Отговори на тема  [ 3905 мнения ]  Отиди на страница Предишна  1 ... 49, 50, 51, 52, 53, 54, 55 ... 261  Следваща
Ами Дедо,
ей сега се глабучкам е едно наше чипче, дето е 0.8мм/3мм с 12 крака(топчета), всяко по 0.17мм само силикон, без корпус
Чет Ное 14, 2013 12:11 am
Microchip обявиха официално PIC32MZ на сайта...
Вто Ное 19, 2013 12:41 am
Н'бабане Гт'муан'га написа:
Разгеле!
В Errata-та какви смешки има, не е истина, обаче. Например:
USB Hi-Speed mode does not function (Device or Host).
Work around:
As an alternative, use Full-Speed mode.
Вто Ное 19, 2013 12:56 am
Явно не си чел много Errata-ти.
http://www.ti.com/lit/er/spmz633h/spmz633h.pdf
If the EEPROM is programmed, both the Flash memory and
EEPROM will be unable to be programmed after a POR
Description:
Due to a factory configuration error, if the EEPROM has been programmed and then a POR is
executed, both the Flash memory and EEPROM will be unable to be programmed. Do not use the
EEPROM on RevB0 devices.
Workaround:
None.
http://processors.wiki.ti.com/index.php ... _Emulation
EEPROM blocks must be accessed in alternate pairs to avoid
corruption of data
Description:
When the words in a pair of EEPROM blocks are repetitively written, the words of the next pair of
blocks get corrupted. In a given group of four blocks of EEPROM, for example, 0, 1, 2 and 3, repeated
writes to either block 0 or block 1 cause the data in blocks 2 and 3 to be corrupted.
Workaround:
The EEPROM should be used only in alternate pairs of blocks 0,1,4,5,8,9, and so on, or 2,3,6,7,10,11,
and so on.
When a 1-kB Flash page is erased, the adjacent page is also erased
Description:
When a 1-kB Flash page is erased, the adjacent page in the even/odd pair is also erased. For
example, if page 0 is erased, then page 1 is also erased. Similarly, if page 1 is erased, then page
0 is also erased.
Workaround:
None.
Вто Ное 19, 2013 3:04 am
Има и бая по-тежки случаи, да.
Вто Ное 19, 2013 9:54 am
Абе аз май съм го пускал тук, ама за мен все още категорично Микрочип държат първенството със следната издънка (пардон фичър):
1. Module: Core
Certain code sequence and placement may cause
the corruption of a few bits in the instruction fetch
when the part is used above 4 MHz. A corrupted
instruction fetch will cause the part to execute an
improper instruction and result in unpredictable
outputs.
Microchip cannot predict which code sequences
and placement will cause this failure. If this failure
mechanism exists in your system, it should be
evident during statistically significant preproduction
testing (minimum suggested sample
size: 100 units) of your particular code sequence
and placement.
Any code changes should be tested in the same
manner prior to their implementation. If most parts
fail your tests, or if failures are seen at all voltages
or at all frequencies, this indicates that the problem
experienced does not relate to this failure
mechanism.
This problem has not been observed at operating
frequencies below 4 MHz.
Work around
Use the part at or below 4 MHz.
Обяснението направо кърти мифки, особенно абзаца как да тестваш дали бъга се проявява и при теб :)
Чипа е 18F6620 и е за 40Mhz по дейта шит :) В последващата ревизия оправиха този бъг и индуцираха нов:
Module: Reset
It has been observed that in certain Reset conditions,
including power-up, the first GOTO instruction
at address 0x0000 may not be executed. This
occurrence is rare and affects very few applications.
To determine if your system is affected, test a
statistically significant number of applications across
the operating temperature, voltage and frequency
ranges of the application. Affected systems will
repeatably fail normal testing. Systems not affected
will continue to not be affected over time.
Work around
Insert a NOP instruction at address 0x0000.
Date Codes that pertain to this issue:
All engineering and production devices.
Обяснението отново кърти мифки - неафектираните системи си оставали неафкетирани. Само дето аз бях от афектираните в отношение 1/1000 ресета, не ме питайте как се хваща тоя бъг (тогава ератата още я нямаше).
Вто Ное 19, 2013 10:00 am
ike написа:
То вярно че не съм чел. Ама смешното е че рекламират чипа грумко като имащ hi-speed USB, а то не работи. :)
Още няколко неща има в errata-та за тотално неработещи модули и други хубавинки:
- I2C трябва да се пуска преди всеки пакет и да се спира след всеки, ако е над 100kHz например.
- Comparator Voltage reference работи наполовина
- SQI модула не работи въобще
- SPI е извън спецификацията си
- RNG не работи
Като изключим последното, другите са основни неща, поне според мен.
Поне най-накрая са сложили адекватно ADC с няколко sample-and-hold модула и добра скорост. Остава и да работи де.
Вто Ное 19, 2013 12:26 pm
Това да не работят цели модули, които иначе гръмко се рекламират като ключови за някое MCU, е съвсем нормална традиция. :(
Повечето бъгове (открити засега) на 32MZ са си направо наследство от 32MX.
Като за тези начални припеци (A0/A1) направо хич не е зле. За модерните ни времена.
Вто Ное 19, 2013 1:29 pm
Ревижъна е A3. :) Вярно че се брои първи, ама явно са борили доста нещица още преди да го пуснат.
PIC32 няма проблeм с I2C и референса на компаратора. Не помня и да съм имал грижи със SPI-то.
Както и да е де. Като излязат някъде в продажба на дребно, така или иначе ще си напазарувам да ги пробвам.
Вто Ное 19, 2013 1:39 pm
На микрочип ревижън системата им е пълна свийнщина. Най - тъпото е, че не я пише на чипа, а пък вътре има едни REV ID полета които се четат само с дебъгера, съдържат някакви кодове, които корепсондират по някакви неведоми алгоритми с буквено цифровата кодировка в дейта шита. Т.е. държейки лентата с чипове по никакъв начин не можеш да разбереш коя ревизия са.
Вто Ное 19, 2013 2:09 pm
Регистриран на: Нед Апр 22, 2012 11:12 pm
MYXATA написа:
Дедо,
то всичко дето се прави за масс продъксшън е на wafer level csp" (за мобилните дивайси и всички малки такива) демек пасивират силикона, слагат топчета и това е.
няма корпуси.
аз съм чувал, че силикона го пасивират в клиниката на доктор Енчев :D
тук вероятно става въпрос за силиций
Вто Ное 19, 2013 7:41 pm
sparkybg написа:
Верно, объркал съм ги с новите 100 MHz-ови PIC32MX вероятно, че и на тях им гледах ератите.
Някои от бъговете са същите като на PIC32MX 1xx/2xx - Watchdog, PMP. Нормално и да има различни. Не е ясно колко екипа мажат периферии. :)
За SPI клока не съм го мислил откъде може да е.
Сря Ное 20, 2013 1:38 pm
тия ТИ що са без надписи по сгради;табели и т.н.
http://goo.gl/maps/zhWOH
Сря Ное 20, 2013 2:34 pm
Гледайте сега колко динамично развиваща се фирма са Майкрочип, чудех се за какви нови микроконтролери на 100MHz говори колегата "woody", а те били решили да ги нарочат за до 100MHz, а до преди месец бяха обявявани за 80 мегахерцови. Като излизаха първите PIC32-ки ги бяха обявили за до 72MHz, после ги качиха до 80. След това тези от серия 1 и 2 ги бяха обявили за 40 мегахерцови, но и те докато започнат да ги продават ги качиха на 50MHz.
Сря Ное 20, 2013 4:49 pm
микрочипестата аризонска мечта ще се разширява - я какво парцелче са си заравнили у задния двор
http://goo.gl/maps/BpLIw
Пет Ное 22, 2013 8:20 am
