Обречен въпрос :(
Мнение Обречен въпрос :(
Става въпрос за HET-а на TMS470. Мъча се да генерирам единичен импулс, контролиран от CPU-то. Кода изглежда така:
L00: CNT  {reg=A, irq=OFF, max=1000, data=1}
L01: ECMP {reg=A, hr_lr=LOW, en_pin_action=on, pin=CC6, action=SET, irq=off, data=0}
L02: ECMP {reg=A, hr_lr=LOW, en_pin_action=on, pin=CC6, action=CLEAR, irq=off, next=L03, cond_addr=GO_LOW1, data=0}
GO_LOW1: MOV32 {reg=NONE, type=IMTOREG&REM, init=OFF, remote=L02, data=0}
GO_LOW2: MOV32 {reg=NONE, type=IMTOREG&REM, init=OFF, remote=L01, data=0}
L03: BR     {next=L00, cond_addr=L00, event=NOCOND}
но не работи - като начало, защото L01 и L02 не се нулират. :( След като се запишат стойности в тях, се получава безкрайно генериране.
Имам ли шанс съпорта на TI да ми отговори, ако им поставя въпроса?
Сря Авг 30, 2006 12:09 am
Има. Почти винаги отговарят и почти винаги смислено. От отсрещната страна е Microchip ( ша ма извиняват пиколюбците ).
Сря Авг 30, 2006 9:47 am
Честито:
Dear Grigorii Nanev,
Thank you for contacting the European Product Information Centre.
Regarding your inquiry about the product TMS470 we would like to inform you that we are unfortunately unable to offer any interactive support at the moment. All information that is available for this product can be found on the following link:
www.ti.com/tms470
You will be able to order samples and development tools via our distribution channel partners.
Best Regards,
Your E-PIC team
Texas Instruments
И още:
TI assumes no liability for applications assistance or customer product design. Customer is fully responsible for all design decisions and engineering with regard to its products, including decisions relating to application of TI products. By providing technical information, TI does not intend to offer or provide engineering services or advice concerning Customer's design. If Customer desires engineering services, the Customer should rely on its retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE).
Сря Авг 30, 2006 12:29 pm
ДАй малко повече инфо/код....
пуснал ли си клоците на таймера ?
Бил Гейтс
Сря Авг 30, 2006 12:46 pm
nickich написа:
Ами това е абсолютно целия код.
nickich написа:
След като има генерация, има и клок, въпроса е, че искам само едно импулсче, не PWM.
Сря Авг 30, 2006 1:39 pm
Без да си имам идея за тоя чип ще ти кажа, че ако се опитваш да пуснеш определен брой импулси на хардуерния ШИМ - няма да стане. Ползвай output compare-те.
Сря Авг 30, 2006 3:31 pm
Мнение Re: Обречен въпрос :(
Реконструктор написа:
L02: ECMP {reg=A, hr_lr=LOW, en_pin_action=on, pin=CC6, action=CLEAR, irq=off,[b] next=L03[/b], cond_addr=GO_LOW1, data=0}
[i]
[/i]
Незнам дали съм прав, но
май не се изпълнява... поради
Бил Гейтс
Сря Авг 30, 2006 4:06 pm
Dimitar написа:
HET е далеч от понятието "хардуерен ШИМ". Иначе нямаше да има много смисъл от него.
По принцип, мога да направя това, което искам, ако прекъсна процесора, но ще се старая по всякакъв начин да го избегна.
Сря Авг 30, 2006 5:24 pm
="май не се изпълнява... поради
Би следвало да се изпълни, поради cond_addr=GO_LOW1
Cond_addr* Conditional address: (Optional) Defines the address of
the next instruction when the condition occurs.
Default: Current address + 1.
Сря Авг 30, 2006 5:28 pm
В такъв случай реда:
би трябвало да стане:
L02: ECMP {reg=Т, hr_lr=LOW, en_pin_action=on, pin=CC6, action=CLEAR, irq=off, next=L03, cond_addr=GO_LOW1, data=0}
"High-End Timer (HET) (SPNU199D)", p.117 =>
If (register T is selected)
T register = Compare value (25 bit);
Jump to Conditional Address;
elseIf (Z == 1 AND Opposite action == 1)
If (Enable Pin action == 1)
Selected Pin = opposite Pin Action AT next loop
resolution clock;
Jump to Next Program Address;
ако не си му казал Т адрес ще почне да ти4а от next адреса, и ще прескочи двата реда .... мисля....
Бил Гейтс
Сря Авг 30, 2006 6:04 pm
