Отговори на тема  [ 281 мнения ]  Отиди на страница Предишна  1, 2, 3, 4, 5, 6, 7, 8 ... 19  Следваща
I2C малко помощ
Мнение Re: I2C малко помощ
EEPROM_Buffer[0] =X;
Нед Юли 30, 2017 8:38 pm
stefan63 написа:
Благодаря!
Това означава ли, че slave ще праща към master - а съдържанието на целия EEPROM буфер? Т.е - да запиша следващата променлива в EEPROM_Buffer[1] и т.н. ?
От страна на master - а MCC генерира следната конфигурация:
i2c1.c :
#include "i2c1.h"
  I2C Driver Queue Status Type
  @Summary
    Defines the type used for the transaction queue status.
  @Description
    This defines type used to keep track of the queue status.
typedef union
    struct
            uint8_t full:1;
            uint8_t empty:1;
            uint8_t reserved:6;
    }s;
    uint8_t status;
}I2C_TR_QUEUE_STATUS;
  I2C Driver Queue Entry Type
  @Summary
    Defines the object used for an entry in the i2c queue items.
  @Description
    This defines the object in the i2c queue. Each entry is a composed
    of a list of TRBs, the number of the TRBs and the status of the
    currently processed TRB.
typedef struct
    uint8_t                             count;          // a count of trb's in the trb list
    I2C1_TRANSACTION_REQUEST_BLOCK *ptrb_list;     // pointer to the trb list
    I2C1_MESSAGE_STATUS            *pTrFlag;       // set with the error of the last trb sent.
                                                        // if all trb's are sent successfully,
                                                        // then this is I2C1_MESSAGE_COMPLETE
} I2C_TR_QUEUE_ENTRY;
  I2C Master Driver Object Type
  @Summary
    Defines the object that manages the i2c master.
  @Description
    This defines the object that manages the sending and receiving of
    i2c master transactions.
typedef struct
    /* Read/Write Queue */
    I2C_TR_QUEUE_ENTRY          *pTrTail;       // tail of the queue
    I2C_TR_QUEUE_ENTRY          *pTrHead;       // head of the queue
    I2C_TR_QUEUE_STATUS         trStatus;       // status of the last transaction
    uint8_t                         i2cDoneFlag;    // flag to indicate the current
                                                    // transaction is done
    uint8_t                         i2cErrors;      // keeps track of errors
} I2C_OBJECT ;
  I2C Master Driver State Enumeration
  @Summary
    Defines the different states of the i2c master.
  @Description
    This defines the different states that the i2c master
    used to process transactions on the i2c bus.
typedef enum
    S_MASTER_IDLE,
    S_MASTER_RESTART,
    S_MASTER_SEND_ADDR,
    S_MASTER_SEND_DATA,
    S_MASTER_SEND_STOP,
    S_MASTER_ACK_ADDR,
    S_MASTER_RCV_DATA,
    S_MASTER_RCV_STOP,
    S_MASTER_ACK_RCV_DATA,
    S_MASTER_NOACK_STOP,
    S_MASTER_SEND_ADDR_10BIT_LSB,
    S_MASTER_10BIT_RESTART,
} I2C_MASTER_STATES;
Section: Macro Definitions
/* defined for I2C1 */
#ifndef I2C1_CONFIG_TR_QUEUE_LENGTH
        #define I2C1_CONFIG_TR_QUEUE_LENGTH 1
#endif
#define I2C1_TRANSMIT_REG                       SSP1BUF                 // Defines the transmit register used to send data.
#define I2C1_RECEIVE_REG                        SSP1BUF                 // Defines the receive register used to receive data.
// The following control bits are used in the I2C state machine to manage
// the I2C module and determine next states.
#define I2C1_WRITE_COLLISION_STATUS_BIT         SSP1CON1bits.WCOL     // Defines the write collision status bit.
#define I2C1_MODE_SELECT_BITS                   SSP1CON1bits.SSPM     // I2C Master Mode control bit.
#define I2C1_MASTER_ENABLE_CONTROL_BITS         SSP1CON1bits.SSPEN    // I2C port enable control bit.
#define I2C1_START_CONDITION_ENABLE_BIT         SSP1CON2bits.SEN      // I2C START control bit.
#define I2C1_REPEAT_START_CONDITION_ENABLE_BIT  SSP1CON2bits.RSEN     // I2C Repeated START control bit.
#define I2C1_RECEIVE_ENABLE_BIT                 SSP1CON2bits.RCEN     // I2C Receive enable control bit.
#define I2C1_STOP_CONDITION_ENABLE_BIT          SSP1CON2bits.PEN      // I2C STOP control bit.
#define I2C1_ACKNOWLEDGE_ENABLE_BIT             SSP1CON2bits.ACKEN    // I2C ACK start control bit.
#define I2C1_ACKNOWLEDGE_DATA_BIT               SSP1CON2bits.ACKDT    // I2C ACK data control bit.
#define I2C1_ACKNOWLEDGE_STATUS_BIT             SSP1CON2bits.ACKSTAT  // I2C ACK status bit.
#define I2C1_7bit    true
Section: Local Functions
void I2C1_FunctionComplete(void);
void I2C1_Stop(I2C1_MESSAGE_STATUS completion_code);
Section: Local Variables
static I2C_TR_QUEUE_ENTRY                  i2c1_tr_queue[I2C1_CONFIG_TR_QUEUE_LENGTH];
static I2C_OBJECT                          i2c1_object;
static I2C_MASTER_STATES                   i2c1_state = S_MASTER_IDLE;
static uint8_t                                 i2c1_trb_count = 0;
static I2C1_TRANSACTION_REQUEST_BLOCK       *p_i2c1_trb_current = NULL;
static I2C_TR_QUEUE_ENTRY                  *p_i2c1_current = NULL;
  Section: Driver Interface
void I2C1_Initialize(void)
    i2c1_object.pTrHead = i2c1_tr_queue;
    i2c1_object.pTrTail = i2c1_tr_queue;
    i2c1_object.trStatus.s.empty = true;
    i2c1_object.trStatus.s.full = false;
    i2c1_object.i2cErrors = 0;
    // R_nW write_noTX; P stopbit_notdetected; S startbit_notdetected; BF RCinprocess_TXcomplete; SMP High Speed; UA dontupdate; CKE disabled; D_nA lastbyte_address;
    SSP1STAT = 0x00;
    // SSPEN enabled; WCOL no_collision; CKP Idle:Low, Active:High; SSPM FOSC/4_SSPxADD_I2C; SSPOV no_overflow;
    SSP1CON1 = 0x28;
    // ACKTIM ackseq; SBCDE disabled; BOEN disabled; SCIE disabled; PCIE disabled; DHEN disabled; SDAHT 100ns; AHEN disabled;
    SSP1CON3 = 0x00;
    // Baud Rate Generator Value: SSPADD 3;
    SSP1ADD = 0x03;
    // clear the master interrupt flag
    PIR1bits.SSP1IF = 0;
    // enable the master interrupt
    PIE1bits.SSP1IE = 1;
uint8_t I2C1_ErrorCountGet(void)
    uint8_t ret;
    ret = i2c1_object.i2cErrors;
    return ret;
void I2C1_ISR ( void )
    static uint8_t  *pi2c_buf_ptr;
    static uint16_t i2c_address         = 0;
    static uint8_t  i2c_bytes_left      = 0;
    static uint8_t  i2c_10bit_address_restart = 0;
    // Check first if there was a collision.
    // If we have a Write Collision, reset and go to idle state */
    if(I2C1_WRITE_COLLISION_STATUS_BIT)
        // clear the Write colision
        I2C1_WRITE_COLLISION_STATUS_BIT = 0;
        *(p_i2c1_current->pTrFlag) = I2C1_MESSAGE_FAIL;
        // reset the buffer pointer
        return;
    /* Handle the correct i2c state */
    switch(i2c1_state)
        case S_MASTER_IDLE:    /* In reset state, waiting for data to send */
            if(i2c1_object.trStatus.s.empty != true)
                // grab the item pointed by the head
                p_i2c1_current     = i2c1_object.pTrHead;
                i2c1_trb_count     = i2c1_object.pTrHead->count;
                p_i2c1_trb_current = i2c1_object.pTrHead->ptrb_list;
                i2c1_object.pTrHead++;
                // check if the end of the array is reached
                if(i2c1_object.pTrHead == (i2c1_tr_queue + I2C1_CONFIG_TR_QUEUE_LENGTH))
                    // adjust to restart at the beginning of the array
                // since we moved one item to be processed, we know
                // it is not full, so set the full status to false
                // check if the queue is empty
                if(i2c1_object.pTrHead == i2c1_object.pTrTail)
                    // it is empty so set the empty status to true
                // send the start condition
                I2C1_START_CONDITION_ENABLE_BIT = 1;
                // start the i2c request
                i2c1_state = S_MASTER_SEND_ADDR;
            break;
        case S_MASTER_RESTART:
            /* check for pending i2c Request */
            // ... trigger a REPEATED START
            I2C1_REPEAT_START_CONDITION_ENABLE_BIT = 1;
            break;
        case S_MASTER_SEND_ADDR_10BIT_LSB:
            if(I2C1_ACKNOWLEDGE_STATUS_BIT)
                i2c1_object.i2cErrors++;
                I2C1_Stop(I2C1_MESSAGE_ADDRESS_NO_ACK);
            else
                // Remove bit 0 as R/W is never sent here
                I2C1_TRANSMIT_REG = (i2c_address >> 1) & 0x00FF;
                // determine the next state, check R/W
                if(i2c_address & 0x01)
                    // if this is a read we must repeat start
                    // the bus to perform a read
                    i2c1_state = S_MASTER_10BIT_RESTART;
                else
                    // this is a write continue writing data
                    i2c1_state = S_MASTER_SEND_DATA;
            break;
        case S_MASTER_10BIT_RESTART:
            else
                // ACK Status is good
                // restart the bus
                // fudge the address so S_MASTER_SEND_ADDR works correctly
                // we only do this on a 10-bit address resend
                i2c_address = 0x00F0 | ((i2c_address >> 8) & 0x0006);
                // set the R/W flag
                i2c_address |= 0x0001;
                // set the address restart flag so we do not change the address
                i2c_10bit_address_restart = 1;
                // Resend the address as a read
            break;
        case S_MASTER_SEND_ADDR:
            /* Start has been sent, send the address byte */
            /* Note:
                On a 10-bit address resend (done only during a 10-bit
                device read), the original i2c_address was modified in
                S_MASTER_10BIT_RESTART state. So the check if this is
                a 10-bit address will fail and a normal 7-bit address
                is sent with the R/W bit set to read. The flag
                i2c_10bit_address_restart prevents the  address to
                be re-written.
            if(i2c_10bit_address_restart != 1)
                // extract the information for this message
                i2c_address    = p_i2c1_trb_current->address;
                pi2c_buf_ptr   = p_i2c1_trb_current->pbuffer;
                i2c_bytes_left = p_i2c1_trb_current->length;
            // check for 10-bit address
            if(!I2C1_7bit && (0x0 != i2c_address))
                if (0 == i2c_10bit_address_restart)
                    // we have a 10 bit address
                    // send bits<9:8>
                    // mask bit 0 as this is always a write
                    I2C1_TRANSMIT_REG = 0xF0 | ((i2c_address >> 8) & 0x0006);
                    i2c1_state = S_MASTER_SEND_ADDR_10BIT_LSB;
                else
                    // resending address bits<9:8> to trigger read
                    I2C1_TRANSMIT_REG = i2c_address;
                    i2c1_state = S_MASTER_ACK_ADDR;
                    // reset the flag so the next access is ok
            else
                // Transmit the address
                    // Next state is to wait for address to be acked
                else
                    // Next state is transmit
            break;
        case S_MASTER_SEND_DATA:
            // Make sure the previous byte was acknowledged
                // Transmission was not acknowledged
                // Reset the Ack flag
                I2C1_ACKNOWLEDGE_STATUS_BIT = 0;
                // Send a stop flag and go back to idle
                I2C1_Stop(I2C1_DATA_NO_ACK);
            else
                // Did we send them all ?
                if(i2c_bytes_left-- == 0U)
                    // yup sent them all!
                    // update the trb pointer
                    p_i2c1_trb_current++;
                    // are we done with this string of requests?
                    if(--i2c1_trb_count == 0)
                        I2C1_Stop(I2C1_MESSAGE_COMPLETE);
                    else
                        // no!, there are more TRB to be sent.
                        //I2C1_START_CONDITION_ENABLE_BIT = 1;
                        // In some cases, the slave may require
                        // a restart instead of a start. So use this one
                        // instead.
                else
                    // Grab the next data to transmit
                    I2C1_TRANSMIT_REG = *pi2c_buf_ptr++;
            break;
        case S_MASTER_ACK_ADDR:
            /* Make sure the previous byte was acknowledged */
            else
                I2C1_RECEIVE_ENABLE_BIT = 1;
                i2c1_state = S_MASTER_ACK_RCV_DATA;
            break;
        case S_MASTER_RCV_DATA:
            /* Acknowledge is completed.  Time for more data */
            // Next thing is to ack the data
            // Set up to receive a byte of data
            break;
        case S_MASTER_ACK_RCV_DATA:
            // Grab the byte of data received and acknowledge it
            *pi2c_buf_ptr++ = I2C1_RECEIVE_REG;
            // Check if we received them all?
            if(--i2c_bytes_left)
                /* No, there's more to receive */
                // No, bit 7 is clear.  Data is ok
                // Set the flag to acknowledge the data
                I2C1_ACKNOWLEDGE_DATA_BIT = 0;
                // Wait for the acknowledge to complete, then get more
                i2c1_state = S_MASTER_RCV_DATA;
            else
                // Yes, it's the last byte.  Don't ack it
                // Flag that we will nak the data
                I2C1_ACKNOWLEDGE_DATA_BIT = 1;
                I2C1_FunctionComplete();
            // Initiate the acknowledge
            I2C1_ACKNOWLEDGE_ENABLE_BIT = 1;
            break;
        case S_MASTER_RCV_STOP:
        case S_MASTER_SEND_STOP:
            // Send the stop flag
            break;
        default:
            // This case should not happen, if it does then
            // terminate the transfer
            I2C1_Stop(I2C1_LOST_STATE);
            break;
        i2c1_state = S_MASTER_SEND_STOP;
    else
        i2c1_state = S_MASTER_RESTART;
    // then send a stop
    I2C1_STOP_CONDITION_ENABLE_BIT = 1;
    // make sure the flag pointer is not NULL
    if (p_i2c1_current->pTrFlag != NULL)
        // update the flag with the completion code
        *(p_i2c1_current->pTrFlag) = completion_code;
    // Done, back to idle
void I2C1_MasterWrite(
                                uint8_t *pdata,
                                uint8_t length,
                                uint16_t address,
                                I2C1_MESSAGE_STATUS *pflag)
    static I2C1_TRANSACTION_REQUEST_BLOCK   trBlock;
    // check if there is space in the queue
    if (i2c1_object.trStatus.s.full != true)
        I2C1_MasterWriteTRBBuild(&trBlock, pdata, length, address);
        I2C1_MasterTRBInsert(1, &trBlock, pflag);
    else
        *pflag = I2C1_MESSAGE_FAIL;
void I2C1_MasterRead(
                                uint8_t *pdata,
                                uint8_t length,
                                uint16_t address,
        I2C1_MasterReadTRBBuild(&trBlock, pdata, length, address);
    else
void I2C1_MasterTRBInsert(
                                uint8_t count,
                                I2C1_TRANSACTION_REQUEST_BLOCK *ptrb_list,
        *pflag = I2C1_MESSAGE_PENDING;
        i2c1_object.pTrTail->ptrb_list = ptrb_list;
        i2c1_object.pTrTail->count     = count;
        i2c1_object.pTrTail->pTrFlag   = pflag;
        i2c1_object.pTrTail++;
        if (i2c1_object.pTrTail == (i2c1_tr_queue + I2C1_CONFIG_TR_QUEUE_LENGTH))
        // since we added one item to be processed, we know
        // it is not empty, so set the empty status to false
        i2c1_object.trStatus.s.empty = false;
        // check if full
        if (i2c1_object.pTrHead == i2c1_object.pTrTail)
            // it is full, set the full status to true
            i2c1_object.trStatus.s.full = true;
    else
    // for interrupt based
    if (*pflag == I2C1_MESSAGE_PENDING)
        while(i2c1_state != S_MASTER_IDLE);
            // force the task to run since we know that the queue has
            // something that needs to be sent
            PIR1bits.SSP1IF = true;
    }   // block until request is complete
void I2C1_MasterReadTRBBuild(
                                I2C1_TRANSACTION_REQUEST_BLOCK *ptrb,
                                uint8_t *pdata,
                                uint8_t length,
                                uint16_t address)
    ptrb->address  = address << 1;
    // make this a read
    ptrb->address |= 0x01;
    ptrb->length   = length;
    ptrb->pbuffer  = pdata;
void I2C1_MasterWriteTRBBuild(
                                uint8_t *pdata,
                                uint8_t length,
                                uint16_t address)
bool I2C1_MasterQueueIsEmpty(void)
    return(i2c1_object.trStatus.s.empty);
bool I2C1_MasterQueueIsFull(void)
    return(i2c1_object.trStatus.s.full);
void I2C1_BusCollisionISR( void )
    // enter bus collision handling code here
End of File
Откъде трябва да прочета стойността на X ?
Нед Юли 30, 2017 9:22 pm
Трябва да извикаш I2C1_MasterRead, като в параметрите укажеш от кой адресИ2Ц, колко байта и къде в собствения РАМ да се запишат. После следиш флаг ФФФ, като се изпълни заявката - можеш да си прочетеш от своя си РАМ. За 30 малки пикчета - трябва да изъчиш 30 заявки . Ако имаш много памет - можеш да ги излъчиш накуп към опашката, ако не - излъчваш една и чакаш , после втората и т.н. Примерът ти за слейв е простичък , слейвът не пише данни в мастера
"Това означава ли, че slave ще праща към master - а съдържанието на целия EEPROM буфер? Т.е - да запиша следващата променлива в EEPROM_Buffer[1] и т.н. ?"
Слейвът НЕ ПРАЩА, той ги дава - ако мастерът ги поиска . И дава толкова , колкото мастерът поиска. В малкия пик можеш да си пишеш
EEPROM_Buffer[0]=x;
EEPROM_Buffer[1]=y;
EEPROM_Buffer[2]=z;
В I2C1_MasterRead задаваш дължина 3 , като се изпълни - ще имаш X,Y,Z.
Не можах да се ориентирам къде стоят флаговете ФФФ, чети и пробвай.
Пон Юли 31, 2017 6:53 am
void I2C1_Initialize(void) е в самото начало;
Викаш
uint8_t *pdata, //тук даващ адрес от РАМ , където да дойдат данните
uint8_t length, // брой байтове
uint16_t address, //адрес на малкия пик
I2C1_MESSAGE_STATUS *pflag) //тук даваш адрес на флаг, който ще следиш.
Системата се движи от
void I2C1_ISR ( void ) .
Значи - когато опашката е празна тази функция не би трябвало да се активира,
и като издадеш заявка - би трябвало някак да я извикаш - може би със сетване на
PIR1bits.SSP1IF = 1;
и оттам нататък - следиш флага на заявката pflag ;
Пон Юли 31, 2017 7:15 am
stefan63 написа:
Трябва да извикаш I2C1_MasterRead,......
Много ти благодаря! :)
PS:
И още един страничен и тъп въпрос:
Кое налага ползването на EEPROM памет в тия джаджи, вместо само FLASH ?
Пон Юли 31, 2017 10:54 am
lcr написа:
stefan63 написа:
PS:
EEPROM-a има много повече цикли на презапис. Флаш-а също можеш да го триеш само на големи блокове, то и затова се казва така.
Пон Юли 31, 2017 11:50 am
radolin написа:
:prayer:
Пон Юли 31, 2017 12:12 pm
Още един въпрос:
Предполагам, че когато се получи заявка за четене от master - а, в slave се генерира прекъсване.
Какво се случва в 12F1840 след обслужване на прекъсването? Основният цикъл ще продължи ли от там докъдето е бил стигнал или ще започне отначало?
Вто Авг 01, 2017 8:05 pm
Това е идеята, ама реализацията зависи от тебе.
На Ц - най вероятно няма да разбереш , че е е имало прекъсване - когто кодът е правилен :D
Иначе -бой , стригане и глад.
Тоз малкия пик - с какво ще го дебъгваш? Май мярнах , че може и без адаптер на ПИКИТ3, дано.
От толкоз много въпроси - следва , че ще има много за деБъгване.
Съвет - Отвори си тема в "Академия" и почни да си публикуваш програмата на малкия пик. Само забележи - няма кой да разлиства 300 реда код - трудно е, разделяй кода в малки файлове и ги качвай като файлове, не ги копиррай като текст в съобщението. Ако имаш достатъчно коментари в кода - ще получиш и достатъчно мнения.
Доколкото разбрах - имаш виждане - какво ще прави малкия пик в основния цикъл - ще смята нещо, което ти е ясно.
И си работил вече с тоя пик.
Но ти е проблем да пратиш резултата към и2ц мастера.
Колкото и да ти изглежда тъпо - започни публикуването от скелета на програмата , не от И2Ц особеностите.
Тук няма кой да ти открадне идеите...
Вто Авг 01, 2017 8:27 pm
Всеки нормален софтуер трябва да се мисли в перспективата 365/7/24 .
Трябва да огледаш ерата-документа, да предвидиш някакъв механизъм за ресет на комуник.канал - ако за някако време не се получи здравословен обмен. Принципно - защитата на комуникацията е 50-80 % от работата и кода - и този код се задейства твърде рядко . Колко рядко....божа работа.
Вто Авг 01, 2017 8:45 pm
Не става въпрос за някакви притеснения. Не си вадя хляба с този занаят и това ми е само хоби. Просто не искам да занимавам аудиторията с банални неща.
Честно казано не ми е и много ясно, как да дебъгвам. Пробвах веднъж и нещо се омаза, като закачих програматора към MPLAB. После трябваше да му преинсталирам фърмуера за да го оправя.
Пиша, билдвам и ако ме наплюе, си търся грешките. Ако не, дъмпя, тествам и така. Луда работа :)
В конкретния случай малкият пик мери 2 аналогови величини и ги интегрира по време. Отвреме навреме трябва да си съобщава сметките на началника :)
Вто Авг 01, 2017 9:06 pm
Случват се такива работи.
Там- дето ще те наплюе компилатора - е лесно.
Вто Авг 01, 2017 9:28 pm
Притеснавам се за прекъсванията от I2C, защото в цикъла имам няколко паузи от по няколко минути, които съм реализирал с __delay_(ms) и ако цикълът продължи от неправилното място след прекъсването, става неприятно.
Вто Авг 01, 2017 9:35 pm
Цикълът ще продължи от където е прекъснат, но тия милисекунди вече ще са повече, отколкото са предвидени.
Вто Авг 01, 2017 9:41 pm
CarBeta написа:
Благодаря!
Това не е фатално в конкретния случай.
Вто Авг 01, 2017 9:43 pm
