Дата и час: Сря Ное 25, 2026 5:01 am
[ 6 мнения ] |
KAK тая програма разбира колко слоя е платката
am stereo
Регистриран на: Съб Дек 08, 2007 10:51 am Мнения: 1869 Местоположение: ♪♫♣♠|☼◙▲♦▼☻╬☺∞
база данни ли чете Thaiphoon Burner Super Blaster8O  |  |  |  | Код: Manufacturing Description Module Manufacturer: Kingston Module Part Number: KVT8FP-HYC DRAM Manufacturer: Hynix DRAM Components: Not determined Module Manufacturing Date: Week 29, 2012 Module Manufacturing Location: Shanghai, China Module Serial Number: DC258212h Module PCB Revision: B (42h) DRAM Die Revision: B (42h) Physical & Logical Attributes Fundamental Memory Class: DDR3 SDRAM Module Speed Grade: DDR3-1600K Module Type: UDIMM (133,35 mm) Module Capacity: 4096 MB Reference Raw Card: B1 (6 layers) Initial Raw Card Designer: SK hynix Module Nominal Height: 29 < H <= 30 mm Module Thickness Maximum, Front: 1 < T <= 2 mm Module Thickness Maximum, Back: 1 < T <= 2 mm Number of DIMM Ranks: 2 Address Mapping from Edge Connector to DRAM: Mirrored DRAM Device Package: Standard Monolithic DRAM Device Package Type: 78-ball FBGA DRAM Device Die Count: Not specified Signal Loading: Not specified Number of Column Addresses: 10 bits Number of Row Addresses: 15 bits Number of Bank Addresses: 3 bits (8 banks) DRAM Device Width: 8 bits Programmed DRAM Density: 2 Gb Calculated DRAM Density: 2 Gb Number of DRAM components: 16 DRAM Page Size: 1 KB Primary Memory Bus Width: 64 bits Memory Bus Width Extension: 0 bits Supported Voltage Levels: 1.50 V DRAM Timing Parameters Fine Timebase Dividend: 5 Fine Timebase Divisor: 2 Fine Timebase: 0,0025 ns Medium Timebase Dividend: 1 Medium Timebase Divisor: 8 Medium Timebase: 0,125 ns Clock Cycle Time (tCK min): 1,250 ns CAS# Latencies Supported (tCL): 6T, 7T, 8T, 9T, 10T, 11T CAS# Latency Time (tAA min): 13,125 ns RAS# to CAS# Delay Time (tRCD min): 13,125 ns Row Active to Row Active Delay (tRRD min): 6,000 ns Row Precharge Delay Time (tRP min): 13,125 ns Active to Precharge Delay Time (tRAS min): 35,000 ns Act to Act/Refresh Delay Time (tRC min): 48,125 ns Refresh Recovery Delay Time (tRFC min): 160,000 ns Write Recovery Time (tWR min): 15,000 ns Write to Read Command Delay (tWTR min): 7,500 ns Read to Precharge Command Delay (tRTP min): 7,500 ns Four Active Windows Delay (tFAW min): 30,000 ns RZQ / 6 Drive Strength: Supported RZQ / 7 Drive Strength: Supported DLL-Off Mode Support: Supported Thermal Parameters Extended Temperature Range: 0-95 °C Extended Temperature Refresh Rate: 2X (85-95 °C) Auto Self Refresh (depending on temperature): Supported Module Thermal Sensor: Not Incorporated On-die Thermal Sensor Readout: Not supported Partial Array Self Refresh: Not supported SPD Protocol SPD Revision: 1.1 SPD Bytes Total: 256 SPD Bytes Used: 176 SPD Checksum: 199Ch (OK) CRC covers bytes: 0-116 Part number details JEDEC DIMM Label: 4GB 2Rx8 PC3-12800U-11-11-B1 Frequency CAS RCD RP RAS RC RFC RRD WR WTR RTP 800 MHz 11 11 11 28 39 128 5 12 6 6 667 MHz 10 9 9 24 33 107 4 10 5 5 667 MHz 9 9 9 24 33 107 4 10 5 5 533 MHz 8 7 7 19 26 86 4 8 4 4 533 MHz 7 7 7 19 26 86 4 8 4 4 400 MHz 6 6 6 14 20 64 3 6 3 3
_________________ DT-838 ((( STEREO ПОЗДРАВ))) за форума - https://youtu.be/xy921Pn3lhA
Последна промяна am stereo на Вто Яну 31, 2017 4:07 pm, променена общо 1 път
| Вто Яну 31, 2017 3:30 pm |
MYXATA
 Re: KAK тая програма разбира колко слоя е платката
например ... Module PCB Revision: B (42h) ... Reference Raw Card: B1 (6 layers) ...
| Вто Яну 31, 2017 3:34 pm |
am stereo
точно това твоето имам впредвид-референсиите са и в длл или списъче,и налучква,но това 42н е у биоса на паметта нали и как може да има различна дебелина платката отпред и отзад
| Вто Яну 31, 2017 4:13 pm |
MYXATA
ами то сигурно и острани е различна дебелината - това не те ли притеснява
| Вто Яну 31, 2017 6:18 pm |
ike
По всяка вероятност, това е колко стърчи модула памет, отпред и отзад. Има такива дето са по голи bga чипове и те са тънки, а има и огромни радиатори които стърчат във всички посоки.
| Сря Фев 01, 2017 9:43 am |
am stereo
мм,не-виж,че го дават макс 2мм-с радиатор отива на 5;6;7мм....... Module Thickness Maximum, Back: 1 < T <= 2 mm
| Сря Фев 01, 2017 11:32 am |
[ 6 мнения ] |
