Отговори на тема  [ 1626 мнения ]  Отиди на страница Предишна  1, 2, 3, 4, 5, 6, 7, 8 ... 109  Следваща
ChatGPT
Мнение Re: ChatGPT
Реверсвам един код и ...
Тука вече паднах от стола ...
АЗ
Можеш ли да транслираш следния код на езика C
.text:00404454 ; =============== S U B R O U T I N E =======================================
.text:00404454
.text:00404454 ; Attributes: bp-based frame
.text:00404454
.text:00404454 sub_404454      proc near               ; CODE XREF: sub_4042D0+85↑p
.text:00404454
.text:00404454 var_8           = dword ptr -8
.text:00404454 var_4           = dword ptr -4
.text:00404454 arg_0           = dword ptr  8
.text:00404454 arg_4           = dword ptr  0Ch
.text:00404454
.text:00404454                 push    ebp
.text:00404455                 mov     ebp, esp
.text:00404457                 add     esp, 0FFFFFFF8h
.text:0040445A                 xor     eax, eax
.text:0040445C                 mov     [ebp+var_8], eax
.text:0040445F                 mov     edx, [ebp+arg_4]
.text:00404462                 dec     edx
.text:00404463                 mov     [ebp+var_4], edx
.text:00404466                 jmp     short loc_404485
.text:00404468 ; ---------------------------------------------------------------------------
.text:00404468
.text:00404468 loc_404468:                             ; CODE XREF: sub_404454+3A↓j
.text:00404468                 mov     ecx, [ebp+arg_0]
.text:0040446B                 xor     eax, eax
.text:0040446D                 mov     al, [ecx]
.text:0040446F                 add     [ebp+var_8], eax
.text:00404472                 inc     [ebp+arg_0]
.text:00404475                 test    byte ptr [ebp+var_8+1], 1
.text:00404479                 jz      short loc_404485
.text:0040447B                 and     [ebp+var_8], 0FFh
.text:00404482                 inc     [ebp+var_8]
.text:00404485
.text:00404485 loc_404485:                             ; CODE XREF: sub_404454+12↑j
.text:00404485                                         ; sub_404454+25↑j
.text:00404485                 mov     edx, [ebp+var_4]
.text:00404488                 add     [ebp+var_4], 0FFFFFFFFh
.text:0040448C                 test    edx, edx
.text:0040448E                 jnz     short loc_404468
.text:00404490                 mov     al, byte ptr [ebp+var_8]
.text:00404493                 and     al, 0FFh
.text:00404495                 pop     ecx
.text:00404496                 pop     ecx
.text:00404497                 pop     ebp
.text:00404498                 retn
.text:00404498 sub_404454      endp
.text:00404498
.text:00404498 ; ---------------------------------------------------------------------------
.text:00404499                 align 4
.text:0040449C
.text:
ТОЙ
Да, мога да транслирам този код на езика C. Ето го транслираният код:
c
Copy code
int sub_404454(char* arg_0, int arg_4) {
    int var_8 = 0;
    int var_4 = arg_4 - 1;
    while (var_4 >= 0) {
        char ecx = *arg_0;
        var_8 += ecx;
        arg_0++;
        if (var_8 & 0x100) {
            var_8 = (var_8 & 0xFF) + 1;
        var_4--;
    return var_8 & 0xFF;
Това е функция, която сумира символите на символен низ от дължина arg_4 и връща резултата модул 256.
АЗ
Имаш само една грешка реда while (var_4 >= 0) трябва да е while (var_4 > 0) Поздравления.
ТОЙ
Благодаря Ви за отбелязването на грешката! Действително, в условието на цикъла while, трябва да се използва операторът > вместо >=, тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. Ето и коригираната версия на кода:
c
Copy code
    int var_8 = 0;
    while (var_4 > 0) {
        char ecx = *arg_0;
        var_8 += ecx;
        arg_0++;
        var_4--;
Благодаря Ви отново за забележката!
Въпреки че и това не е вярно (тъй като arg_4 се намалява с 1 на ред 0x00404462 и съответно низът има дължина arg_4 - 1. )
е впечатляващо
Вниманиене съмвишист....ИЙ.
Пет Мар 03, 2023 12:50 am
Мнение Re: ChatGPT
Чай сега ще го питам за тоя чип със сбъркания дейта шийт :)
Пет Мар 03, 2023 1:05 am
Мнение Re: ChatGPT
Ако му дадеш повече инфо, като му дадеш за какво да се хване ,предполагам че много елегантно ще се съгласи с теб ... въпреки това ще те изненада.
Пет Мар 03, 2023 1:16 am
Мнение Re: ChatGPT
Не можа да ме изненада, говори общи приказки, но ги говори логично, ще елиминира въпросите на студенти търсещи кой да им напише курсовия проект :)
Пет Мар 03, 2023 1:20 am
Мнение Re: ChatGPT
Бахти чата гадта разбира и от вредители и препарати. Ше го питам и за моя проблем ESP8266
Пет Мар 03, 2023 7:53 am
Мнение Re: ChatGPT
Ако му обясниш естеството на проблема с три думи - както обичаш да обясняваш тук, не се надявай на помощ. :lol:
Пет Мар 03, 2023 9:51 am
Мнение Re: ChatGPT
От консерви разбира ли? Компоти, туршии, вина, ракии, домашна и експериментална химия и физика?
Пет Мар 03, 2023 12:48 pm
Мнение Re: ChatGPT
:D
byte.jpg [ 259.85 KiB | Прегледано 4438 пъти ]
Пет Мар 03, 2023 7:30 pm
Мнение Re: ChatGPT
Grubi написа:
От консерви не разбира, лъже и дава друга рецепта.
Не познава растения от снимка и говори глупости, но пък по име добре се справя с гугъл и дава верни линкове.
Пет Мар 03, 2023 7:59 pm
Мнение Re: ChatGPT
Това е от StableDiffusion, но е впечатляващо
https://sites.google.com/view/stabledif ... ith-brain/
Пет Мар 03, 2023 11:34 pm
Мнение Re: ChatGPT
RM написа:
АЗ
.text:00404454
.text:00404454
.text:00404454
.text:00404454
.text:00404468
.text:00404485
.text:00404498                 retn
.text:00404498
.text:0040449C
.text:
ТОЙ
c
Copy code
    int var_8 = 0;
        char ecx = *arg_0;
        var_8 += ecx;
        arg_0++;
        var_4--;
АЗ
ТОЙ
c
Copy code
    int var_8 = 0;
    while (var_4 > 0) {
        char ecx = *arg_0;
        var_8 += ecx;
        arg_0++;
        var_4--;
е впечатляващо
Тя и проверката на цикъла не е нито >0 нито >=0 ами !=0 ...
Съб Мар 04, 2023 12:30 am
Мнение Re: ChatGPT
palavrov написа:
Така е - JNZ
Не съм толкова добър но замазах нещата до работещ вариант.
Функцията предава два аргумента, поинт към масив и дължина на масива.
вътре си създава две променливи, едната е сумата от байтовете която функцията ще връща, другата е поинт към адресите на байтовете на масива .
Записал съм го така ... .
uchar_8 fun(const void *my_array,int l){
int s;
const uchar_8 *p=(uchar_8) my_array;
for(;l;l--){
s+=*p++;
if(s&0x100)s=(s&0xFF)+1;
дължината на масива няма как да мине под 0.
Съб Мар 04, 2023 6:21 pm
Мнение Re: ChatGPT
RM написа:
Ако искаш да е коректно типът на дължината трябва да е unsigned или по-модерното size_t.
Иначе имаш int аргумент и ако някой по-разсеян ти подаде отрицателна стойност функцията ще се замисли яко и после ще гръмне ако свърши паметта.
Съб Мар 04, 2023 7:11 pm
Мнение Re: ChatGPT
За какво ви е това, като си има гугле? :)
miro_atc написа:
RM написа:
То и като писах на асемблер колега от физиката ми каза да използвам други команди, че по-лесно се помнели. Оказа се, че са за знакови числа и почна да гърми...
Пон Мар 06, 2023 10:55 am
Мнение Re: ChatGPT
Сега вече изтрепаха рибата
https://www.youtube.com/watch?v=Mqg3aTGNxZ0
https://writings.stephenwolfram.com/202 ... perpowers/
Съб Мар 25, 2023 12:15 am
