Дата и час: Сря Ное 25, 2026 7:42 am
stefan63
 Re: I2C малко помощ
EEPROM_Buffer[0] =X;
| Нед Юли 30, 2017 8:38 pm |
lcr
 Re: I2C малко помощ
Благодаря! Това означава ли, че slave ще праща към master - а съдържанието на целия EEPROM буфер? Т.е - да запиша следващата променлива в EEPROM_Buffer[1] и т.н. ? От страна на master - а MCC генерира следната конфигурация: i2c1.c :  |  |  |  | Код: #include "i2c1.h"
/** I2C Driver Queue Status Type
@Summary Defines the type used for the transaction queue status.
@Description This defines type used to keep track of the queue status. */
typedef union { struct { uint8_t full:1; uint8_t empty:1; uint8_t reserved:6; }s; uint8_t status; }I2C_TR_QUEUE_STATUS;
/** I2C Driver Queue Entry Type
@Summary Defines the object used for an entry in the i2c queue items.
@Description This defines the object in the i2c queue. Each entry is a composed of a list of TRBs, the number of the TRBs and the status of the currently processed TRB. */ typedef struct { uint8_t count; // a count of trb's in the trb list I2C1_TRANSACTION_REQUEST_BLOCK *ptrb_list; // pointer to the trb list I2C1_MESSAGE_STATUS *pTrFlag; // set with the error of the last trb sent. // if all trb's are sent successfully, // then this is I2C1_MESSAGE_COMPLETE } I2C_TR_QUEUE_ENTRY;
/** I2C Master Driver Object Type
@Summary Defines the object that manages the i2c master.
@Description This defines the object that manages the sending and receiving of i2c master transactions. */
typedef struct { /* Read/Write Queue */ I2C_TR_QUEUE_ENTRY *pTrTail; // tail of the queue I2C_TR_QUEUE_ENTRY *pTrHead; // head of the queue I2C_TR_QUEUE_STATUS trStatus; // status of the last transaction uint8_t i2cDoneFlag; // flag to indicate the current // transaction is done uint8_t i2cErrors; // keeps track of errors
} I2C_OBJECT ;
/** I2C Master Driver State Enumeration
@Summary Defines the different states of the i2c master.
@Description This defines the different states that the i2c master used to process transactions on the i2c bus. */
typedef enum { S_MASTER_IDLE, S_MASTER_RESTART, S_MASTER_SEND_ADDR, S_MASTER_SEND_DATA, S_MASTER_SEND_STOP, S_MASTER_ACK_ADDR, S_MASTER_RCV_DATA, S_MASTER_RCV_STOP, S_MASTER_ACK_RCV_DATA, S_MASTER_NOACK_STOP, S_MASTER_SEND_ADDR_10BIT_LSB, S_MASTER_10BIT_RESTART, } I2C_MASTER_STATES;
/** Section: Macro Definitions */
/* defined for I2C1 */
#ifndef I2C1_CONFIG_TR_QUEUE_LENGTH #define I2C1_CONFIG_TR_QUEUE_LENGTH 1 #endif
#define I2C1_TRANSMIT_REG SSP1BUF // Defines the transmit register used to send data. #define I2C1_RECEIVE_REG SSP1BUF // Defines the receive register used to receive data.
// The following control bits are used in the I2C state machine to manage // the I2C module and determine next states. #define I2C1_WRITE_COLLISION_STATUS_BIT SSP1CON1bits.WCOL // Defines the write collision status bit. #define I2C1_MODE_SELECT_BITS SSP1CON1bits.SSPM // I2C Master Mode control bit. #define I2C1_MASTER_ENABLE_CONTROL_BITS SSP1CON1bits.SSPEN // I2C port enable control bit.
#define I2C1_START_CONDITION_ENABLE_BIT SSP1CON2bits.SEN // I2C START control bit. #define I2C1_REPEAT_START_CONDITION_ENABLE_BIT SSP1CON2bits.RSEN // I2C Repeated START control bit. #define I2C1_RECEIVE_ENABLE_BIT SSP1CON2bits.RCEN // I2C Receive enable control bit. #define I2C1_STOP_CONDITION_ENABLE_BIT SSP1CON2bits.PEN // I2C STOP control bit. #define I2C1_ACKNOWLEDGE_ENABLE_BIT SSP1CON2bits.ACKEN // I2C ACK start control bit. #define I2C1_ACKNOWLEDGE_DATA_BIT SSP1CON2bits.ACKDT // I2C ACK data control bit. #define I2C1_ACKNOWLEDGE_STATUS_BIT SSP1CON2bits.ACKSTAT // I2C ACK status bit.
#define I2C1_7bit true /** Section: Local Functions */
void I2C1_FunctionComplete(void); void I2C1_Stop(I2C1_MESSAGE_STATUS completion_code);
/** Section: Local Variables */
static I2C_TR_QUEUE_ENTRY i2c1_tr_queue[I2C1_CONFIG_TR_QUEUE_LENGTH]; static I2C_OBJECT i2c1_object; static I2C_MASTER_STATES i2c1_state = S_MASTER_IDLE; static uint8_t i2c1_trb_count = 0;
static I2C1_TRANSACTION_REQUEST_BLOCK *p_i2c1_trb_current = NULL; static I2C_TR_QUEUE_ENTRY *p_i2c1_current = NULL;
/** Section: Driver Interface */
void I2C1_Initialize(void) { i2c1_object.pTrHead = i2c1_tr_queue; i2c1_object.pTrTail = i2c1_tr_queue; i2c1_object.trStatus.s.empty = true; i2c1_object.trStatus.s.full = false;
i2c1_object.i2cErrors = 0;
// R_nW write_noTX; P stopbit_notdetected; S startbit_notdetected; BF RCinprocess_TXcomplete; SMP High Speed; UA dontupdate; CKE disabled; D_nA lastbyte_address; SSP1STAT = 0x00; // SSPEN enabled; WCOL no_collision; CKP Idle:Low, Active:High; SSPM FOSC/4_SSPxADD_I2C; SSPOV no_overflow; SSP1CON1 = 0x28; // ACKTIM ackseq; SBCDE disabled; BOEN disabled; SCIE disabled; PCIE disabled; DHEN disabled; SDAHT 100ns; AHEN disabled; SSP1CON3 = 0x00; // Baud Rate Generator Value: SSPADD 3; SSP1ADD = 0x03;
// clear the master interrupt flag PIR1bits.SSP1IF = 0; // enable the master interrupt PIE1bits.SSP1IE = 1; }
uint8_t I2C1_ErrorCountGet(void) { uint8_t ret;
ret = i2c1_object.i2cErrors; return ret; }
void I2C1_ISR ( void ) { static uint8_t *pi2c_buf_ptr; static uint16_t i2c_address = 0; static uint8_t i2c_bytes_left = 0; static uint8_t i2c_10bit_address_restart = 0;
// Check first if there was a collision. // If we have a Write Collision, reset and go to idle state */ if(I2C1_WRITE_COLLISION_STATUS_BIT) { // clear the Write colision I2C1_WRITE_COLLISION_STATUS_BIT = 0; i2c1_state = S_MASTER_IDLE; *(p_i2c1_current->pTrFlag) = I2C1_MESSAGE_FAIL;
// reset the buffer pointer p_i2c1_current = NULL;
return; }
/* Handle the correct i2c state */ switch(i2c1_state) { case S_MASTER_IDLE: /* In reset state, waiting for data to send */
if(i2c1_object.trStatus.s.empty != true) { // grab the item pointed by the head p_i2c1_current = i2c1_object.pTrHead; i2c1_trb_count = i2c1_object.pTrHead->count; p_i2c1_trb_current = i2c1_object.pTrHead->ptrb_list;
i2c1_object.pTrHead++;
// check if the end of the array is reached if(i2c1_object.pTrHead == (i2c1_tr_queue + I2C1_CONFIG_TR_QUEUE_LENGTH)) { // adjust to restart at the beginning of the array i2c1_object.pTrHead = i2c1_tr_queue; }
// since we moved one item to be processed, we know // it is not full, so set the full status to false i2c1_object.trStatus.s.full = false;
// check if the queue is empty if(i2c1_object.pTrHead == i2c1_object.pTrTail) { // it is empty so set the empty status to true i2c1_object.trStatus.s.empty = true; }
// send the start condition I2C1_START_CONDITION_ENABLE_BIT = 1; // start the i2c request i2c1_state = S_MASTER_SEND_ADDR; }
break;
case S_MASTER_RESTART:
/* check for pending i2c Request */
// ... trigger a REPEATED START I2C1_REPEAT_START_CONDITION_ENABLE_BIT = 1;
break;
case S_MASTER_SEND_ADDR_10BIT_LSB:
if(I2C1_ACKNOWLEDGE_STATUS_BIT) { i2c1_object.i2cErrors++; I2C1_Stop(I2C1_MESSAGE_ADDRESS_NO_ACK); } else { // Remove bit 0 as R/W is never sent here I2C1_TRANSMIT_REG = (i2c_address >> 1) & 0x00FF;
// determine the next state, check R/W if(i2c_address & 0x01) { // if this is a read we must repeat start // the bus to perform a read i2c1_state = S_MASTER_10BIT_RESTART; } else { // this is a write continue writing data i2c1_state = S_MASTER_SEND_DATA; } }
break;
case S_MASTER_10BIT_RESTART:
if(I2C1_ACKNOWLEDGE_STATUS_BIT) { i2c1_object.i2cErrors++; I2C1_Stop(I2C1_MESSAGE_ADDRESS_NO_ACK); } else { // ACK Status is good // restart the bus I2C1_REPEAT_START_CONDITION_ENABLE_BIT = 1;
// fudge the address so S_MASTER_SEND_ADDR works correctly // we only do this on a 10-bit address resend i2c_address = 0x00F0 | ((i2c_address >> 8) & 0x0006);
// set the R/W flag i2c_address |= 0x0001;
// set the address restart flag so we do not change the address i2c_10bit_address_restart = 1;
// Resend the address as a read i2c1_state = S_MASTER_SEND_ADDR; }
break;
case S_MASTER_SEND_ADDR:
/* Start has been sent, send the address byte */
/* Note: On a 10-bit address resend (done only during a 10-bit device read), the original i2c_address was modified in S_MASTER_10BIT_RESTART state. So the check if this is a 10-bit address will fail and a normal 7-bit address is sent with the R/W bit set to read. The flag i2c_10bit_address_restart prevents the address to be re-written. */ if(i2c_10bit_address_restart != 1) { // extract the information for this message i2c_address = p_i2c1_trb_current->address; pi2c_buf_ptr = p_i2c1_trb_current->pbuffer; i2c_bytes_left = p_i2c1_trb_current->length; }
// check for 10-bit address if(!I2C1_7bit && (0x0 != i2c_address)) { if (0 == i2c_10bit_address_restart) { // we have a 10 bit address // send bits<9:8> // mask bit 0 as this is always a write I2C1_TRANSMIT_REG = 0xF0 | ((i2c_address >> 8) & 0x0006); i2c1_state = S_MASTER_SEND_ADDR_10BIT_LSB; } else { // resending address bits<9:8> to trigger read I2C1_TRANSMIT_REG = i2c_address; i2c1_state = S_MASTER_ACK_ADDR; // reset the flag so the next access is ok i2c_10bit_address_restart = 0; } } else { // Transmit the address I2C1_TRANSMIT_REG = i2c_address; if(i2c_address & 0x01) { // Next state is to wait for address to be acked i2c1_state = S_MASTER_ACK_ADDR; } else { // Next state is transmit i2c1_state = S_MASTER_SEND_DATA; } } break;
case S_MASTER_SEND_DATA:
// Make sure the previous byte was acknowledged if(I2C1_ACKNOWLEDGE_STATUS_BIT) { // Transmission was not acknowledged i2c1_object.i2cErrors++;
// Reset the Ack flag I2C1_ACKNOWLEDGE_STATUS_BIT = 0;
// Send a stop flag and go back to idle I2C1_Stop(I2C1_DATA_NO_ACK);
} else { // Did we send them all ? if(i2c_bytes_left-- == 0U) { // yup sent them all!
// update the trb pointer p_i2c1_trb_current++;
// are we done with this string of requests? if(--i2c1_trb_count == 0) { I2C1_Stop(I2C1_MESSAGE_COMPLETE); } else { // no!, there are more TRB to be sent. //I2C1_START_CONDITION_ENABLE_BIT = 1;
// In some cases, the slave may require // a restart instead of a start. So use this one // instead. I2C1_REPEAT_START_CONDITION_ENABLE_BIT = 1;
} } else { // Grab the next data to transmit I2C1_TRANSMIT_REG = *pi2c_buf_ptr++; } } break;
case S_MASTER_ACK_ADDR:
/* Make sure the previous byte was acknowledged */ if(I2C1_ACKNOWLEDGE_STATUS_BIT) {
// Send a stop flag and go back to idle I2C1_Stop(I2C1_MESSAGE_ADDRESS_NO_ACK);
// Reset the Ack flag I2C1_ACKNOWLEDGE_STATUS_BIT = 0; } else { I2C1_RECEIVE_ENABLE_BIT = 1; i2c1_state = S_MASTER_ACK_RCV_DATA; } break;
case S_MASTER_RCV_DATA:
/* Acknowledge is completed. Time for more data */
// Next thing is to ack the data i2c1_state = S_MASTER_ACK_RCV_DATA;
// Set up to receive a byte of data I2C1_RECEIVE_ENABLE_BIT = 1;
break;
case S_MASTER_ACK_RCV_DATA:
// Grab the byte of data received and acknowledge it *pi2c_buf_ptr++ = I2C1_RECEIVE_REG;
// Check if we received them all? if(--i2c_bytes_left) {
/* No, there's more to receive */
// No, bit 7 is clear. Data is ok // Set the flag to acknowledge the data I2C1_ACKNOWLEDGE_DATA_BIT = 0;
// Wait for the acknowledge to complete, then get more i2c1_state = S_MASTER_RCV_DATA; } else {
// Yes, it's the last byte. Don't ack it // Flag that we will nak the data I2C1_ACKNOWLEDGE_DATA_BIT = 1;
I2C1_FunctionComplete(); }
// Initiate the acknowledge I2C1_ACKNOWLEDGE_ENABLE_BIT = 1; break;
case S_MASTER_RCV_STOP: case S_MASTER_SEND_STOP:
// Send the stop flag I2C1_Stop(I2C1_MESSAGE_COMPLETE); break;
default:
// This case should not happen, if it does then // terminate the transfer i2c1_object.i2cErrors++; I2C1_Stop(I2C1_LOST_STATE); break;
void I2C1_FunctionComplete(void) {
// are we done with this string of requests? if(--i2c1_trb_count == 0) { i2c1_state = S_MASTER_SEND_STOP; } else { i2c1_state = S_MASTER_RESTART; }
void I2C1_Stop(I2C1_MESSAGE_STATUS completion_code) { // then send a stop I2C1_STOP_CONDITION_ENABLE_BIT = 1;
// make sure the flag pointer is not NULL if (p_i2c1_current->pTrFlag != NULL) { // update the flag with the completion code *(p_i2c1_current->pTrFlag) = completion_code; }
// Done, back to idle i2c1_state = S_MASTER_IDLE; }
void I2C1_MasterWrite( uint8_t *pdata, uint8_t length, uint16_t address, I2C1_MESSAGE_STATUS *pflag) { static I2C1_TRANSACTION_REQUEST_BLOCK trBlock;
// check if there is space in the queue if (i2c1_object.trStatus.s.full != true) { I2C1_MasterWriteTRBBuild(&trBlock, pdata, length, address); I2C1_MasterTRBInsert(1, &trBlock, pflag); } else { *pflag = I2C1_MESSAGE_FAIL; }
void I2C1_MasterRead( uint8_t *pdata, uint8_t length, uint16_t address, I2C1_MESSAGE_STATUS *pflag) { static I2C1_TRANSACTION_REQUEST_BLOCK trBlock;
// check if there is space in the queue if (i2c1_object.trStatus.s.full != true) { I2C1_MasterReadTRBBuild(&trBlock, pdata, length, address); I2C1_MasterTRBInsert(1, &trBlock, pflag); } else { *pflag = I2C1_MESSAGE_FAIL; }
void I2C1_MasterTRBInsert( uint8_t count, I2C1_TRANSACTION_REQUEST_BLOCK *ptrb_list, I2C1_MESSAGE_STATUS *pflag) {
// check if there is space in the queue if (i2c1_object.trStatus.s.full != true) { *pflag = I2C1_MESSAGE_PENDING;
i2c1_object.pTrTail->ptrb_list = ptrb_list; i2c1_object.pTrTail->count = count; i2c1_object.pTrTail->pTrFlag = pflag; i2c1_object.pTrTail++;
// check if the end of the array is reached if (i2c1_object.pTrTail == (i2c1_tr_queue + I2C1_CONFIG_TR_QUEUE_LENGTH)) { // adjust to restart at the beginning of the array i2c1_object.pTrTail = i2c1_tr_queue; }
// since we added one item to be processed, we know // it is not empty, so set the empty status to false i2c1_object.trStatus.s.empty = false;
// check if full if (i2c1_object.pTrHead == i2c1_object.pTrTail) { // it is full, set the full status to true i2c1_object.trStatus.s.full = true; }
// for interrupt based if (*pflag == I2C1_MESSAGE_PENDING) { while(i2c1_state != S_MASTER_IDLE); { // force the task to run since we know that the queue has // something that needs to be sent PIR1bits.SSP1IF = true; } } // block until request is complete
void I2C1_MasterReadTRBBuild( I2C1_TRANSACTION_REQUEST_BLOCK *ptrb, uint8_t *pdata, uint8_t length, uint16_t address) { ptrb->address = address << 1; // make this a read ptrb->address |= 0x01; ptrb->length = length; ptrb->pbuffer = pdata; }
void I2C1_MasterWriteTRBBuild( I2C1_TRANSACTION_REQUEST_BLOCK *ptrb, uint8_t *pdata, uint8_t length, uint16_t address) { ptrb->address = address << 1; ptrb->length = length; ptrb->pbuffer = pdata; }
bool I2C1_MasterQueueIsEmpty(void) { return(i2c1_object.trStatus.s.empty); }
bool I2C1_MasterQueueIsFull(void) { return(i2c1_object.trStatus.s.full); } void I2C1_BusCollisionISR( void ) { // enter bus collision handling code here } /** End of File */
Откъде трябва да прочета стойността на X ?
| Нед Юли 30, 2017 9:22 pm |
stefan63
 Re: I2C малко помощ
Трябва да извикаш I2C1_MasterRead, като в параметрите укажеш от кой адресИ2Ц, колко байта и къде в собствения РАМ да се запишат. После следиш флаг ФФФ, като се изпълни заявката - можеш да си прочетеш от своя си РАМ. За 30 малки пикчета - трябва да изъчиш 30 заявки . Ако имаш много памет - можеш да ги излъчиш накуп към опашката, ако не - излъчваш една и чакаш , после втората и т.н. Примерът ти за слейв е простичък , слейвът не пише данни в мастера
"Това означава ли, че slave ще праща към master - а съдържанието на целия EEPROM буфер? Т.е - да запиша следващата променлива в EEPROM_Buffer[1] и т.н. ?" Слейвът НЕ ПРАЩА, той ги дава - ако мастерът ги поиска . И дава толкова , колкото мастерът поиска. В малкия пик можеш да си пишеш EEPROM_Buffer[0]=x; EEPROM_Buffer[1]=y; EEPROM_Buffer[2]=z;
В I2C1_MasterRead задаваш дължина 3 , като се изпълни - ще имаш X,Y,Z.
Не можах да се ориентирам къде стоят флаговете ФФФ, чети и пробвай.
| Пон Юли 31, 2017 6:53 am |
stefan63
 Re: I2C малко помощ
void I2C1_Initialize(void) е в самото начало;
Викаш void I2C1_MasterRead( uint8_t *pdata, //тук даващ адрес от РАМ , където да дойдат данните uint8_t length, // брой байтове uint16_t address, //адрес на малкия пик I2C1_MESSAGE_STATUS *pflag) //тук даваш адрес на флаг, който ще следиш.
Системата се движи от void I2C1_ISR ( void ) . Значи - когато опашката е празна тази функция не би трябвало да се активира, и като издадеш заявка - би трябвало някак да я извикаш - може би със сетване на PIR1bits.SSP1IF = 1; и оттам нататък - следиш флага на заявката pflag ;
| Пон Юли 31, 2017 7:15 am |
lcr
 Re: I2C малко помощ
Много ти благодаря!  PS: И още един страничен и тъп въпрос: Кое налага ползването на EEPROM памет в тия джаджи, вместо само FLASH ?
| Пон Юли 31, 2017 10:54 am |
radolin
 Re: I2C малко помощ
EEPROM-a има много повече цикли на презапис. Флаш-а също можеш да го триеш само на големи блокове, то и затова се казва така.
| Пон Юли 31, 2017 11:50 am |
lcr
 Re: I2C малко помощ
| Пон Юли 31, 2017 12:12 pm |
lcr
 Re: I2C малко помощ
Още един въпрос:
Предполагам, че когато се получи заявка за четене от master - а, в slave се генерира прекъсване.
Какво се случва в 12F1840 след обслужване на прекъсването? Основният цикъл ще продължи ли от там докъдето е бил стигнал или ще започне отначало?
| Вто Авг 01, 2017 8:05 pm |
stefan63
 Re: I2C малко помощ
Това е идеята, ама реализацията зависи от тебе. На Ц - най вероятно няма да разбереш , че е е имало прекъсване - когто кодът е правилен Иначе -бой , стригане и глад. Тоз малкия пик - с какво ще го дебъгваш? Май мярнах , че може и без адаптер на ПИКИТ3, дано. От толкоз много въпроси - следва , че ще има много за деБъгване. Съвет - Отвори си тема в "Академия" и почни да си публикуваш програмата на малкия пик. Само забележи - няма кой да разлиства 300 реда код - трудно е, разделяй кода в малки файлове и ги качвай като файлове, не ги копиррай като текст в съобщението. Ако имаш достатъчно коментари в кода - ще получиш и достатъчно мнения. Доколкото разбрах - имаш виждане - какво ще прави малкия пик в основния цикъл - ще смята нещо, което ти е ясно. И си работил вече с тоя пик. Но ти е проблем да пратиш резултата към и2ц мастера. Колкото и да ти изглежда тъпо - започни публикуването от скелета на програмата , не от И2Ц особеностите. Тук няма кой да ти открадне идеите...
| Вто Авг 01, 2017 8:27 pm |
stefan63
 Re: I2C малко помощ
Всеки нормален софтуер трябва да се мисли в перспективата 365/7/24 . Трябва да огледаш ерата-документа, да предвидиш някакъв механизъм за ресет на комуник.канал - ако за някако време не се получи здравословен обмен. Принципно - защитата на комуникацията е 50-80 % от работата и кода - и този код се задейства твърде рядко . Колко рядко....божа работа.
| Вто Авг 01, 2017 8:45 pm |
lcr
 Re: I2C малко помощ
Не става въпрос за някакви притеснения. Не си вадя хляба с този занаят и това ми е само хоби. Просто не искам да занимавам аудиторията с банални неща. Честно казано не ми е и много ясно, как да дебъгвам. Пробвах веднъж и нещо се омаза, като закачих програматора към MPLAB. После трябваше да му преинсталирам фърмуера за да го оправя. Пиша, билдвам и ако ме наплюе, си търся грешките. Ако не, дъмпя, тествам и така. Луда работа  В конкретния случай малкият пик мери 2 аналогови величини и ги интегрира по време. Отвреме навреме трябва да си съобщава сметките на началника
| Вто Авг 01, 2017 9:06 pm |
stefan63
 Re: I2C малко помощ
Случват се такива работи. Там- дето ще те наплюе компилатора - е лесно.
| Вто Авг 01, 2017 9:28 pm |
lcr
 Re: I2C малко помощ
Притеснавам се за прекъсванията от I2C, защото в цикъла имам няколко паузи от по няколко минути, които съм реализирал с __delay_(ms) и ако цикълът продължи от неправилното място след прекъсването, става неприятно.
| Вто Авг 01, 2017 9:35 pm |
CarBeta
 Re: I2C малко помощ
Цикълът ще продължи от където е прекъснат, но тия милисекунди вече ще са повече, отколкото са предвидени.
| Вто Авг 01, 2017 9:41 pm |
lcr
 Re: I2C малко помощ
Благодаря! Това не е фатално в конкретния случай.
| Вто Авг 01, 2017 9:43 pm |
