Отговори на тема  [ 100 мнения ]  Отиди на страница Предишна  1, 2, 3, 4, 5 ... 7  Следваща
С или Basic, каква е разликата?
Ами и аз съм съгласен с Никола.
Човек трябва да се развива.
П.П.
В селския хоремаг за посредствен човек се счита този който не може да се справи с половинка ракия.
Вто Дек 09, 2008 3:01 pm
Местоположение: Ботевград
BASIC Advantages
1. Very easy to learn and use.
2. A BASIC compiler will produce code that runs fast as a C compiler.
3. Many in built functions (depending on compiler).
4. Very popular – large user base with many example programs.
BASIC Disadvantages
1. Non standard language.
2. If using an interpreted HLL will run very slowly.
Note: Because the language is not standardized it will be difficult to move code to a new processor target type.
Pascal Advantages
1. Easy to learn and use.
2. A Pascal compiler will produce code that runs fast as a C compiler.
Pascal Disadvantages
1. Not as popular as C – so not as many compilers.
2. A bit wordy – it was originally intended as a teaching language.
3. Not as flexible as C.
C Advantages
1. Compiled language - always runs fast.
2. Standardized language (ANSI)- easier to port to different compilers / target devices.
3. Many compilers available.
4. Many in built functions (depending on compiler).
5. Very popular – large user base with many example programs.
6. Used in many different industries.
7. Usable at the hardware level as well as higher abstraction levels (although C++ is better for very abstracted programming models).
C Disadvantages
1. Hard to learn at first.
2. Strong type checking means you spend time pleasing the compiler (although this protects you from making errors).
Author John Main
Copyright © John Main 2006
Вто Дек 09, 2008 4:06 pm
Без коментар в тази тема. Вече сме го коментирали и примери сме давали.
С човешката простотия няма преборване. Такива смотяняци като вас само с нещо тежко по главата. И не забравяйте че света е малък преди да ръсите бисери.
Вто Дек 09, 2008 5:10 pm
rumen написа:
Тъй като по другите критерии не можеш да минеш за човек,тренирай. Там може би ще намериш среда в която да се чувстваш пълноценен :):):):)
Вто Дек 09, 2008 5:15 pm
Zeus, това, което си постнал е отчасти невярно, а останалото е спорно.
Нещо като "белите не могат да скачат".
Вто Дек 09, 2008 5:41 pm
Nikola Kirov написа:
rumen написа:
Схванах сарказма ти.
Ще им кажа че си им казал да учат С. :D
Вто Дек 09, 2008 7:08 pm
Местоположение: Varna
Благодаря на всички за мненията и съветите.
Вто Дек 09, 2008 8:18 pm
Лоша тема а .. :) не мисля че С е по трудно за учене от бейсика, не виждам нищо по-сложно, тъпото и просто С не е с нищо по сложно, виж при Ц++ става малко по извъртяно, но пък има защо ...
Вто Дек 09, 2008 8:51 pm
Desert Leo написа:
Ами не споря. Аз за това съм сложил и автора отдолу, да не си помислите че в моята глава се е родило това. С Бейсик имам доста опит, но от времето на Правец 82 :) . С Паскал по-малко (Предимно Борланд паскал 6.0 без да навлизам в турбовижън). Със С още по-малко - предимно около микроконтролерите. Това го постнах, защото ми попадна в интернет. Всеки да си вади изводите :)
Вто Дек 09, 2008 10:50 pm
Ми като нямаш мнение що се месиш в темата. :):) Ако всеки вземе да поства всяка глупост която срещне в нета какво ще стане. След като си го постнал нормално е да се мисли че подкрепяш това. :)
Вто Дек 09, 2008 11:13 pm
... а реалистите изучават АК-47.
Сря Дек 10, 2008 3:29 am
Вече не ти се връзвам на провокациите 8)
Сря Дек 10, 2008 10:04 am
Бе то и аз почнах с базик, после ми трябваха години да се оттърся от вредните навици там ... Отвратих се от него, когато ми се наложи да трасирам чужд кърпен сорс ... след 49-тия последователен оператор goto се отказах от това творение на програмистите :>
та от тогава си действам със C/C++ ...
Така че ако някой ден мислиш да минаваш на език, различен от базика - изобщо не започвай с него, нанася тежки поражения по мисленето на човек :>
P.S. мразя и да сменям клавиатури ...
Сря Дек 10, 2008 3:59 pm
goose написа:
И един съвет от бивш вече програмист, който си пише само за собствено удоволствие ...
Езика не е важен, езика е просто средство за изразяване на алгоритъма ... Ако искаш да ставаш програмист почни с мислене, езика идва след това. Почни с някаква твоя измислена задача, ако твърдо си се ориентирал към контролерите - стандартните мигащи диоди примерно, схвани как работи контролера, какви са му основните принципи, измисли как точно да раздвижиш светлините и чак тогава се хващай с асемблера, 80% от работата се върши далеч преди да си стигнал до писане на код.
Поздрави ;>
Сря Дек 10, 2008 7:38 pm
Местоположение: Стара Загора
Твоята любов към този бейсик е направо патологична :) Хем ти казаха, че нанася тежки поражения на мисленето... но при теб вече явно непоправими :D
Чет Дек 11, 2008 12:03 am
