Отговори на тема  [ 267 мнения ]  Отиди на страница Предишна  1 ... 5, 6, 7, 8, 9, 10, 11 ... 18  Следваща
LPWA - Narrow Band, Lora...
Мнение Re: LPWA - Narrow Band, Lora...
горното с добавен GSP
пример
#include <Arduino.h>
#include <Device.h>
#include <Dss.h>
#include <Ril.h>
#include <txDns.h>
#include <Wire.h>
#include <NMEA.h>
#include <txMqtt.h>
#include "MQTT_CONFIG.h"
NMEA nmea;
MqttClient mqtt;
String IMEI;
void sensorInit();
float readTemperature();
float readHumidity();
Ril ril(QAPI_AT_PORT_1);
static void ril_callback(qapi_at_pipe_data_t *data)
  ril.save(data->data, data->len);
Dns dns;
Device dev;
String iface;
int dataCallReady = 0;
void onDssConnect(void);
Dss dss(onDssConnect);
  IPAddress local, gateway, primary, secondary;
  dss.getIFace(iface);
  dss.get(local, gateway, primary, secondary);
  //Serial1.printf("[DSS] IFACE     %s\n", iface.c_str());
  Serial1.printf("[DSS] LOCAL     %s\n", local.toString().c_str());
  Serial1.printf("[DSS] GATEWAY   %s\n", gateway.toString().c_str());
  Serial1.printf("[DSS] PRIMARY   %s\n", primary.toString().c_str());
  Serial1.printf("[DSS] SECONDARY %s\n", secondary.toString().c_str());
  dns.start(); // and set DNS client
  dns.add(DNS_V4_PRIMARY, "8.8.8.8");
  dns.add(DNS_V4_SECONDARY, "8.8.4.4");
  dataCallReady = 1;
struct minmea_sentence_rmc rmc;
void onNMEA(char *line)
  switch (minmea_sentence_id(line, false))
  case MINMEA_SENTENCE_RMC:
    if (minmea_parse_rmc(&rmc, line))
      //if (rmc.valid) Serial1.printf("GPS: LAT = %f, LON = %f\n", minmea_tocoord(&rmc.latitude), minmea_tocoord(&rmc.longitude));
void onMessage(qapi_Net_MQTT_Hndl_t mqtt, int32_t reason,
               const uint8_t *topic, int32_t topic_length,
               const uint8_t *msg, int32_t msg_length,
               int32_t qos, const void *sid)
  DBG("MQTT Receive\n");
  DBG("   Topic: %.*s\n", topic_length, topic);
  DBG("   Message: %.*s\n", msg_length, msg);
void publish()
  char buff[256];
  float T, H;
  T = readTemperature();
  H = readHumidity();
  //Serial1.printf("SENSOR: Temperature = %f, Humidity = %f\n", T, H);
  snprintf(buff, sizeof(buff), "{\"ser\":\"%s\",\"tmp\":\"%.2f\",\"hum\":\"%.2f\",\"lat\":\"%f\",\"lon\":\"%f\"}",
           IMEI.c_str(), T, H, minmea_tocoord(&rmc.latitude), minmea_tocoord(&rmc.longitude));
  if (mqtt.pub("wizio/pub", buff, strlen(buff)))
    DBG("MQTT Publish: %s\n", buff);
void setup()
  Serial1.begin(115200);
  Serial1.debug();
  Serial1.println("\nArduino Quectel BG96 - MQTT");
  ril.begin(ril_callback);
  ril.send("AT+QCFG=\"nwscanmode\",1\r\n", NULL); // only gprs
  ril.send("AT+QSCLK=0\r\n", NULL);               // disable sleep
  dev.getIMEI(IMEI);
  Serial1.printf("IMEI: %s\n", IMEI.c_str());
  dev.waitSim();
  nmea.begin(onNMEA);
  Serial1.println("Sim ready");
  sensorInit();
  //return;
  dss.apn("gprs", "user", "pass");
  dss.open(RADIO_UNKNOWN);
  dss.begin();
  while (0 == dataCallReady)
    delay(100);
  Serial1.println("Net ready");
  IPAddress MQTT_IP;
  if (dns.query(MQTT_HOST_NAME, MQTT_IP))
    mqtt.server((uint32_t)MQTT_IP, MQTT_PORT);
    mqtt.client(IMEI);
    mqtt.onMessage = onMessage;
#ifdef MQTT_SECURED
    mqtt.secured();
    mqtt.certificate(SSL_CERT_FILE_NAME, SSL_KEY_FILE_NAME);
    Serial1.print("Amazon ");
#else
    Serial1.print("Eclipse ");
#endif
    Serial1.println(MQTT_IP);
    Serial1.print("MQTT Connecting...");
    while (!mqtt.connect())
      Serial1.print(".");
      delay(60000);
    Serial1.println(" Done");
    mqtt.sub("wizio/sub");
    publish();
void loop()
  static int t = 0;
  if (seconds() - t > 60) // publish interval in seconds
    t = seconds();
    publish();
  delay(1000);
GPS-AWS.png [ 1.12 MiB | Прегледано 6785 пъти ]
Вто Юни 11, 2019 10:50 am
след едноседмична заигравка с облаци
google iot core.png [ 136.33 KiB | Прегледано 6719 пъти ]
Вто Юни 18, 2019 6:18 pm
и Microsoft Azure IoT Core "падна плячка"
AZURE.png [ 231.4 KiB | Прегледано 6679 пъти ]
Сря Юни 19, 2019 3:29 pm
малко секюрити инфо за LoRaWAN ( на руски )
https://habr.com/ru/post/458394/
Пон Юли 01, 2019 8:51 pm
Новото е Quectel BG96 - PlatformIO - ThreadX и Arduino
https://github.com/Wiz-IO/platform-quec ... platformio
ThreadX - стандартни SDK леко преработени за GCC
Arduino: в разработка е - може да има бъгове
https://github.com/Wiz-IO/platform-quec ... plications
Чет Юли 04, 2019 2:33 pm
а тук малко екзампъли за горния пост
https://github.com/Wiz-IO/platformio-qu ... duino/bg96
Пет Юли 05, 2019 12:32 pm
проби... JavaScript с Quectel BG96 ( ThreadX ) :) :) :)
PS: тръгна и от файл, снимката е от стринг
BG96-JavaScript.png [ 92.81 KiB | Прегледано 6419 пъти ]
Вто Юли 16, 2019 3:05 pm
резултат от друга тема ( newlib - stdio линк )
приложена към Quectel BG96 - ThreadX User API ( снимката ) ( app size 54 k от 3 меги макс ) { 20 k ми взима printf full }
пример за GPS ( stdio )
#include <interface.h>
char imei[16] = {0};
char nmea[128];
MAIN()
    system_init(1);
    read( open("/dev/sim-ready", 0), 0, 0 ); // wait ready
    read( open("/dev/imei", 0), imei, sizeof(imei) );
    printf("IMEI: %.*s", 15, imei);
    FILE *gps = open("/gps", 0);
    while (1)
        if ( fgets(nmea, sizeof(nmea), gps) )
            puts( nmea );
        delay(100);
quectel-bg96-stdio.jpg [ 863.92 KiB | Прегледано 6352 пъти ]
Вто Юли 23, 2019 7:37 pm
на горния пост GPS-a
unix-like.png [ 86.82 KiB | Прегледано 6310 пъти ]
Сря Юли 24, 2019 4:41 pm
Излиза нов играч на пазара с Lora GW https://download2.mikrotik.com/news/news_89.pdf страница 5.
Отдавна се надявах микротик да се насочат в този сегмент.
lz2com
Чет Юли 25, 2019 10:11 am
малко за дистанциите между LTE-M( CAT-M1 ) и NB-IoT ( CAT-NB1 )
тестове на Нордик
https://www.youtube.com/watch?v=p1_0OAlTcuY
Сря Юли 31, 2019 10:46 am
не е точно LPWA но става за IoT...
Quectel EC25 https://youtu.be/nw-W78SpLRQ
Сря Авг 28, 2019 4:12 pm
С LTE на МАХ си е друго нещо
Sending data to Amazon over MQTT
https://www.youtube.com/watch?v=sbLJNXT ... rgiAngelov
Пет Авг 30, 2019 7:15 pm
На работа се мъчим с Quectel bc66. Проблемът е следния:
В Пловдив има само една клетка, която подържа Narrow Band на 3-ти канал, т.е около 1800 MHz. Интересното е, че въпреки, че клетката е на около 2 км без пряка видимост от работата, когато съм в самата сграда (която има и решетки на прозорците) чат-пат успявам да се свържа дори с PCB UFL антена. Всички се изумяват, как изобщо успявам да се свържа, предвид, че има някакъв RSSI От порядъка на -90 dBm и SNR около 0 (между -3 dB и +3 dB). За да тестваме платките, които сме произвели, заехме една Huawei Yagi антена. И сега идва интересната част:
Около фирмата има доста високи сгради и дървета. когато застана пред сградата между дърветата успявам да се свържа доста често с клетката и RSSI го дава около -80 dBm при SNR до 6. Ако се кача на покрива на сградата, над същите въпросни дървета, не мога да се свържа към клетката. Ако спусна антената от покрива пак се свързва. Че ни е грозна постановката - грозна е. Антената си дойде с 15м кабел (коаксиален), на който в края му запоихме едно тънко кабелче с UFL Накрайник, за да можем да я закачим за платката. Още по-любопитното ми е, че живея на около 300 метра от клетката пресечен терен. Пробвах с оригиналната антена на Quectel, Пробвах с Yagi антената и не мога да се свържа от вкъщи. Пробвах да излезна на едни гаражи до блока, малко по-наоткрито и насочих антената към клетката. Пак не успях да се свържа с двете антени. Изобщо излиза, че този Narrow band или иска само пряка видимост или този канал е кофти и е капризен откъм разпространение на вълната и прихващането й. В тоя ред на мисли, как аджеба ще забуча някакво модулче някъде си и ще съм сигурен, че това модулче ще се свърже с NB мрежата? Искам да кажа, че опитите до сега ми хвърлят доста голямо съмнение в тази технология. Предвид, че GSM-ма ми, който е сигурно с пъти по-малка антена и с по-малка чувствителност има с пъти по-добър обхват?
Вто Сеп 03, 2019 6:57 am
просто LWPA над гигахерц е кофти ... заради разпространението на вълната, а и радиус 3 км в градски условия е "чудесно"
Най-доброто решение: кажи на твоя шеф да говори с A1 да сменят клетката на 900 или да ви пуснат някоя по-близо до вас
Вто Сеп 03, 2019 8:35 am
