DGPS - има ли почва у нас?
Мнение DGPS - има ли почва у нас?
Ето това ми даде GPS приемника:
$PGTOP,001,3,0.00,16.84,168*76
$GPGGA,091004.000,4242.0625,N,02319.2432,E,1,5,1.66,556.7,M,36.7,M,,*58
$GPRMC,091004.000,A,4242.0625,N,02319.2432,E,0.43,293.52,280113,,,A*6C
$PGTOP,001,3,0.00,16.81,168*73
$GPGGA,091005.000,4242.0624,N,02319.2432,E,1,5,1.66,556.7,M,36.7,M,,*58
$GPRMC,091005.000,A,4242.0624,N,02319.2432,E,0.37,293.52,280113,,,A*6F
$PGTOP,001,3,0.00,16.79,167*7B
$GPGGA,091006.000,4242.0623,N,02319.2433,E,1,5,1.66,556.7,M,36.7,M,,*5D
$GPRMC,091006.000,A,4242.0623,N,02319.2433,E,0.36,293.52,280113,,,A*6B
$PGTOP,001,3,0.00,16.76,167*74
$GPGGA,091007.000,4242.0622,N,02319.2434,E,1,5,1.66,556.7,M,36.7,M,,*5A
$GPRMC,091007.000,A,4242.0622,N,02319.2434,E,0.39,293.52,280113,,,A*63
$PGTOP,001,3,0.00,16.74,167*76
$GPGGA,091008.000,4242.0619,N,02319.2437,E,2,5,1.66,556.7,M,36.7,M,0000,0000*5D
$GPRMC,091008.000,A,4242.0619,N,02319.2437,E,0.42,293.52,280113,,,D*6E
$GPGGA,091009.000,4242.0614,N,02319.2442,E,2,5,1.66,556.7,M,36.7,M,0000,0000*53
$GPRMC,091009.000,A,4242.0614,N,02319.2442,E,0.47,293.52,280113,,,D*65
$GPGGA,091010.000,4242.0611,N,02319.2444,E,2,5,1.66,556.7,M,36.7,M,0000,0000*58
$GPRMC,091010.000,A,4242.0611,N,02319.2444,E,0.48,293.52,280113,,,D*61
$PGTOP,001,3,0.00,16.85,168*77
$GPGGA,091011.000,4242.0610,N,02319.2443,E,2,5,1.66,556.7,M,36.7,M,0000,0000*5F
$GPRMC,091011.000,A,4242.0610,N,02319.2443,E,0.47,293.52,280113,,,D*69
Даваше го няколко дни, а сега не. И друг път съм виждал флага за диференциална корекция, но няма никаква закономерност. Знам, че в София има наземна станция, ама защо не получавам корекцията редовно?
Допускам, че от офиса не виждам винаги съответните спътници, ама и GPS приемниците, които са на полето на стотици км от София също хващат корекцията от дъжд, та на вятър.
Някой да знае нещо по въпроса?
Нед Фев 24, 2013 8:25 pm
Мнение Re: DGPS - има ли почва у нас?
Съвсем си е редовно. Просто му трябва време да си свали данните. Тия корекции се излъчваха от само 3 спътника от всичките, когато се ровичках. Към тях видимостта не винаги е еднаква, и съответно не винаги приемника ги хваща бързо.
...ама това не е DGPS, а WAAS/EGNOS корекции. DGPS е нещо съвсем друго.
Няма нищо диференциално в това. Корекцията е за намаляване на влиянието на йоносферата въру изкривяването на сигнала от спътниците:
http://www.kowoma.de/en/gps/waas_egnos.htm
Пон Фев 25, 2013 4:35 pm
Ами в дейта шийта на GPS приемника пише:
0 Fix not available
1 GPS fix
2 Differential GPS fix
Е...м, му мамата какво точно се включва, въпросът е, че не е редовно.
Вто Фев 26, 2013 10:58 am
Тъй де - като имаш видимост към спътниците, дето излъчват тия корекции, GPS-а понякога смогва да си ги свали и да коригира по тях. Те са диференциални корекции, щото добавят или изваждат от времето за пътване на сигналите на спътниците, но нямат нищо общо с DGPS.
Примерно, сигнала от някой спътник идва при теб за време t, обаче, понеже се пречупва от йоносферата, фе-факто той не ти отразява разстоянието между теб и спътника по правата линия, а по леко пречупена. Чрез WAAS/EGNOS/диференциалните корекции към времето за пристигане с добавя делта t, така, щото до колкото е възможно да коригира тия неточности в следствие на пречупването.
Ако сложиш на GPS-а хубава антена и я разположиш на хубаво място, корекциите са налични почти постоянно. Аз не помня туристическия ми Garmin Colorado 300 да не е смогвал да си ги свали поне в последните 2 години. Има и друго - вероятно от време на време се актуализират- тогава GPS-а трябва да си ги свали наново. За това също му трябва време и видимост. Ако устройството има asisted GPS, моге да си свали алманака(текущото положение на спътниците и прочие неща) и корекциите по интернет, и тогава сгрява доста по-бързо. Ако приемника поддържа и ГЛОНАСС, точността се подобрява още повече.
При DGPS се ползват няколко антени, няколко устройства, понякога и локална наземна станция и прочие истории, та го докарва до точност примерно 10cm. Ама там говорим за други цели, съвсем друго оборудване и съвсем други цени (не помня, но май не беше безплатен).
Вто Фев 26, 2013 12:26 pm
Аз използвам емебедед GPS модули. Не всички поддържат тези екстри, ако и производителите да се кълнат в това.
Този GPS е вградена и възможност за външна антена. Сложил съм външна, но не винаги или по-точно рядко виждам флага на корекцията. Интересно е, че ID-то на станцията е 0000.
Вто Фев 26, 2013 12:44 pm
