Отговори на тема  [ 18047 мнения ]  Отиди на страница Предишна  1 ... 474, 475, 476, 477, 478, 479, 480 ... 1204  Следваща
Новини от цивилизования свят
Ракетата е само една от илюстрациите в книжката, която изглежда да е добра за подарък:
> Stephen Biesty's Incredible Everything
Stephen Biesty's Incredible Everything.gif [ 188.02 KiB | Прегледано 4442 пъти ]
The creators of Incredible Cross-Sections present a study with more than one thousand intricately detailed, color illustrations, showing how everything from bridges to planes to dinosaur models is built, accompanied by a wealth of fascinating facts.
About the Author
Stephen Biesty is an artist of phenomenal talent with remarkable visual skills. As a child he spent hours drawing castles, knights at battle, and ferocious Vikings, taking inspiration from films such as Spartacus, Ben Hur, and Anthony and Cleopatra, which fueled his already fertile imagination.
In 1980, he attended Brighton Polytechnic where he specialized in historical reconstruction illustration and developed a particular interest in what went on inside castles and other ancient buildings. After graduating from Brighton with a BA in Graphic Design, Stephen earned an MA in Graphic Design at City of Birmingham Polytechnic working further in historical reconstruction.
Stephen became a full-time illustrator in 1985 and has since worked on a variety of information books for adults and children. It took Stephen two and a half years to draw the wonderful illustrations for the best-selling Stephen Biesty's Incredible Cross-Sections, which was published in 1992. That volume was the inspiration for a new range of cross-section books which include Man-of-War (1993), Castle (1994), Incredible Pop-Up Cross-Sections (1995), Incredible Explosions (1996), Incredible Everything (1997), Incredible Body (1998), and DK Amazing Pop-Up 3D Time Scape (1999).
Пет Юни 22, 2018 12:04 am
Е да, ама виж кога е публикувано, днес не им трябват такива неща, зомбита, и някакви други уродчета които дори не ги знам какви са са им достатъчни, ще гледат те ракети, за какво им е, друго е да гледаш xxx шибаняк черняк , разстреля ли го и стана знаменитост, чак сега започнали да му разбират творчеството .. как не го разстреляха 20 години по рано, до е е бил още в тумбака на черната свиня ... това сега са новините, видиш ли за два дена има 400% повишение в интереса към последния му албум ...
Пет Юни 22, 2018 1:47 am
Е да, ама виж кога е публикувано, днес не им трябват такива неща...
Абе при Мъск и ракети излитат, че и кацат сами, и електрокарчета припкат наоколо, и разни други фентъзита... Тази работа не става само с първа цифра в ЕГН-то 5, 6 и 7, има и много млади хора от новите, по-комерсиални поколения. И тук стигаме до методите за мотивация, дебело/тънко ли се плаща при него, дали плющи работодателския камшик над робските бачкаторски гърбове или по някой друг начин стават нещата. :D
Пет Юни 22, 2018 9:38 am
Чисто технологично, ако загледаш ел.двигател на BMW или Mercedes ами че той няма нищо общо с това което е в теслите, горе долу като да сравняваш дизела на Q7 с дизела на Рудолф Дизел ...
Мии не е баш тъй. Тесла продават целия POwer Train на Мерцедес и на още някои. Вероятно има някакви разлики естествено но това е нормално. Те (Тесла) пък си купуват волана и щракалките от тях (Мерцедес). И тъй.
В един автомобил има 7к клетки. Общо взето май ги прави най-големи потребител на 18650 в света. Имаше едно изказване че ако пуснат фабриката за Модел 3 ще дръпнат цялото световно производство (тогавашно) на тия клетки. То затова им се наложи да си направят собствена фабрика.
Пет Юни 22, 2018 4:29 pm
Ммм може би на някои мерцедеси, гледах някакви филмчета в тубата в които разкостваха и мерцедес, и Тойота и BMW и Порше, гледал съм и филмче за производството на телсите, и някак не намирам прилики.
Тя фабриката за батерии не е точно тяхна, сега не съм се интересувал каква част е тяхна и каква е на панасоник, ама реално май цялата фабрика за батерии си е на панасоник, но това не е цялата гигафабрика а само част от нея. Те се канят да правят и в Европа .. интересно България дали изобщо се е кандидатирала :)
Пет Юни 22, 2018 6:21 pm
ето каква фабрика строят на север
https://www.google.se/amp/s/www.theloca ... actory/amp
Пет Юни 22, 2018 6:25 pm
В Швеция .... е ако някой може да ми го обясни ... айде да не е България, ама малко ли са им страните в централна Европа, всички въвеждат данъчни облекчения, имат по-нисък стандарт, отиди се завру в Швеция, данъци и комунизъм, ей това не мога да го разбера.
Пет Юни 22, 2018 6:37 pm
В Швеция ....
Политическа и икономическа стабилност, малка вероятност в обозримо бъдеще да се смени посоката на държавата и примерно да реши да изправи лошите частници до стената.
Grubi написа:
Погледнах съседна статия и ти да видиш :D :
> Why thousands of Swedes are inserting microchips into themselves
Докато се чипира всичкото двукрак добитък, ще има работа за електронни инженери и няма лесно да изчезне занаята. :D
Пет Юни 22, 2018 7:12 pm
Айде сега, искаш да кажеш че цяла останала европа е пред бунт или какво, дори Австрия е финансово по-удобна от Швеция, просот не мога да си го представя. Имало е явно някакви причини, може да са им обещали много сериозни облекчения, не знам, но на база икономически параметри, аз не бих построил фабрика там. В момента едно от най-удачните места е Полша, много работна ръка, все още сравнително евтина, в центъра на европа, с добра комуникация, добро образование ..
Пет Юни 22, 2018 8:07 pm
Private написа:
Интересно, има ли някаква защита от нежелано прочитане на RFID-то? Щото ако всеки с мощен излъчвател може да те прочете от метри разстояние, нещата стават грозни. :)
Пет Юни 22, 2018 9:52 pm
Ти се радвай само ако те чете, да не почнат да ти сменят фърмуера и в един момент от месо да минеш на сено ... и ще се реши проблема с изхранването, па рупат по цял ден тревица на воля, а и колко по удобно на 4 крачета, талафона си виси кротко пред погледа, фейсиш си и си пасеш .. идилия.
Пет Юни 22, 2018 10:28 pm
И лучец еж,
водица пий -
И пак поглеж!
Дий...
Дий, воле, дий!
Яворов, на нивата
Съб Юни 23, 2018 7:50 am
айде стига с тия глупости, уж сте сериозни хора
някаква фирма или няколко тех кукута си сложили rfid чипове в ръката и излезе 1984та
и аз искам, но засега не виждам смисъл - въпреки, че ключалките и по-селата вече са с код, rfid и дистанционно.
и какво като го прочетат - не държа злато и кеш под дюшека или където и да е. ще откраднат някое старо HP от архива ми :D
ТоНи - ако си прочел, освен данъци и комънизъм, до тая фабрика има и няколко полезни мини, случайно
Съб Юни 23, 2018 10:14 am
Суровината не може да е определящия фактор в случая. Тони е прав, вероятно са се споразумели за някакви яки облекчения, било данъци, било осигуровки в първите години или някаква безплатна инфраструктура. Пък и нека се случи и да почне да прави пари, тогава ще говорим пак, тоя пазар е толкова динамичен, че подобни инвестиции са яко рискови.
Другия вариант китайците да имат някакви планове за там, а техните планировки рядко се подчиняват на нашата бизнес логика.
Съб Юни 23, 2018 12:56 pm
Верно, че само със суровини не може..
Инфраструктура да искаш тук, ABB имат големи офиси наблизо, карго летища и пристанища. Е и китайците са тука.
Май стига...
Съб Юни 23, 2018 2:19 pm
