RED чука на вратата
Мнение Re: RED чука на вратата
Ето с какво ни облъчват нашите "лаборанти" (така де, фирмата дето си правим изпитанията).
The new Radio Equipment Directive* (2014/53/EU) has already become effective
as published in the Official Journal (L 153/62) of the European Union, dated 16 April 2014.
The existing R&TTE Directive 1999/5/EC ceases to be applicable as from 13 June 201 7 (Article 49).
A significant change is that this Directive applies to wireless products for radio communication and radio determination only
(Preamble 6) and should not apply to fixed-line terminal equipment (Preamble 4), which are now covered by the new EMC-/LVDDirectives.
Receivers (only) need to ensure the “efficient use of radio spectrum” acc. to this Directive (Preamble 11).
There should only be a single EU Declaration of Conformity (DOC) in respect of all Union acts (Article 18), applicable/required
to ensure conformity with the requirements for CE-marking.
“Simplified DOC” (including Name of manufacturer, model/type and directive 2014/53/EU) can be used to affix it to the packaging
of the radio equipment concerned, with exact internet address to obtain the full text of the DOC. (Preamble 31, Article 9, Article 18
& Annex VII). If possible (size of equipment), postal address, name of manufacturer, model/type and CE marking need to be
shown on the equipment (Article 10). The terms “Class Identifier” (i.e. “alert sign”) and “Expert’s Opinion” described in the existing
R&TTE Directive are no longer mentioned in this new Directive.
Information of the manufacturer (traceability throughout the whole supply chain), the product and the DOC must be in
language easily understood by the destination’s consumers and end-users, as determined by the Member State’s authorities
(Articles 7, 8, 12, 13, 18 & 21).
The essential requirements refer to new Directives: 2014/35/EU (including EMC and safety, but with no voltage limit applying).
The other requirements are detailed in Article 3. Compliance has to be in all possible configurations (Article 17).
New rules on penalties in case of infringements will be effective and dissuasive, and there are many other new and tough
requirements, e.g.
Сря Мар 29, 2017 12:21 pm
Нещо по-конкретно не казват ли, защото това си е преразказ на директивата.
Чет Мар 30, 2017 10:57 am
Ами май трябва да ги питаме.
Те пък едни работни...
Чет Мар 30, 2017 11:30 am
тя цялата директива е чиновническо бръщолевене
шум (11):
Въпреки че самите приемници не причиняват вредни радиосмущения, приемните характеристики се превръщат във все по-важен фактор за гарантиране на ефективното използване на радиочестотния спектър чрез увеличаване на устойчивостта на приемниците спрямо вредни радиосмущения и нежелани сигнали въз основа на съответните съществени изисквания на законодателството на Съюза за хармонизация.
нещо чисълца? дори да приемем, че съществува 'спактрален ефективометър', поне някаква норма да бяха сложили - 80, 90,98 от нещо си.
а предходния член може да се дава за образец, как в едно дълго съставно изречение, в което с 142 думи да не кажеш нищо.
шум (10):
С цел да се гарантира ефективното и да се подпомага ефикасното използване на радиочестотния спектър от радиосъоръженията, те следва да бъдат конструирани така, че в случай на предавател, когато предавателят е правилно инсталиран, поддържан и използван по предназначение, той генерира излъчване на радиовълни, които не причиняват вредни радиосмущения, докато нежеланите излъчвания на радиовълни, генерирани от предавател (например в съседни канали) с потенциално отрицателно въздействие върху целите на политиката в областта на радиочестотния спектър, следва да бъдат ограничени до такова равнище, че съгласно степента на техническите познания да се избягват вредни радиосмущения; и в случай на приемник — той да има такива работни характеристики, които да му позволяват да функционира по предназначение и да го предпазват от риск от вредни радиосмущения, по-специално такива от споделени или съседни канали, и по този начин да подпомагат подобряването на ефективното използване на споделени или съседни канали.
нямаше да е лошо евро-зелките да приложат тези пожелания към собствената си директива - по-ефективано да излгат мислите си без излишен шум в канала (и съседните канали) :D
като цяло:
Член 3
Съществени изисквания
1. Радиосъоръженията се конструират така, че да се гарантира:
а) опазването на здравето и безопасността на хората и на домашните животни и защита на вещите, включително целите по отношение на изискванията за безопасност съгласно Директива 2014/35/ЕС, но без да се прилага ограничение за напрежението;
б) съответно ниво на електромагнитна съвместимост съгласно Директива 2014/30/ЕС.
2. Радиосъоръженията се конструират по такъв начин, че да използват ефективно и същевременно да подпомагат ефикасното използване на радиочестотния спектър, за да бъдат избегнати вредни радиосмущения.
3. Радиосъоръжение, попадащо в определени категории или класове, се конструира по такъв начин, че да е в съответствие със следните съществени изисквания:
а) радиосъоръжението да работи съвместно с принадлежности, по-специално с общи зарядни устройства;
б) радиосъоръжението да работи съвместно чрез мрежи с друго радиосъоръжение;
в) радиосъоръжението да може да бъде свързано с интерфейси от подходящ тип в целия Съюз;
г) радиосъоръжението да не вреди на мрежата или на нейното функциониране, да не използва неправилно мрежови ресурси, като по такъв начин да причинява неприемливо влошаване на услугата;
д) радиосъоръжението да има вградена защита, за да се осигури, че личните данни и неприкосновеността на личния живот на ползвателя и абоната са защитени;
е) радиосъоръжението да притежава определени характеристики, които осигуряват защита от измами;
ж) радиосъоръжението да притежава определени характеристики, които осигуряват достъп до службите за спешно реагиране;
з) радиосъоръжението да притежава определени характеристики с цел да се улесни неговото използване от ползватели с увреждания;
и) радиосъоръжението да притежава определени характеристики с цел да се осигури, че зареждането на софтуер в радиосъоръжението е възможно само когато съответствието на комбинацията на радиосъоръжението и софтуера е доказано.
не виждам как/защо приемника на телфера на балкона ми може да звъни на бърза помощ, да защитава личните ми данни, да е достъпен за инвалиди или дори да ползва общо зарядно?
целта май е наистина да удавят всички, не само дребните. гледаме цирка с дизел-гейт и се молим валяка да не мине и на нашата улица.
Чет Мар 30, 2017 11:45 am
Не е лошо Рек да премести темата в раздела за сертификации, за да не изпадне надолу...
Съб Апр 01, 2017 9:25 am
Тъй, от средата на тая година RED удря с пълна сила. В момента всички сертификации се правят по RED.
За нас вероятно няма да има разлика, щото така и така сме си тествали, но има устройства които преди не са се тествали и сега ще се тестват по EMC.
Предстои да ни внесат малко яснота (надявам се).
Основния проблем е че ще трябва да се пресертифицират (и наново тестват) всички устройства които са в продажба, за да отговарят по RED.
От там иде и другия проблем - лабораториите са претоварени и чаржват на високи цени. Колко, ще разберем съвсем скоро, щото и ние ще трябва да претестваме... Най-тъпото е че имаме СЕ сертификат за съответното устройство, но по старите директиви (или каквото е там), а можеше да бъде по RED (имаше 1 година гратисен период в който се тестваше и по двете директиви).
Да ни са честити новите директиви на ЕС (Еврейския Съюз)...
Универсалните зарядни трябвало да да се оптимизират за намаляване на загубите (WTF?). Че нали има директива за екодизайн, дето обхваща захранващите и захранваните устройства, и има изисквания за консумации и ефективност... Баси бозата.
Сря Ное 01, 2017 7:01 pm
Self assessment не върши ли работа, е, поне за част от дивайсите :wink:
Чет Ное 02, 2017 11:12 am
Потребители разглеждащи този форум: 0 регистрирани и 313 госта
