Отговори на тема  [ 42 мнения ]  Отиди на страница Предишна  1, 2, 3
Продавам ФРП и следяща с-ма за него
@sthx:
Ето, да видиш и реализацията:
*  This file provides a             *
*  FRP /encoder/ functions for      *
*  _211-06/12 Extended Counter      *
*  16 - Mar - 2007`                 *
*  PIC18F2620 @ 40 MHz              *
*  MikroPascal v6.0.0.2             *
*  rsrachev@gmail.com               *
unit frp_211;
uses definitions_211, counters_file;
const
  FRP_ENABLE         : byte = 0;
  FRP_ENABLED        : byte = 1;
  FRP_DISABLED       : byte = 0;
  //FRP_ONLINE         : byte = 1;
  //FRP_OFFLINE        : byte = 0;
var
  frp_input_A_now, frp_input_A_pre, frp_input_A      : word;  // TIMER3
  frp_input_B_now, frp_input_B_pre, frp_input_B      : word;  // TIMER0
  frp_UP, frp_DOWN                                   : word;  // |A - B|
  in_A_L, in_A_H, in_B_L, in_B_H                     : byte;
  input_divider_UP_counter, input_divider_DOWN_counter               : word;
  FRP_MODULE_ENABLED                                 : byte; register;
implementation
procedure FRP_Init(var frp_port : byte; frp_pin : byte; frp_online : boolean);
var
  ddr_port : ^byte;  //a pointer to TRIS REG
begin
  ddr_port := @frp_port + TRIS_OFFSET;  //Get TRIS address
  ddr_port^.frp_pin := 0;
  if frp_online then
    begin
      //TMR0H := 0; TMR0L := 0;
      //TMR3H := 0; TMR3L := 0;
      frp_input_A_pre := 0;
      frp_input_B_pre := 0;
      input_divider_UP_counter := 1;
      input_divider_DOWN_counter := 1;
      CCP1CON := 0;
      CCPR1H := 0; CCPR1L := 0;
      T0CON := %10101000;
      T3CON := %10000011;  //16 bit mode with sync input!!!
      frp_port.frp_pin := FRP_ENABLED;
      FRP_MODULE_ENABLED := True;
      TMR0H := 0; TMR0L := 0;  //moved here to solve bug 'count at startup'
    end
  else
    begin
      T0CON.TMR0ON := 0;
      T3CON.TMR3ON := 0;
      frp_port.frp_pin := FRP_DISABLED;
      FRP_MODULE_ENABLED := False;
      ddr_port^.frp_pin := 1;
    end;
end;
procedure FRP_Handle;
begin
  if direction_1_value = _FORWARD then  //change count direction
    begin
      in_A_L := TMR3L; in_A_H := TMR3H;
      in_B_L := TMR0L; in_B_H := TMR0H;
    end
  else
    begin
      in_A_L := TMR0L; in_A_H := TMR0H;
      in_B_L := TMR3L; in_B_H := TMR3H;
    end;
  frp_input_A_now := 0;
  frp_input_A_now := (in_A_H shl 8) + in_A_L;
  frp_input_B_now := 0;
  frp_input_B_now := (in_B_H shl 8) + in_B_L;
  frp_UP := frp_input_A_now - frp_input_A_pre;
  frp_DOWN := frp_input_B_now - frp_input_B_pre;
  frp_input_A_pre := frp_input_A_now;
  frp_input_B_pre := frp_input_B_now;
  if frp_DOWN > frp_UP then
    direction_1 := BACKWARD;
  if frp_DOWN < frp_UP then
    direction_1 := _FORWARD;
  while (frp_DOWN >= 1) do
    begin
      Inc(input_divider_DOWN_counter);
      input_divider_UP_counter := input_divider_1_value - input_divider_DOWN_counter + 1;
      if input_divider_DOWN_counter > input_divider_1_value then
        begin
          if prescaler_1_in_use then
            Multiply_Counter_1_On_Dec
          else
            Dec_Counter_1;
        end;
      Dec(frp_DOWN);
    end;
  while (frp_UP >= 1) do
    begin
      Inc(input_divider_UP_counter);
      input_divider_DOWN_counter := input_divider_1_value - input_divider_UP_counter + 1;
      if input_divider_UP_counter > input_divider_1_value then
        begin
            Multiply_Counter_1
          else
            Inc_Counter_1;
        end;
      Dec(frp_UP);
    end;
end;
procedure FRP_Set;
begin
  if MAIN_TASK_Dispatcher = ENCODER_MODE then
    FRP_Init(PORTA, FRP_ENABLE, True)
  else
    FRP_Init(PORTA, FRP_ENABLE, False);
end;
end.
Единствения проблем е, че while-a блокира индикацията, но всичкко останало като граници и изпълнителни механизни си работи.
Нед Окт 24, 2010 12:29 pm
Е, добре. :) . А ако може да се каже отделните части на програмата за колко време се изпълняват, тогава ще се види и максималното бързодействие. Ако всички инструкции в примерът който го дадох по-горе се изпълняват за един процесорен цикъл, то времето за изпълнението им (11 инструкции) е 1.1 микросекунди. Но това е абсолютният минимум.
Нед Окт 24, 2010 7:32 pm
sthx написа:
Ами както знаем, максималното бързодействие на релето е около 50 Hz. За Епик мисля, че им го изкарах около 200 пъти в секунда по RS. Иначе един от тестовете беше със точно същото ФРП. Самото то отказва при около 130 kHz или 3200 RPM.... ако паметта не ме лъже вече.
Нед Окт 24, 2010 8:13 pm
Е, не. Имали въобще смисъл от това? Какво точно ще се мери при 3000RPM и 2500 стъпки на фрп-то? Да приемем че е в металорежеща машина ... 40 об. = 1 см. резолюция 1/10000 мм ?!?!? И представяте ли си как фрезата се движи с 1 см. в секунда 8O . Като постижение за скорост е добре ...
Нед Окт 24, 2010 8:32 pm
Регистриран на: Нед Ное 01, 2009 5:57 pm
Намалям цената на 270 за фрп-то и следящата система.
Чет Ное 04, 2010 8:10 pm
Местоположение: Котел
Е Cekins, 1 см/сек не е нещо кой знае какво. Моята CNC фреза си работи съвсем нормално при тази скорост, разбира се не става дума за работа с твърди метали но например при обработка на стъклотекстолит, гетинакс, МДФ-та а и при преместването до позиция 600мм/мин си е нормална скорост ;)
Пет Ное 05, 2010 12:15 am
Да де, ама според мен движение с такава висока скорост обезсмисля измерване с такава висока прецизност. Би било необходима такава точност ако се прави някаква супер финна матрица - от метал - и искам да видя как фреза ще обработва финно при движение с 1 см. в секунда ... метал ... Малко ще има с един фрезер в секунда. А и ти говориш за такива скорости само в празния ход :)
Пет Ное 05, 2010 4:25 pm
Местоположение: Pz
Cekins написа:
За една истинска металорежеща машина с цпу, тези неща са нещо съвсем нормално.
Cekins написа:
...и искам да видя...
Ако отидеш на правилното място, ще видиш! Щом поставяш така въпроса, значи, че като видиш, ще бъдеш доста изненадан! :partyman:
Пет Ное 05, 2010 7:53 pm
Ето нещо за гледане по въпроса за разхода на фрезери в минута - http://www.youtube.com/watch?v=-gzjw0svMA8
На същото място има доста подобни клипчета...
Пет Ное 05, 2010 11:19 pm
Това не е ли алуминий?
Съб Ное 06, 2010 12:56 am
:arrow: :)
Вто Мар 29, 2011 10:34 pm
Мнение Re: Продавам ФРП и следяща с-ма за него
[quote="stefan_gb"]ФРП 2500 имп.об. 120лв. 1бр.
http://media.snimka.bg/4012/014280293.jpg
http://media.snimka.bg/4012/014280290.jpg
Отчитаща система за ФРП 170 лв. 1бр.
http://media.snimka.bg/4012/014280304.jpg
Съб Мар 31, 2012 11:12 pm
Потребители разглеждащи този форум: Google [Bot] и 9 госта
