Отговори на тема  [ 33 мнения ]  Отиди на страница Предишна  1, 2, 3  Следваща
Препоръчайте някой LTE / 4G / GPS модул
Местоположение: Phoenix AZ
Мнение Re: Препоръчайте някой LTE / 4G / GPS модул
Тони ,
виж какво е излезло - LILYGO T-A7068E-H/T-A7608SA-H board
Wireless Connectivity
WiFi & Bluetooth – ESP32-WROVER-E module based on ESP32 dual-core processor @ 240 MHz with 4MB flash, 8MB PSRAM, 2.4 GHz WiFi 4 and Bluetooth 4.2/5.x connectivity, PCB antenna
Cellular connectivity
Data transfer speeds
4G LTE – Up to 150 Mbps downlink, up to 50Mbps uplink
3G HSPA+ – Up to 42 Mbps downlink, up to 5.76 Mbps uplink
3G UMTS – Up to 384 Kbps DL/UL
2G Edge – Up to 236.8 Kbps DL/UL
2G GPRS – Up to 85.6 Kbps DL/UL
Frequency bands
SIMCom A7608SA-H module (South America, New Zealand, and Australia)
4G LTE FDD – B38, B40, B41
4G LTD TDD – B1, B2, B3, B4, B5, B7, B8, B20, B28, B66
3G – B1, B2, B5, B8
2G – 850, 900, 1800, 1900 MHz
SIMCom A7608E-H variant (EMEA, South Korea, and Thailand)
4G LTD TDD – B1, B3, B5, B7, B8, B20
3G – B1, B8
2G – 900/1800 MHz
Nano-SIM card socket, 1x external 4G LTE antenna (but 2x u.FL antenna connectors)
Supply Voltage – 3.4 to 4.2V
Dimensions – 30 x 30 x 2.5 mm (LGA module)
GNNS with external GPS antenna
Storage – MicroSD card socket
USB
1x USB Type-C port for power and programming
1x Micro USB port to use the board as a 4G LTE USB dongle
Expansion – 2x 16-pin headers with GPIOs, ADC, DAC, touch interface, UART, I2C, SPI, VN/VP, Reset, VBUS, VBAT, 3.3V, GND
Misc – Reset and Boot buttons, battery switch,
Power Supply
5V via USB Type-C port
16850 battery holder + charging circuit
4.4V to 6V via 2-pin header for solar panel input or external battery
Power consumption with a 3.7V battery
Active – 170 mA
Sleep – 0.125 mA
Dimensions – 11 x 3.2 x 2 cm
Пон Юни 27, 2022 10:30 pm
Тука при нас у Америка разкарват 3 Г то , мин седмица псувах че 1 от моите тел не бачка ама го оправиха.
Та в тая връзка има ли нео подобно обявено за Европата?
https://www.fcc.gov/consumers/guides/pl ... nd-service
If your mobile phone is more than a few years old, you may need to upgrade your device before your mobile provider shuts down its 3G network, to avoid losing service. For more information on your mobile providers' plans for 3G retirement and how you can prepare, contact your provider directly.
What is happening?
Mobile carriers are shutting down their 3G networks, which rely on older technology, to make room for more advanced network services, including 5G. As a result, many older cell phones will be unable to make or receive calls and texts, including calls to 911, or use data services. This will affect 3G mobile phones and certain older 4G mobile phones that do not support Voice over LTE (VoLTE or HD Voice).
Learn more about other connected devices, such as medical devices and home security systems that may be impacted below.
When is it happening?
As early as January 1, 2022, though plans and timing to phase out 3G services will vary by company and may change. Consult your mobile provider's website for the most up-to-date information.
AT&T announced that it will finish shutting down its 3G network by February 2022.
Verizon announced that will finish shutting down its 3G network by December 31, 2022.
T-Mobile announced that it will finish shutting down Sprint's 3G CDMA network by March 31, 2022 and Sprint's 4G LTE network by June 30, 2022. It also announced it will shut down T-Mobile's 3G UMTS network by July 1, 2022, but has not yet announced a shutdown date for its 2G network.
If your mobile carrier is not listed here, you may still be affected. Many carriers, such as Cricket, Boost, Straight Talk, and several Lifeline mobile service providers, utilize AT&T's, Verizon's, and T-Mobile's networks.
Пон Юни 27, 2022 10:40 pm
TheWizard написа:
EG915U
https://www.youtube.com/watch?v=iF06FHYSfZM
не е от много бързите, нормална скорост(виж PDF)
има 3 "версии" SDK
- нормални АТ команди
за вътрешни апликации:
- C ( мисля че беше FreeRTOS + LwIP )
- uPython
EC25 - Qualcomm SoC
от "бързите", незнам колко е наличен
SDK по принцип е Linux ... като Малинка зеро, но флоат софт
EC25AFA-512-STD в Дигикеъ днес е 67,16 американски лева без такси.
Пон Юни 27, 2022 10:47 pm
Ами а, дълго се псувах с АТ&Т, всеки месец ми спираше телефона, обаждаш се пускат го, обясняват ти как минават на 5Г да ти продадяли нов ала бала .. бая ги нахраних последният път, ъпдейтнах фърмуера да работи с 5Г и скоро не съм имал проблем, но пък БГ телефона ми нещо му стана, тоя мтелски педал нещо ми сменя плана и от както съм се върнал в сащ телефона не приема смс-и ...не мога да банкирам
Пон Юни 27, 2022 11:09 pm
Все пак ако искаш да псоде;иш - ти намери ли модулче?
Щото и на мене ми трябва обаче за европа.
Та зора е от де да се купи и да знам че поне 1 година ще мога да купувам - моя проект е мижави броики.
Сря Юни 29, 2022 5:52 pm
Сложих един ublox, клиента каза, че може да си го намира, към момента наличности има и в Фиджи и в Маузер но докога ще е така не знам.
Сря Юни 29, 2022 8:29 pm
Предполагам е това
SARA-R412M-02B-01
7,099 In Stock
QTY UNIT PRICE EXT PRICE
1 $65.34000 $65.34
10 $49.00000 $490.00
50 $39.13020 $1,956.51
100 $35.37800 $3,537.80
Моя проблем е че с моите мижави броки аз тва ще се сдухам докат го залепя на ръка на по голямата платка.
Чет Юни 30, 2022 8:27 am
ами сега чакам платка за да наситя една бройка, ще видим какво ще се получи, то варианта е с хийт плейта, ще взема и някой по-ниско температурен припой и ще видим, иначе фабрично лесно, и във фурничка става, но там по-може да се прецака нещо ако не мери много вярно или -рофила е грешен, току разпоила нещо в модула.
Чет Юни 30, 2022 8:41 am
сигурен ли си, че ти трябва SARA-R412M-02B-01 ( еквиваленти Quectel BG96, Simcom SIM7000 )
модула е NB-IoT / LTE-M / EGPRS ( 2G ) и няма нищо общо с LTE ( 4G )
стар ( и скъп ) чипсет: Qualcomm MD9206
новите SoC за препоръчване са Qualcomm MDM9205 - u-blox незнам дали го използват, използват за новите техен си чипсет UBX-R5
еквиваленти Quectel BG95/BG77, Simcom SIM7070/SIM7080/SIM7090
узер SDK-то за Qualcomm модули е база ThreadX и дава огромни възможнисти за без външно управление
sara.jpg [ 300.2 KiB | Прегледано 2465 пъти ]
Чет Юни 30, 2022 10:55 am
това което аз използвам е SARA-R510M8S-01B, гледам, че в момента е паднало до 201 бр. в диджито, но това си е грижа на коиента, аз няма да се занимавам с производството, поне за сега, той каза, че може да си ги доставя, имаше и друго предложение, но то беше точно като зa iot, не му помня модела, но мога да проверя.
Чет Юни 30, 2022 2:01 pm
по принцип ... GSM с АТ команди - избирай по красота, цена и достъпност
на този етап са натрупали над 25 години опит с технологията и не вярвам някой да се "омаже" с основните протоколи и услуги
а ако се съмняваш в GSM модул - търси го в FCC базата данни
https://fccid.io/
щом са дали много пари - тряя да работи
Чет Юни 30, 2022 6:41 pm
Ako Може малко съвети и за мен .
По горе указаното модулче ( ЕСП + СИМ7000Г) го намерих за 37 усд на ибея вече тази цена е Ок за мен.
Доколкото прочетох за това ( SIM7000G ) би трябвало да е ОК за моите нужди да пращам ТЕКСТ и да получавам - друго не ми трябва засега.
Употребата е за Немско наи вече .
Ама поне това може да се купи та и затова се зарових.
Сря Юли 06, 2022 1:43 am
HSB :) поста с картинката беше за теб
4Г(LTE) ли ти трябва или NarrowBand
btw комбинирани LTE+NB няма има GPRS+NB (+- GPS)
Сря Юли 06, 2022 8:15 am
TheWizard написа:
Сори не съм разбрал .
Обаче Тони рече че е намерил модул в Дигикей а там само тоя САРА беше.
И нк от системна гледна точка ето какво трябва да прави моито устроиство:
Пращам СМС там се извършва нещо и ми отговатя със СМС.
Все ми е тая откъде ще мине ,на каква честота ..колко е старо и т.н.
И почнах да гледам какво може да се купи .... ето какво намерих :
TTGO T-SIM7000G Module ESP32-WROVER-B Chip WiFi Bluetooth 18560 Battery Holder
https://www.ebay.com/itm/154709565236?h ... BM6Ly00bpg
От това дето прочетох за SIM7000G уж става но аз въобще не съм спец по материята и съответно питам .
Сря Юли 06, 2022 11:01 pm
само нормален ГСМ може да праща СМС
някой оператори махат 2G ( GPRS ) и 3G подръжките
остава 4G ( LTE ) търси някой евтин такъв за да си сигурен че ще работи и бъдеще ... ама са скъпи
NB/CAT-М са LPWA - частен случай и не пращат СМС (CAT-М може и да праща, не съм сигурен и май зависи от оператора да ли си е настроил апаратурата)
Европа ползва NB ... USA - CAT-М .... btw: за тези иска и специфична сим на която е разрешено (по APN) да работи в LPWA обхвата
SIM7000 e 2G ( GPRS ) + NB + CAT-М
ама ако 2G ( GPRS ) ти върши работа Симком имат само 2G ( GPRS ) модули ... и са по-евтини от избрания
https://www.simcom.com/module/2g.html
Последна промяна TheWizard на Чет Юли 07, 2022 12:08 am, променена общо 1 път
Сря Юли 06, 2022 11:48 pm
