol crisis management.
I'm long since retired, and any opinions are mine alone; not a spokesperson!
Сря Юли 24, 2024 8:50 pm
Докладвай
Отговори с цитат
Купесто-дъждовна "облачност"... :D
Нов глобален срив в услугите на Microsoft
https://it.dir.bg/web/nov-globalen-sriv ... -microsoft
Вто Юли 30, 2024 10:43 pm
Докладвай
Отговори с цитат
... "професионална" фурна за пици на Lincoln USA - мотора на вентилатора хванат със скобичка за маркуч !
IMG_20240830_132329_442.jpg [ 2.64 MiB | Прегледано 3222 пъти ]
IMG_20240830_132255_371.jpg [ 2.33 MiB | Прегледано 3222 пъти ]
Пет Авг 30, 2024 1:28 pm
Докладвай
Отговори с цитат
Дали просто не е побългарено ?
Пет Авг 30, 2024 3:03 pm
Докладвай
Отговори с цитат
Не !
Гарантирам ,че аз съм първият европеец който и отваря ламарините (личи ,че има доста прах по машината) , а и ДОКОЛКО разбрах от собственика вкарал си е две - като едната имала проблем с горелката , а другата с електрониката ... човека си прехвърлил горелката и после 6 месеца търсил някой да му реставрира платката ... Вчера ми я домъкна (ако видя зор със "съживяването" мога да попитам Тук ) и понеже не дава много гас - ще я реанимирам когато ми остане повечко време !
Пет Авг 30, 2024 4:22 pm
Докладвай
Отговори с цитат
Мммм добре де, но какъв всъщност е проблема на това решение, освен, че е супер елементарно.
Пет Авг 30, 2024 4:36 pm
Докладвай
Отговори с цитат
... просто ми се стори "не професионално" & "не здраво" ... Не съм дипломиран инжинер учил 3 семестъра съпромат ...а и сам можеш да провериш цената на тая шайтан машина ... и накрая скобичка която държи мотор към 5-6 килограма ... натоварен с (да допуснем) перманентно биеща турбина ... просто ми се стори "не сериозно".
Това е !
Пет Авг 30, 2024 8:37 pm
Докладвай
Отговори с цитат
Това което аз виждам са 3 сравнително дебели профила хванати за корпуса на вентилатора с болтове М8 и отиващи отпред на предния фланец на мотора. Допълнително 3 тънки ламарини хванати със скоба за да намалят вибрациите. Което предполагам е основно при тръгване и спиране при натрупана мръсотия по перката. Не виждам голяма драма. Това, че е хванато халтаво даже е полезно в случая. Щом не се е скъсало всичко е наред. Не вярвам да им е първия продаден екземпляр.
Пет Авг 30, 2024 9:20 pm
Докладвай
Отговори с цитат
petko_sz написа:
Това е !
Колкото по-малотиражна е серията, толкова повече компоненти "обща употреба" се ползват. Някои неща в единични бройки са направо като правени в гараж.
Но поне е ремонто пригодно! Това напоследък си е лукс!
Чет Сеп 12, 2024 6:24 pm
Докладвай
Отговори с цитат
Ами ...въпрос на избор. Предполагам че щом си стигнал до ремонт все е работела досега, и като гледна мотора си е на мястото :)
Не изглежда инженерно но очевидно работи, и е елементарно....
Пет Сеп 13, 2024 4:33 am
Докладвай
Отговори с цитат
Долни леви педали...
Купен е за SSD диск 4TB.
IMG_20240924_194223.jpg [ 1.34 MiB | Прегледано 2843 пъти ]
IMG_20240924_194452.jpg [ 1.68 MiB | Прегледано 2843 пъти ]
IMG_20240924_194122.jpg [ 1.53 MiB | Прегледано 2843 пъти ]
Вто Сеп 24, 2024 7:48 pm
Докладвай
Отговори с цитат
Те отдавна ги пробутват такива ментета за без пари. Общо взето човек получава баш колкото си е платил.
Вто Сеп 24, 2024 9:46 pm
Докладвай
Отговори с цитат
Аааа, китайската скрап. Пълно е с такива - много терабайти за никакви пари.
Ето с какво се беше сдобил приятел преди време - от "експреса":
chinese_garbage_1.jpg [ 94.7 KiB | Прегледано 2824 пъти ]
chinese_garbage_2.jpg [ 92.54 KiB | Прегледано 2824 пъти ]
chinese_garbage_3.jpg [ 215.38 KiB | Прегледано 2824 пъти ]
chinese_garbage_5.jpg [ 222.92 KiB | Прегледано 2824 пъти ]
Пък феновете на чайника да продължават да обясняват, че чайниците не са измамници и мизерници...
Вто Сеп 24, 2024 9:48 pm
Докладвай
Отговори с цитат
Vasseto написа:
Това ако не го бях видял разглобено, нямаше да повярвам, че го правят и че и го продават за "SSD storage".
Вто Сеп 24, 2024 9:54 pm
Докладвай
Отговори с цитат
palavrov написа:
...Общо взето човек получава баш колкото си е платил.
Не съм съгласен с горното.
Стоката трябва да отговаря на описанието си. Не всеки е технически гуру, непрекъснато следящ ревюта и отзиви.
Има хора които са скарани с техниката и просто искат да си купят диск. Гледат базови параметри като обем / цена, размер, с каква "дупка" за включване е устройството, и ако преценят че им върши работа, купуват.
Вто Сеп 24, 2024 10:16 pm
Докладвай
