Дата и час: Сря Ное 25, 2026 12:04 am
[ 14 мнения ] |
asensavov
Регистриран на: Сря Юни 03, 2009 12:00 am Мнения: 22 Местоположение: Шумен
 Помощ за асемблер
Здравейте, опитвам се да подкарам един код за управление на BLDC от ръководство на Microchip. Но MPLAB ми изкарва грешки и не знам дали проблема е в мен или в кода. Ако може някой да пробва да го компилира.  |  |  |  | Код: ;********************************************************************** ; * ; Filename: sensored.asm * ; Date: 11 Feb. 2002 * ; File Version: 1.0 * ; * ; Author: W.R. Brown * ; Company: Microchip Technology Incorporated * ; * ; * ;********************************************************************** ; * ; Files required: p16f877.inc * ; * ; * ; * ;********************************************************************** ; * ; Notes: Sensored brushless motor control Main loop uses 3-bit * ; sensor input as index for drive word output. PWM based on * ; Timer0 controls average motor voltage. PWM level is determined * ; PWM level is determined from ADC reading of potentiometer. * ; * ;********************************************************************** list p=16f877 ; list directive to define processor #include <p16f877.inc> ; processor specific variable definitions __CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _HS_OSC & _WRT_ENABLE_OFF & _LVP_ON & _DEBUG_OFF & _CPD_OFF ;********************************************************************** ;* ;* Define variable storage ;* CBLOCK 0x20 ADC ; PWM threshold is ADC result LastSensor ; last read motor sensor data DriveWord ; six bit motor drive data ENDC
;********************************************************************** ;* ;* Define I/O ;* #define OffMask B'11010101' #define DrivePort PORTC #define DrivePortTris TRISC #define SensorMask B'00000111' #define SensorPort PORTE #define DirectionBit PORTA,1 ;********************************************************************** org 0x000 ; startup vector nop ; required for ICD operation clrf PCLATH ; ensure page bits are cleared goto Initialize ; go to beginning of program ORG 0x004 ; interrupt vector location retfie ; return from interrupt ;********************************************************************** ;* ;* Initialize I/O ports and peripherals ;* Initialize clrf DrivePort ; all drivers off banksel TRISA ; setup I/O clrf DrivePortTris ; set motor drivers as outputs movlw B'00000011' ; A/D on RA0, Direction on RA1, Motor sensors on RE<2:0> movwf TRISA ; ; setup Timer0 movlw B'11010000' ; Timer0: Fosc, 1:2 movwf OPTION_REG ; Setup ADC (bank1) movlw B'00001110' ; ADC left justified, AN0 only movwf ADCON1 banksel ADCON0 ; setup ADC (bank0) movlw B'11000001' ; ADC clock from int RC, AN0, ADC on movwf ADCON0 bsf ADCON0,GO ; start ADC clrf LastSensor ; initialize last sensor reading call Commutate ; determine present motor position clrf ADC ; start speed control threshold at zero until first ADC reading ;********************************************************************** ;* ;* Main control loop ;* Loop call ReadADC ; get the speed control from the ADC incfsz ADC,w ; if ADC is 0xFF we're at full speed - skip timer add goto PWM ; add Timer0 to ADC for PWM movf DriveWord,w ; force on condition goto Drive ; continue PWM
movf ADC,w ; restore ADC reading addwf TMR0,w ; add it to current Timer0 movf DriveWord,w ; restore commutation drive data btfss STATUS,C ; test if ADC + Timer0 resulted in carry andlw OffMask ; no carry - suppress high drivers Drive movwf DrivePort ; enable motor drivers call Commutate ; test for commutation change goto Loop ; repeat loop ReadADC ;********************************************************************** ;* ;* If the ADC is ready then read the speed control potentiometer ;* and start the next reading ;* btfsc ADCON0,NOT_DONE ; is ADC ready? return ; no - return movf ADRESH,w ; get ADC result bsf ADCON0,GO ; restart ADC movwf ADC ; save result in speed control threshold return ; ;********************************************************************** ;* ;* Read the sensor inputs and if a change is sensed then get the ;* corresponding drive word from the drive table ;* Commutate movlw SensorMask ; retain only the sensor bits andwf SensorPort,w ; get sensor data xorwf LastSensor,w ; test if motion sensed btfsc STATUS,Z ; zero if no change return ; no change - back to the PWM loop xorwf LastSensor,f ; replace last sensor data with current btfss DirectionBit ; test direction bit goto FwdCom ; bit is zero - do forward commutation ; reverse commutation movlw HIGH RevTable ; get MS byte of table movwf PCLATH ; prepare for computed GOTO movlw LOW RevTable ; get LS byte of table goto Com2 FwdCom ; forward commutation movlw HIGH FwdTable ; get MS byte of table movwf PCLATH ; prepare for computed GOTO movlw LOW FwdTable ; get LS byte of table Com2 addwf LastSensor,w ; add sensor offset btfsc STATUS,C ; page change in table? incf PCLATH,f ; yes - adjust MS byte call GetDrive ; get drive word from table movwf DriveWord ; save as current drive word return GetDrive movwf PCL
;********************************************************************** ;* ;* The drive tables are built based on the following assumptions: ;* 1) There are six drivers in three pairs of two ;* 2) Each driver pair consists of a high side (+V to motor) and low side (motor to ground) drive ;* 3) A 1 in the drive word will turn the corresponding driver on ;* 4) The three driver pairs correspond to the three motor windings: A, B and C ;* 5) Winding A is driven by bits <1> and <0> where <1> is A's high side drive ;* 6) Winding B is driven by bits <3> and <2> where <3> is B's high side drive ;* 7) Winding C is driven by bits <5> and <4> where <5> is C's high side drive ;* 8) Three sensor bits constitute the address offset to the drive table ;* 9) A sensor bit transitions from a 0 to 1 at the moment that the corresponding ;* winding's high side forward drive begins. ;* 10) Sensor bit <0> corresponds to winding A ;* 11) Sensor bit <1> corresponds to winding B ;* 12) Sensor bit <2> corresponds to winding C ;* FwdTable retlw B'00000000' ; invalid retlw B'00010010' ; phase 6 retlw B'00001001' ; phase 4 retlw B'00011000' ; phase 5 retlw B'00100100' ; phase 2 retlw B'00000110' ; phase 1 retlw B'00100001' ; phase 3 retlw B'00000000' ; invalid RevTable retlw B'00000000' ; invalid retlw B'00100001' ; phase /6 retlw B'00000110' ; phase /4 retlw B'00100100' ; phase /5 retlw B'00011000' ; phase /2 retlw B'00001001' ; phase /1 retlw B'00010010' ; phase /3 retlw B'00000000' ; invalid END ; directive 'end of program' |  |  |  |  |
| Нед Мар 20, 2016 7:26 pm |
timt
 Re: Помощ за асемблер
задай интервали в началото.
| Нед Мар 20, 2016 8:45 pm |
asensavov
Благодаря за помощта. Не съм запознат с този асемблер. Кои интервали трябва да задам ?
| Нед Мар 20, 2016 9:28 pm |
timt
от началото се задава интервал но не е от значение за кода. Имаш си хекса. Имам някой съмнения дали ще работи, кажи после какво си направил.
| Нед Мар 20, 2016 9:38 pm |
asensavov
Симулирах схемата с този .hex в Proteus 8 и ми изкара: "ADC conversion started before 'wait' time has expired following previous conversion or channel change" Този код е за мотори с хол сензори, в ръководството има и код за мотори без сензори. Бих искал да пробвам и него ако не ти е проблем.  |  |  |  | Код: ;********************************************************************** ; * ; Filename: snsrless.asm * ; Date: 14 Jan. 2002 * ; File Version: 1.0 * ; * ; Author: W.R. Brown * ; Company: Microchip Technology Incorporated * ; * ; * ;********************************************************************** ; * ; Files required: p16f877.inc * ; * ; * ; * ;********************************************************************** ; * ; Notes: Sensorless brushless motor control * ; * ; Closed loop 3 phase brushless DC motor control. * ; Two potentiometers control operation. One potentiometer (A0) * ; controls PWM (voltage) and RPM (from table). The other * ; potentiometer (A1) provides a PWM offset to the PWM derived * ; from A0. Phase A motor terminal is connected via voltage * ; divider to A3. This is read while the drive is on during * ; phase 4. The result is the peak applied voltage (Vsupply). * ; A3 is also read while the drive is on at two times during * ; phase 5. The result is the BEMF voltage. The BEMF voltage is * ; read at the quarter (t1) and mid (t2) points of the phase 5 * ; period. BEMF is compared to VSupply/2. If BEMF is above * ; VSupply/2 at t1 and below VSupply/2w at t2 then no speed * ; adjustment is made. If BEMF is high at both t1 and t2 then * ; the speed is reduced. If BEMF is low at t1 and t2 then the * ; speed is increased. * ; * ;********************************************************************** ; list P = PIC16F877 include "p16f877.inc" __CONFIG _CP_OFF & _WRT_ENABLE_OFF & _HS_OSC & _WDT_OFF & _PWRTE_ON & _BODEN_ON ; Acceleration/Deceleration Time = RampRate * 256 * 256 * Timer0Timer0 prescale / Fosc #define AccelDelay D'100' ; determines full range acceleration time #define DecelDelay D'10' ; determines full range deceleration time #define ManThresh 0x3f ; Manual threshold is the PWM potentiomenter ; reading above which RPM is adjusted automatically #define AutoThresh 0x100-ManThresh
OffMask equ B'11010101' ; PWM off kills the high drives Invalid equ B'00000000' ; invalid Phase1 equ B'00100001' ; phase 1 C high, A low Phase2 equ B'00100100' ; phase 2 C high, B low Phase3 equ B'00000110' ; phase 3 A high, B low Phase4 equ B'00010010' ; phase 4 A high, C low Phase5 equ B'00011000' ; phase 5 B high, C low Phase6 equ B'00001001' ; phase 6 B high, A low #define CARRY STATUS,C #define ZERO STATUS,Z #define subwl sublw ;********************************************************************************* ;* ;* Define I/O Ports ;* #define ReadIndicator PORTB,0 ; diagnostic scope trigger for BEMF readings #define DrivePort PORTC ; motor drive and lock status ;********************************************************************************* ;* ;* Define RAM variables ;* CBLOCK 0x20 STATE ; Machine state PWMThresh ; PWM threshold PhaseIndx ; Current motor phase index Drive ; Motor drive word RPMIndex ; RPM Index workspace ADCRPM ; ADC RPM value ADCOffset ; Delta offset to ADC PWM threshold PresetHi ; speed control timer compare MS byte PresetLo ; speed control timer compare LS byte Flags ; general purpose flags Vsupply ; Supply voltage ADC reading DeltaV1 ; Difference between expected and actual BEMF at T/4 DeltaV2 ; Difference between expected and actual BEMF at T/2 CCPSaveH ; Storage for phase time when finding DeltaV CCPSaveL ; Storage for phase time when finding DeltaV CCPT2H ; Workspace for determining T/2 and T/4 CCPT2L ; Workspace for determining T/2 and T/4 RampTimer ; Timer0 post scaler for accel/decel ramp rate xCount ; general purpose counter workspace Status ; relative speed indicator status ENDC
;********************************************************************************* ;* ;* Define Flags ;* #define DriveOnFlag Flags,0 ; Flag for invoking drive disable mask when clear #define AutoRPM Flags,1 ; RPM timer is adjusted automatically ; Flags,3 ; Undefined #define FullOnFlag Flags,4 ; PWM threshold is set to maximum drive #define Tmr0Ovf Flags,5 ; Timer0 overflow flag #define Tmr0Sync Flags,6 ; Second Timer0 overflow flag ; Flags,7 ; undefined #define BEMF1Low DeltaV1,7 ; BEMF1 is low if DeltaV1 is negative #define BEMF2Low DeltaV2,7 ; BEMF2 is low if DeltaV2 is negative ;********************************************************************************* ;* ;* Define State machine states and index numbers ;* sRPMSetup equ D'0' ; Wait for Phase1, Set ADC GO, RA1->ADC sRPMRead equ sRPMSetup+1 ; Wait for ADC nDONE, Read ADC->RPM sOffsetSetup equ sRPMRead+1 ; Wait for Phase2, Set ADC GO, RA3->ADC sOffsetRead equ sOffsetSetup+1 ; Wait for ADC nDONE, Read ADC->ADCOffset sVSetup equ sOffsetRead+1 ; Wait for Phase4, Drive On, wait 9 uSec, Set ADC GO sVIdle equ sVSetup+1 ; Wait for Drive On, wait Tacq, set ADC GO sVRead equ sVIdle+1 ; Wait for ADC nDONE, Read ADC->Vsupply sBEMFSetup equ sVRead+1 ; Wait for Phase5, set Timer1 compare to half phase time sBEMFIdle equ sBEMFSetup+1 ; Wait for Timer1 compare, Force Drive on and wait 9 uSec, ; Set ADC GO, RA0->ADC sBEMFRead equ sBEMFIdle+1 ; Wait for ADC nDONE, Read ADC->Vbemf sBEMF2Idle equ sBEMFRead+1 ; Wait for Timer1 compare, Force Drive on and wait 9 uSec, ; Set ADC GO, RA0->ADC sBEMF2Read equ sBEMF2Idle+1 ; Wait for ADC nDONE, Read ADC->Vbemf ;********************************************************************************* ;* ;* The ADC input is changed depending on the STATE ;* Each STATE assumes a previous input selection and changes the selection ;* by XORing the control register with the appropriate ADC input change mask ;* defined here: ;* ADC0to1 equ B'00001000' ; changes ADCON0<5:3> from 000 to 001 ADC1to3 equ B'00010000' ; changes ADCON0<5:3> from 001 to 011 ADC3to0 equ B'00011000' ; changes ADCON0<5:3> from 011 to 000 ;********************************************************************************* ;**************************** PROGRAM STARTS HERE ******************************** ;********************************************************************************* org 0x000 nop goto Initialize org 0x004 bsf Tmr0Ovf ; Timer0 overflow flag used by accel/decel timer bsf Tmr0Sync ; Timer0 overflow flag used to synchronize code execution bcf INTCON,T0IF retfie ; Initialize clrf PORTC ; all drivers off clrf PORTB
banksel TRISA ; setup I/O clrf TRISC ; motor drivers on PORTC movlw B'00001011' ; A/D on RA0 (PWM), RA1 (Speed) and RA3 (BEMF) movwf TRISA ; movlw B'11111110' ; RB0 is locked indicator movwf TRISB ; setup Timer0 movlw B'11010000' ; Timer0: Fosc, 1:2 movwf OPTION_REG bsf INTCON,T0IE ; enable Timer0 interrupts ; Setup ADC movlw B'00000100' ; ADC left justified, AN0, AN1 movwf ADCON1 banksel PORTA movlw B'10000001' ; ADC clk = Fosc/32, AN0, ADC on movwf ADCON0 ; setup Timer 1 movlw B'00100001' ; 1:4 prescale, internal clock, timer on movwf T1CON ; setup Timer 1 compare movlw 0xFF ; set compare to maximum count movwf CCPR1L ; LS compare register movwf CCPR1H ; MS compare register movlw B'00001011' ; Timer 1 compare mode, special event - clears timer1 movwf CCP1CON ; initialize RAM clrf PWMThresh movlw D'6' movwf PhaseIndx clrf Flags clrf Status ; clrf STATE ; LoopIdle->STATE bcf INTCON,T0IF ; ensure Timer0 overflow flag is cleared bsf INTCON,GIE ; enable interrupts MainLoop ;***************************************************************** ; ; PWM, Commutation, State machine loop ; ;***************************************************************** btfsc PIR1,CCP1IF ; time for phase change? call Commutate ; yes - change motor drive PWM bsf DriveOnFlag ; pre-set flag btfsc FullOnFlag ; is PWM level at maximum? goto PWM02 ; yes - only commutation is necessary movf PWMThresh,w ; get PWM threshold addwf TMR0,w ; compare to Timer0 btfss CARRY ; drive is on if carry is set bcf DriveOnFlag ; timer has not reached threshold, disable drive call DriveMotor ; output drive word PWM02 call LockTest call StateMachine ; service state machine goto MainLoop ; repeat loop
StateMachine movlw SMTableEnd-SMTable-1 ; STATE table must have 2^n entries andwf STATE,f ; limit STATE index to state table movlw high SMTable ; get high byte of table address movwf PCLATH ; prepare for computed goto movlw low SMTable ; get low byte of table address addwf STATE,w ; add STATE index to table root btfsc CARRY ; test for page change in table incf PCLATH,f ; page change adjust movwf PCL ; jump into table SMTable ; number of STATE table entries MUST be evenly divisible by 2 goto RPMSetup ; Wait for Phase1, Set ADC GO, RA1->ADC, clear Timer0 overflow goto RPMRead ; Wait for ADC nDONE, Read ADC->RPM goto OffsetSetup ; Wait for Phase2, Set ADC GO, RA3->ADC goto OffsetRead ; Wait for ADC nDONE, Read ADC->ADCOffset goto VSetup ; Wait for Phase4 goto VIdle ; Wait for Drive On, wait Tacq, set ADC GO goto VRead ; Wait for ADC nDONE, Read ADC->Vsupply goto BEMFSetup ; Wait for Phase5, set Timer1 compare to half phase time goto BEMFIdle ; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0->ADC goto BEMFRead ; Wait for ADC nDONE, Read ADC->Vbemf goto BEMF2Idle ; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0->ADC goto BEMF2Read ; Wait for ADC nDONE, Read ADC->Vbemf ; fill out table with InvalidStates to make number of table entries evenly divisible by 2 goto InvalidState ; invalid state - reset state machine goto InvalidState ; invalid state - reset state machine goto InvalidState ; invalid state - reset state machine goto InvalidState ; invalid state - reset state machine SMTableEnd ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ RPMSetup ; Wait for Phase1, Set ADC GO, RA1->ADC, clear Timer0 overflow movlw Phase1 ; compare Phase1 word... xorwf Drive,w ; ...with current drive word btfss ZERO ; ZERO if equal return ; not Phase1 - remain in current STATE bsf ADCON0,GO ; start ADC movlw ADC0to1 ; prepare to change ADC input xorwf ADCON0,f ; change from AN0 to AN1 incf STATE,f ; next STATE bcf Tmr0Sync ; clear Timer0 overflow return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ RPMRead ; Wait for ADC nDONE, Read ADC->RPM btfsc ADCON0,GO ; is ADC conversion finished? return ; no - remain in current STATE movf ADRESH,w ; get ADC result movwf ADCRPM ; save in RPM incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
OffsetSetup ; Wait for Phase2, Set ADC GO, RA3->ADC movlw Phase2 ; compare Phase2 word... xorwf Drive,w ; ...with current drive word btfss ZERO ; ZERO if equal return ; not Phase2 - remain in current STATE bsf ADCON0,GO ; start ADC movlw ADC1to3 ; prepare to change ADC input xorwf ADCON0,f ; change from AN1 to AN3 incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ OffsetRead ; Wait for ADC nDONE, Read ADC->ADCOffset btfsc ADCON0,GO ; is ADC conversion finished? return ; no - remain in current STATE movf ADRESH,w ; get ADC result xorlw H'80' ; complement MSB for +/- offset movwf ADCOffset ; save in offset addwf ADCRPM,w ; add offset to PWM result btfss ADCOffset,7 ; is offset a negative number? goto OverflowTest ; no - test for overflow btfss CARRY ; underflow? andlw H'00' ; yes - force minimum goto Threshold ; OverflowTest btfsc CARRY ; overflow? movlw H'ff' ; yes - force maximum Threshold movwf PWMThresh ; PWM threshold is RPM result plus offset btfsc ZERO ; is drive off? goto DriveOff ; yes - skip voltage measurements bcf FullOnFlag ; pre-clear flag in preparation of compare sublw 0xFD ; full on threshold btfss CARRY ; CY = 0 if PWMThresh > FullOn bsf FullOnFlag ; set full on flag incf STATE,f ; next STATE return ; back to Main Loop DriveOff clrf Status ; clear speed indicators movlw B'11000111' ; reset ADC input to AN0 andwf ADCON0,f ; clrf STATE ; reset state machine return ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ VSetup ; Wait for Phase4 movlw Phase4 ; compare Phase4 word... xorwf Drive,w ; ...with current Phase drive word btfss ZERO ; ZERO if equal return ; not Phase4 - remain in current STATE call SetTimer ; set timer value from RPM table incf STATE,f ; next STATE return ; back to Main Loop
;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ VIdle ; Wait for Drive On, wait Tacq, set ADC GO btfss DriveOnFlag ; is Drive active? return ; no - remain in current STATE call Tacq ; motor Drive is active - wait ADC Tacq time bsf ADCON0,GO ; start ADC incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ VRead ; Wait for ADC nDONE, Read ADC->Vsupply btfsc ADCON0,GO ; is ADC conversion finished? return ; no - remain in current STATE movf ADRESH,w ; get ADC result movwf Vsupply ; save as supply voltage incf STATE,f ; next STATE bcf Tmr0Sync ; clear Timer0 overflow return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BEMFSetup ; Wait for Phase5, set Timer1 compare to half phase time movlw Phase5 ; compare Phase5 word... xorwf Drive,w ; ...with current drive word btfss ZERO ; ZERO if equal return ; not Phase5 - remain in current STATE btfss Tmr0Sync ; synchronize with Timer0 return ; btfss PWMThresh,7 ; if PWMThresh > 0x80 then ON is longer than OFF goto BEMFS1 ; OFF is longer and motor is currently off - compute now btfss DriveOnFlag ; ON is longer - wait for drive cycle to start return ; not started - wait BEMFS1 bcf CCP1CON,0 ; disable special event on compare movf CCPR1H,w ; save current capture compare state movwf CCPSaveH ; movwf CCPT2H ; save copy in workspace movf CCPR1L,w ; low byte movwf CCPSaveL ; save movwf CCPT2L ; and save copy bcf CARRY ; pre-clear carry for rotate rrf CCPT2H,f ; divide phase time by 2 rrf CCPT2L,f ; bcf CARRY ; pre-clear carry rrf CCPT2H,w ; divide phase time by another 2 movwf CCPR1H ; first BEMF reading at phase T/4 rrf CCPT2L,w ; movwf CCPR1L ; incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
BEMFIdle ; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0- >ADC btfss PIR1,CCP1IF ; timer compare? return ; no - remain in current STATE bsf DriveOnFlag ; force drive on for BEMF reading call DriveMotor ; activate motor drive bsf ReadIndicator ; Diagnostic call Tacq ; wait ADC acquisition time bsf ADCON0,GO ; start ADC bcf ReadIndicator ; Diagnostic ; setup to capture BEMF at phase 3/4 T movf CCPT2H,w addwf CCPR1H,f ; next compare at phase 3/4 T movf CCPT2L,w ; addwf CCPR1L,f ; set T/2 lsb btfsc CARRY ; test for carry into MSb incf CCPR1H,f ; perform carry bcf PIR1,CCP1IF ; clear timer compare interrupt flag incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BEMFRead ; Wait for ADC nDONE, Read ADC->Vbemf btfsc ADCON0,GO ; is ADC conversion finished? return ; no - remain in current STATE rrf Vsupply,w ; divide supply voltage by 2 subwf ADRESH,w ; Vbemf - Vsupply/2 movwf DeltaV1 ; save error voltage incf STATE,f ; next STATE return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BEMF2Idle ; When Timer1 compares force Drive on, Set ADC GO after Tacq, RA0- >ADC btfss PIR1,CCP1IF ; timer compare? return ; no - remain in current STATE bsf DriveOnFlag ; force drive on for BEMF reading call DriveMotor ; activate motor drive bsf ReadIndicator ; Diagnostic call Tacq ; wait ADC acquisition time bsf ADCON0,GO ; start ADC bcf ReadIndicator ; Diagnostic movlw ADC3to0 ; prepare to change ADC input xorwf ADCON0,f ; change from AN3 to AN0 ; restore Timer1 phase time and special event compare mode movf CCPSaveH,w movwf CCPR1H ; next compare at phase T movf CCPSaveL,w ; movwf CCPR1L ; set T lsb bcf PIR1,CCP1IF ; clear timer compare interrupt flag bsf CCP1CON,0 ; enable special event on compare incf STATE,f ; next STATE return ; back to Main Loop
;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ BEMF2Read ; Wait for ADC nDONE, Read ADC->Vbemf btfsc ADCON0,GO ; is ADC conversion finished? return ; no - remain in current STATE rrf Vsupply,w ; divide supply voltage by 2 subwf ADRESH,w ; Vbemf - Vsupply/2 movwf DeltaV2 ; save error voltage clrf STATE ; reset state machine to beginning return ; back to Main Loop ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ InvalidState ; trap for invalid STATE index movlw B'11000111' ; reset ADC input to AN0 andwf ADCON0,f ; clrf STATE return ;________________________________________________________________________________________________ Tacq ;***************************************************************** ; ; Software delay for ADC acquisition time ; Delay time = Tosc*(3+3*xCount) ; ;***************************************************************** movlw D'14 ; 14 equates to approx 9 uSec delay movwf xCount ; decfsz xCount,f ; goto $-1 ; loop here until time complete return LockTest ;***************************************************************** ; ; T is the commutation phase period. Back EMF is measured on the ; floating motor terminal at two times during T to determine ; the approximate zero crossing of the BEMF. BEMF low means that ; the measured BEMF is below (supply voltage)/2. ; If BEMF is low at 1/4 T then accelerate. ; If BEMF is high at 1/4 T and low at 3/4 T then speed is OK. ; If BEMF is high at 1/4 T and 3/4 T then decelerate. ; ; Lock test computation is synchronized to the PWM clock such ; that the computation is performed during the PWM ON or OFF ; time whichever is longer. ; ;***************************************************************** ; synchronize test with start of Timer0 btfss Tmr0Ovf ; has Timer0 wrapped around? return ; no - skip lock test btfss PWMThresh,7 ; if PWMThresh > 0x80 then ON is longer than OFF goto LT05 ; OFF is longer and motor is currently off - compute now btfss DriveOnFlag ; ON is longer - wait for drive cycle to start return ; not started - wait
LT05 bcf Tmr0Ovf ; clear synchronization flag decfsz RampTimer,f ; RampTimer controls the acceleration/deceleration rate return ; use lock results to control RPM only if not manual mode bsf AutoRPM ; preset flag movf ADCRPM,w ; compare RPM potentiometer... addlw AutoThresh ; ...to the auto control threshold btfss CARRY ; CARRY is set if RPM is > auto threshold bcf AutoRPM ; not in auto range - reset flag btfss BEMF1Low ; is first BEMF below Supply/2 goto LT20 ; no - test second BEMF LT10 ; accelerate if BEMF at 1/4 T is below Supply/2 movlw B'10000000' ; indicate lock test results movwf Status ; status is OR'd with drive word later movlw AccelDelay ; set the timer for acceleration delay movwf RampTimer ; btfss AutoRPM ; is RPM in auto range? goto ManControl ; no - skip RPM adjustment incfsz RPMIndex,f ; increment the RPM table index return ; return if Index didn't wrap around decf RPMIndex,f ; top limit is 0xFF return LT20 btfsc BEMF2Low ; BEMF1 was high... goto ShowLocked ; ... and BEMF2 is low - show locked ; decelerate if BEMF at 3/4 T is above Supply/2 movlw B'01000000' ; indicate lock test results movwf Status ; status is OR'd with drive word later movlw DecelDelay ; set the timer for deceleration delay movwf RampTimer ; btfss AutoRPM ; is RPM in auto range? goto ManControl ; no - skip RPM adjustment decfsz RPMIndex,f ; set next lower RPM table index return ; return if index didn't wrap around incf RPMIndex,f ; bottom limit is 0x01 return ShowLocked movlw B'11000000' ; indicate lock test results movwf Status ; status is OR'd with drive word later movlw DecelDelay ; set the timer for deceleration delay movwf RampTimer ; btfsc AutoRPM ; was RPM set automatically? return ; yes - we're done
ManControl movf ADCRPM,w ; get RPM potentiometer reading... movwf RPMIndex ; ...and set table index directly return Commutate ;***************************************************************** ; ; Commutation is triggered by PIR1<CCP1IF> flag. ; This flag is set when timer1 equals the compare register. ; When BEMF measurement is active the compare time is not ; cleared automatically (special event trigger is off). ; Ignore the PIR1<CCP1IF> flag when special trigger is off ; because the flag is for BEMF measurement. ; If BEMF measurement is not active then decrement phase table ; index and get the drive word from the table. Save the ; drive word in a global variable and output to motor drivers. ; ;***************************************************************** btfss CCP1CON,0 ; is special event on compare enabled? return ; no - this is a BEMF measurement, let state machine handle this bcf PIR1,CCP1IF ; clear interrupt flag movlw high OnTable ; set upper program counter bits movwf PCLATH decfsz PhaseIndx,w ; decrement to next phase goto $+2 ; skip reset if not zero movlw D'6' ; phase counts 6 to 1 movwf PhaseIndx ; save the phase index addlw LOW OnTable btfsc CARRY ; test for possible page boundary incf PCLATH,f ; page boundary adjust call GetDrive movwf Drive ; save motor drive word DriveMotor movf Drive,w ; restore motor drive word btfss DriveOnFlag ; test drive enable flag andlw OffMask ; kill high drive if PWM is off iorwf Status,w ; show speed indicators movwf DrivePort ; output to motor drivers return GetDrive movwf PCL ; computed goto OnTable retlw Invalid retlw Phase6 retlw Phase5 retlw Phase4 retlw Phase3 retlw Phase2 retlw Phase1 retlw Invalid SetTimer
;***************************************************************** ; ; This sets the CCP module compare registers for timer 1. ; The motor phase period is the time it takes timer 1 ; to count from 0 to the compare value. The CCP module ; is configured to clear timer 1 when the compare occurs. ; Get the timer1 compare variable from two lookup tables, one ; for the compare high byte and the other for the low byte. ; ;***************************************************************** call SetTimerHigh movwf CCPR1H ; Timer1 High byte preset call SetTimerLow movwf CCPR1L ; Timer1 Low byte preset return SetTimerHigh movlw high T1HighTable ; lookup preset values movwf PCLATH ; high bytes first movlw low T1HighTable ; addwf RPMIndex,w ; add table index btfsc STATUS,C ; test for table page crossing incf PCLATH,f ; movwf PCL ; lookup - result returned in W SetTimerLow movlw high T1LowTable ; repeat for lower byte movwf PCLATH ; movlw low T1LowTable ; addwf RPMIndex,w ; add table index btfsc STATUS,C ; test for table page crossing incf PCLATH,f ; movwf PCL ; lookup - result returned in W #include "BLDCspd4.inc" end |  |  |  |  |
| Нед Мар 20, 2016 9:48 pm |
asensavov
В кода се изисква BLDCSpd4.inc Садържанието му е :
| Нед Мар 20, 2016 9:50 pm |
timt
Това ти е другото
| Нед Мар 20, 2016 10:29 pm |
asensavov
Благодаря. Утре вечер ще го изпробвам и ще пиша какво е станало.
| Нед Мар 20, 2016 11:04 pm |
asensavov
В голям филм влязох с този проект за безчетков мотор. Сорс кодовете които колегата timt компилира са от ръководство AN857B. Протеуса си забива грешки и не работи симулацията. После си викам да пробвамвам друга схема и попаднах на това - http://elecnote.blogspot.bg/2015/02/cd-rom-brushless-dc-motor-control.html компилирам си кода, правя схемата и пак не иска.... Възможно ли е протеуса да не работи добре? Версията е 8-ма SP0. Тъй като съм упорит и не се отказвам си изтеглих ръководство AN957 с dsPIC30F2010, изтеглих си и MikroC PRO for dsPIC и при компилация ми дава грешки, а кода го копирам директно ......  |  |  |  | Код: //--------------------------------------------------------------------------------- // Software License Agreement // // The software supplied herewith by Microchip Technology Incorporated // (the “Company”) is intended and supplied to you, the Company’s customer, // for use solely and exclusively with products manufacture by the Company. // The software is owned by the Company and/or its supplier, and is protected under // applicable copyright laws. All rights are reserved. Any use in violation of the // foregoing restrictions may subject the user to criminal sanctions under applicable // laws, as well as to civil liability for the breach of the terms and conditions of // this icense. // // THIS SOFTWARE IS PROVIDED IN AN “AS IS” CONDITION. NO WARRANTIES, WHETHER EXPRESS, // IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF // MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. // THE COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR // CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER. //--------------------------------------------------------------------------------- // File: ClosedLoopSenBLDC.c // // Written By:Stan D'Souza, Microchip Technology // // The following files should be included in the MPLAB project: // // ClosedLoopSenBLDC.c-- Main source code file // p30f2010.gld-- Linker script file // //--------------------------------------------------------------------- // Revision History // // 10/01/04 -- first version //--------------------------------------------------------------------- //*************************************************************************** ClosedLoopSenBLDC.c is a sensored Closed Loop Control for a BLDC motor. The task consists of the following: Sense changes in the Hall Sensors connected to CN5,6 & 7 (PortB) During the CNInterrupt, read the sensors input by reading PortB Mask and determine the state of the position 1, 2, ... 6. Use the StateLoTable and the lookup table provided to determine the Overload Control Register value. Set the OVDCON to this value. The PWM is initialized to generate independant continuous PWMs. The value of the Pot REF is used to determine the demand or desired speed of the Motor. The desired speed value is then used with the actual speed value to determine the Proportional Speed Error and the Integral Speed Error. With these two values the new DutyCycle is determined as: NewDutyCycle = Kp*(Portportional Speed Error) + Ki*(Integral Speed Error) All 3 PWM Duty cycles are then loaded with the NewDutyCycloe 10-bit value. The FPWM = 16000hz The ADC is setup for a PWM trigger to start the conversion ********************************************************************************/
#define __dsPIC30F2010__ #include "c:\pic30_tools\support\h\p30F2010.h" #define FCY 10000000// xtal = 5.0Mhz; PLLx8 #define MILLISEC FCY/10000// 1 mSec delay constant #define FPWM 16000 #define Ksp1200 #define Ksi10 #define RPMConstant60*(FCY/256) #define S2!PORTCbits.RC14 void InitTMR3(void); void InitADC10(void); void AverageADC(void); void DelayNmSec(unsigned int N); void InitMCPWM(void); void CalculateDC(void); void GetSpeed(void); struct { unsigned RunMotor : 1; unsigned Minus : 1; unsigned unused : 14; } Flags; unsigned int HallValue; int Speed; unsigned int Timer3; unsigned char Count; unsigned char SpeedCount; int DesiredSpeed; int ActualSpeed; int SpeedError; int DutyCycle; int SpeedIntegral; //************************************************************* Low side driver table is as below. In this StateLoTable, the Low side driver is PWM while the high side driver is either on or off. This table is used in this exercise *************************************************************/ unsigned int StateLoTable[] = {0x0000, 0x1002, 0x0420, 0x0402, 0x0108, 0x1008, 0x0120, 0x0000}; /**************************************************************** Interrupt vector for Change Notification CN5, 6 and 7 is as below. When a Hall sensor changes states, an interrupt will be caused which will vector to the routine below. The user has to then read the PORTB, mask bits 3, 4 and 5, shift and adjust the value to read as 1, 2 ... 6. This value is then used as an offset in the lookup table StateLoTable to determine the value loaded in the OCDCON register *****************************************************************/
void _ISR _CNInterrupt(void) { IFS0bits.CNIF = 0; // clear flag HallValue = PORTB & 0x0038; // mask RB3,4 & 5 HallValue = HallValue >> 3; // shift right 3 times OVDCON = StateLoTable[HallValue];// Load the overide control register } /********************************************************************* The ADC interrupt loads the DesiredSpeed variable with the demand pot value. This is then used to determing the Speed error. When the motor is not running, the PDC values use the direct Demand value from the pot. *********************************************************************/ void _ISR _ADCInterrupt(void) { IFS0bits.ADIF = 0; DesiredSpeed = ADCBUF0; if (!Flags.RunMotor) { PDC1 = ADCBUF0; // get value ... PDC2 = PDC1; // and load all three PWMs ... PDC3 = PDC1; // duty cycles } } /************************************************************************ The main routine controls the initialization, and the keypress to start and stop the motor. ************************************************************************/ int main(void) { LATE = 0x0000; TRISE = 0xFFC0; // PWMs are outputs CNEN1 = 0x00E0; // CN5,6 and 7 enabled CNPU1 = 0x00E0; // enable internal pullups IFS0bits.CNIF = 0; // clear CNIF IEC0bits.CNIE = 1; // enable CN interrupt SpeedError = 0; SpeedIntegral = 0; InitTMR3(); InitMCPWM(); InitADC10(); while(1) { while (!S2); // wait for start key hit while (S2) // wait till key is released DelayNmSec(10); // read hall position sensors on PORTB HallValue = PORTB & 0x0038; // mask RB3,4 & 5 HallValue = HallValue >> 3; // shift right to get value 1, 2 ... 6 OVDCON = StateLoTable[HallValue];// Load the overide control register PWMCON1 = 0x0777; // enable PWM outputs Flags.RunMotor = 1; // set flag T3CON = 0x8030; // start TMR3 while (Flags.RunMotor) // while motor is running if (!S2) // if S2 is not pressed
{ if (HallValue == 1) //IF in sector 1 { HallValue = 0xFF; // force a new value as a sector if (++Count == 5) // do this for 5 electrical revolutions or 1 // mechanical revolution for a 10 pole motor { Timer3 = TMR3;// read latest tmr3 value TMR3 = 0; Count = 0; GetSpeed();// determine spped } } } else // else S2 is pressed to stop motor { PWMCON1 = 0x0700;// disable PWM outputs OVDCON = 0x0000; // overide PWM low. Flags.RunMotor = 0;// reset run flag while (S2)// wait for key release DelayNmSec(10); } } // end of while (1) } /******************************************************************* Below is the code required to setup the ADC registers for : 1. 1 channel conversion (in this case RB2/AN2) 2. PWM trigger starts conversion 3. Pot is connected to CH0 and RB2 4. Manual Stop Sampling and start converting 5. Manual check of Conversion complete *********************************************************************/ void InitADC10(void) { ADPCFG = 0xFFF8; // all PORTB = Digital;RB0 to RB2 = analog ADCON1 = 0x0064; // PWM starts conversion ADCON2 = 0x0000; // sample CH0 channel ADCHS = 0x0002; // Connect RB2/AN2 as CH0 = pot. ADCON3 = 0x0080; // Tad = internal RC (4uS) IFS0bits.ADIF = 0; // clear flag IEC0bits.ADIE = 1; // enable interrupt ADCON1bits.ADON = 1; // turn ADC ON }
/******************************************************************** InitMCPWM, intializes the PWM as follows: 1. FPWM = 16000 hz 2. Independant PWMs 3. Control outputs using OVDCON 4. Set Duty Cycle using PI algorithm and Speed Error 5. Set ADC to be triggered by PWM special trigger *********************************************************************/ void InitMCPWM(void) { PTPER = FCY/FPWM - 1; PWMCON1 = 0x0700; // disable PWMs OVDCON = 0x0000; // allow control using OVD PDC1 = 100; // init PWM 1, 2 and 3 to 100 PDC2 = 100; PDC3 = 100; SEVTCMP = PTPER; // special trigger is 16 period values PWMCON2 = 0x0F00; // 16 postscale values PTCON = 0x8000; // start PWM } /************************************************************************ Tmr3 is used to determine the speed so it is set to count using Tcy/256 *************************************************************************/ void InitTMR3(void) { T3CON = 0x0030; // internal Tcy/256 clock TMR3 = 0; PR3 = 0x8000; } /************************************************************************ GetSpeed, determins the exact speed of the motor by using the value in TMR3 for every mechanical cycle. *************************************************************************/ void GetSpeed(void) { if (Timer3 > 23000) // if TMR3 is large ignore reading return; if (Timer3 > 0) Speed = RPMConstant/(long)Timer3;// get speed in RPM ActualSpeed += Speed; ActualSpeed = ActualSpeed >> 1; if (++SpeedCount == 1) {SpeedCount = 0;CalculateDC();} }
/***************************************************************************** CalculateDC, uses the PI algorithm to calculate the new DutyCycle value which will get loaded into the PDCx registers. ****************************************************************************/ void CalculateDC(void) { DesiredSpeed = DesiredSpeed*3; Flags.Minus = 0; if (ActualSpeed > DesiredSpeed) SpeedError = ActualSpeed - DesiredSpeed; else { SpeedError = DesiredSpeed - ActualSpeed; Flags.Minus = 1; } SpeedIntegral += SpeedError; if (SpeedIntegral > 9000) SpeedIntegral = 0; DutyCycle = (((long)Ksp*(long)SpeedError + (long)Ksi*(long)SpeedIntegral) >> 12); DesiredSpeed = DesiredSpeed/3; if (Flags.Minus) DutyCycle = DesiredSpeed + DutyCycle; else DutyCycle = DesiredSpeed - DutyCycle; if (DutyCycle < 100) DutyCycle = 100; if (DutyCycle > 1250) {DutyCycle = 1250;SpeedIntegral = 0;} PDC1 = DutyCycle; PDC2 = PDC1; PDC3 = PDC1; } //--------------------------------------------------------------------- // This is a generic 1ms delay routine to give a 1mS to 65.5 Seconds delay // For N = 1 the delay is 1 mS, for N = 65535 the delay is 65,535 mS. // Note that FCY is used in the computation. Please make the necessary // Changes(PLLx4 or PLLx8 etc) to compute the right FCY as in the define // statement above. void DelayNmSec(unsigned int N) { unsigned int j; while(N--) for(j=0;j < MILLISEC;j++); } |  |  |  |  |
Модератора може да смени заглавието
| Нед Мар 27, 2016 11:32 am |
timt
То с програмирането филма винаги е голям  Протеус 8 ми е много смотан и бъгав и за това съм на 7.10, опитах се на няколко пъти да работя с 8-цата но ми се видя смотана. По добре кажи какво искаш да направиш. Като ти писах че кода много ме съмнява без да се задълбочавам в него е че е много дълъг (голям) за такъв вид джаджа. Не съм си играл да го разглеждам подробно. BLDC за всеки мотор е различно, например аз преди време се опитвах да направя една шлайф машинка за полиране с изгоряла плата и така и не успях да и постигна оборотите които ми трябваха. А и беше служебна и бракувана и за това спрях да си играя с нея.
| Нед Мар 27, 2016 11:48 am |
asensavov
Ще правя дипломна работа и общо взето трябва да направя една установка на която да си играят студентите. Ако подкарам последния сорс, правя една симулация и започва реалното осъществяване.
Поздрави
| Нед Мар 27, 2016 12:07 pm |
timt
ето ти симулация
| Нед Мар 27, 2016 12:43 pm |
asensavov
Мерси. Работи на моя протеус, значи нямам проблем с него. Аз все пак ще се помъча с микроконтролерите за да е по интересна дипломната работа.
| Нед Мар 27, 2016 1:59 pm |
asensavov
Някой може ли да пробва този файл дали се компилира. Изисква p30F2010.h MikroC ми дава грешка в хедър файла.
Поздрави.
| Нед Мар 27, 2016 7:08 pm |
[ 14 мнения ] |
