Отговори на тема  [ 8678 мнения ]  Отиди на страница Предишна  1 ... 392, 393, 394, 395, 396, 397, 398 ... 579  Следваща
Мнение Re: Хумор
am stereo, по едно време си мислех, че си забравил за форума и хоп... взе, че намери пари за интернет. 8O :?
Вто Апр 30, 2019 8:13 pm
Мнение Re: Хумор
цели 15лв ми искат тия педали-и те дават на полицията ако некой те наклевети ай пито..ще се въра на ван порта,както погрешка ме вързаха като бях в монтана навремето,но тук са сбутали 2 препълнени суича в 1 кутия и е нужен А - рж45 разклонител за товаИзображениеEUR 11,30
:?: Защо така разделят пачовете -няма ли единия изход да не работи при 100мб режим\2 двойки само\Изображение
Our Port Doublers allow two devices to be connected using only one port of a structured cabling system. The CAT5/5e/6 cable used in a conventional Fast Ethernet network is made up of 8 conductors 4 of which are unused. The port doubler makes use of these 4 spare conductors to provide a second connection over a single cable run without any loss of performance. Port Doublers must be used in pairs by connecting one to the patch panel and the other to the wall outlet. Please note: these doublers are sold as single units not pairs. 2 x 10/100Base-TX devices to 1 port Low cost solution for adding extra connections Existing installations can be expanded quickly and easily allowing additional devices to be added temporarily or permanently No performance loss Saves adding additional cable runs Ideal for existing installations where additional cables cannot be installed easily
PoE doesn't need separate wires. As others have mentioned, gigabit ethernet uses all 4 pairs for data, so Gigabit PoE power and data share the same wires.
100BASE-TX uses 2 pairs. There are 4 pairs available in the cable. Those 4 pairs are split between the 2 "outputs" on the splitter. As such, neither device connected to the "outputs" will operate at 1000BASE-TX.
If the splitter makes use of the spare pairs in a cable, the splitters need to be used in pairs to return the data to the correct pair at the other end. It is possible to connect multiple computers to one Ethernet cable in parallel since the Ethernet standards were originally bus type networks and allow for collision detection. Two computers will quite happily share one Ethernet medium. :idea: :?: май това ми трябваИзображение Built-in surge and transient overvoltage protection ensure safety during operation
Connect two male RJ45 to your switch, and remotely connect each to your camera, Wi-Fi or phone
Compatible with any 10/100 switch with or without PoE; Ideal for devices that does not support Power Over EthernetИзображениеNOTE: Don't support 2 or more computers that connect to the internet simultaneously, ONLY 1 output port is working. When one port is connected to the network, other ports devices must be disconnected. :evil:Shipping & Fee Details
Price $6.99
AmazonGlobal Shipping + $13.90
Estimated Import Fees Deposit + $4.18
Total $25.07 Изображение
Последна промяна am stereo на Сря Май 01, 2019 11:32 am, променена общо 3 пъти
Сря Май 01, 2019 9:52 am
Мнение Re: Хумор
на стереото нещо му плува пилотния сигнал, по честота ли е, по фаза ли - не може да се окопремери.
в резултат двата канала често се препритат, губят сигнал, а понякога се чува и друг канал от съседната станция.
човек, може ли малко да намалиш радиото?
Сря Май 01, 2019 11:27 am
Мнение Re: Хумор
не виждаш ли,че търся свестен разклонител за нета ми-тия горе се не стават- първия работи в чифт;другия само единия изход е с нет...да дам над 55лв.за боклук :!:
Сря Май 01, 2019 11:36 am
Мнение Re: Хумор
ами не е толкова очевидно, че търсиш нещо, каквото и да е то. поне за мен. и особено в тема 'хумор'
ако нещо те убива чепика със сплитерите, пусни си тема, опиши какво търсиш, какво искаш да постигнеш и може да получиш подходящи препоръки. колкото повече думички напишеш и колкото повече ти е фокусиран въпроса, толкова по-голям е шанса да получиш правилен отговор.
'разклонител за нета' лично на мен ме навява на мисли за рутер или поне суч. другото са не особено препоръчителни практики за ползване на 4-чифтов кабел за пренос на 2 10/100 (FE) сигнала и няма нищо общо с разклоненията, еле пък с интернета.
Сря Май 01, 2019 11:56 am
Мнение Re: Хумор
Абе, ти си направо радио Ереван :D
Сплитерът не служи да "разклониш мрежата" а да пуснеш "2 мрежи" по 1 кабел. Т.е - трябват ти 2 сплитера, по един от всеки край на кабела.
Иначе разклоняването на мрежата не става без активни устройства - комутатори или хъбове.
Сря Май 01, 2019 12:01 pm
Мнение Re: Хумор
Дедо,
то не е за хумор неговото, ами за "плаче майка" раздел :!:
много пъти съм предлагал да има тема "Звездите ми говорят". доста почетни членове ще има там :)
Сря Май 01, 2019 12:28 pm
Мнение Re: Хумор
Суичовете са по 15-на лева, ако много държиш може и за 10 да го намериш, пък ако е на старо...
Ама наистина: съобразявай се с тематиката!
Сря Май 01, 2019 12:31 pm
Мнение Re: Хумор
bongo_x2 написа:
пу-несъм,Tisho почна пръв :)
аз имам суич,но няма място за него :idea:
тия сплитери ще се поберат там уж
lcr написа:
хаха
тогава минятурен суич с вход и 2 разклонения някакъв
пп
Въпрос към радио „Ереван”:
- Какво е изневяра в Перник?
Отговор на радиото:
- Друг мъж да бие жена ти! :axe:
Въпрос към радио "Ереван":
- Кога мъжът е най-съсредоточен?
Отговор на радиото:
- Мъжът е най-съсредоточен, когато прелива ракия от дамаджана в малка бутилка...
Попитали радио Ереван:
- Как се доят овце?
- Като пуснеш нов модел айфон на пазара...
Въпрос към радио Ереван:
- Какво ядат канибалите по време на пости?
Отговор на радиото:
- Вегани...
- Коя жена е почтена? - пита радио Ереван, а радио Париж отговаря:
- Тази, която има съпруг и любовник.
- Ама тази жена е покварена! - възмущава се радио Ереван.
- Не, покварена е тази, която има съпруг и много любовници.
- Това не е ли развратна жена? - учудва се радио Ереван.
- Развратна е тази, която няма съпруг, но има много любовници.
- Как? Такава е пропаднала...
- Пропадналата няма нито съпруг, нито любовник.
- Ее, това е самотна...
- Ооо, не, грешите. Самотна е тази, която има съпруг и няма любовник! :!:
Блондинка се обажда в радио Ереван:
- Как най-бързо мога да стана секретарка на голям шеф?
Радио Ереван отговаря:
- На сексуални въпроси не отговоряме!
- По какво човека прилича на компютъра?
- Също като компютъра, на млади години човек има достатъчно хардуер и малко софтуер, на старини -софтуерът в изобилие, но все не достига хардуерът.
- Каква е приликата между жената и колата?
От радиото отговорили:
- И двете стават трудно подвижни след спукана гума!
- Колко пъти е редно да изневери една съпруга?
- Колкото пъти не я хванат.
- Може ли да се оправи колежка в работно време?
- А в кое друго време?!?
- Каква е максималната скорост при секса?
- 68, защото при 69 се обръщате.
- Може ли родителите да разговарят с 15-годишната си дъщеря на сексуални теми?
- Да, ако искат да научат нещо ново!
- Колко вида хора има в България?
- Само два вида - доволни и недоволни. С недоволните се занимава Държавна сигурност, а с доволните - Икономическа полиция.
- Русия ще влезе ли в НАТО?
- Ако се налага, ще влезе. Чак до Белгия ще влезе, ако трябва.
:D Попитали радио Ереван:
- Защо само 30 % от жените попадат в рая?
- Защото, ако бяха повече, това щеше да е адът. :o
Сря Май 01, 2019 12:46 pm
Мнение Re: Хумор
Наистина ли съветската царевица е най-добрата в света?Да, съветската царевица е като телеграфен стълб, толкова здрава и висока и расте точно на такова разстояние една от друга".
- Как се гладят дантелени гащи с ютия?
- Върху гъза на тъщата!
- Защо на евреите са им големи носовете.
Радиото отговаря:
- Защото въздухът е безплатен.
Попитали радио "Ереван":
- Може ли кърпа да убие човек?
- Да, ако в кърпата има ютия.
- Каква е приликата между телевизионната кула и женския крак?
- Колкото са по-високо, толкова повече ти спира дъха.
Питат радио Ереван:
- Защо на арменските жени са им криви краката?
- Затова пък са космати.
Попитали Радио Ереван:
- Може ли жена да забременее от вятър?
- Може, ако преди това вятъра е преминал през военно поделение.
Въпрос към Радио Ереван:
Какво би трябвало да се промени, за да могат българските пътища да отговарят на стандартите на Европейския Съюз?
- Стандартите на Европейския Съюз.
- Как може да се продаде на двойна цена Трабант?
- Ами като се напълни резервоара до горе.
Питали Радио Ереван:
- Може ли заврян зет да стане 100 кг.
Радиото отговаря:
- Може, ако е бил 150.
Радио Ереван провежда предаване с открит телефон за връзка. Постъпва запитване от слушател:
- Как може една дебела жена да отслабне? Радио Ереван дава съвет:
- Препоръчваме на такава жена да върти обръч.
Следва ново запитване от същия слушател:
- А какво да направи горката жена, ако не може да влезне в обръча?
Радиото е силно затруднено. На помощ се отзовава Радио Анкара:
- Ние с интерес следим Вашето предаване. Горещо препоръчваме да не разваляте хубавата жена!
Радио Париж пита:
- Какво щеше да стане, ако на проститутките очите им светеха ?
- Ами в Париж щеше да има бели нощи.
След кратко време се обажда радио Ленинград:
- Моля без намеци...
Питат Радио Ереван:
- Как е най-добре за народа - първо да се увеличат цените и след това заплатите или обратно?
Радио Ереван мълчи - на политически въпроси не отговаря.
Втори въпрос:
- Как е най-добре за булката да бъде облечена в първата брачна нощ - с копринена или памучна нощница?
- Все тая, и в двата случая ще бъде наебана. Отнася се и за първия въпрос.
- Каква е разликата между бельото на бабите ни и нашето?
- Едно време разтваряш гащите, за да видиш задника, а сега разтваряш задника, за да видиш гащите.
- Какво е кавалерство?
- Държанието на един мъж към жената на друг мъж.
- Може ли мъж да забременее?
- Не може, но опитите в Анадола продължават.
Сря Май 01, 2019 4:27 pm
Мнение Re: Хумор
Радио "Ереван" пуснало анкета до всички национални радиостанции с въпрос: "Какъв максимален брой дини може да носи един средно статистически мъж ?".
След известно време по-голямата част от радиостанциите отговорили, като преобладавал отговорът че един мъж може да носи най-много до четири дини: по една под двете мишници и по една във всяка ръка.
"Един Арменец може да носи пет дини - оповестило радио "Ереван"- четири в ръцете и една надяната на чепа!"
В този момент пристигнал и отговорът на радио "София":
- Един българин може да носи девет дини - четири в ръцете и един арменец с пет дини надянат на чепа !
След като в "Шоуто на Слави" вицепремиерът Николай Василев каза, че за една година сме направили крачка напред, буден гражданин попита попита радио "Ереван" колко ни остава до капитализма на господин Василев.
- 18 км - отговори радиото, без да се замисли.
Питат радио Ереван:
- Кога свършва меденият месец?
- Когато мъжът престане да помага на жена си в миенето на чиниите и започне да ги мие сам - отговарят от радиото.
- Кога човек трябва да си изпере чорапите?
- Когато си събуеш обувките и чорапите останат вътре.
- Кога трябва да си ги зашие?
- Когато можеш да си изрежеш ноктите без да си събуваш чорапите.
- Кога трябва да ги хвърли?
- Когато можеш да си свалиш чорапите без да си сваляш обувките.
Питат Радио Ереван:
- Може ли да се живее само от заплата?
- Не знаем, не сме опитвали.
- Каква е разликата между самотната и порядъчната жена?
- Самотната - това е жена, която всяка вечер си ляга сама, а порядъчната обича реда - тази вечер с един, утре с друг и така нататък.
Питат Радио Ереван:
- Какви са симптомите на венерическите болести?
Радиото отговорило:
- Ами, ако съдим по Венера Милоска, първо ви падат ръцете...
60-те години. Запитване до радио "Ереван":
- Вярно ли е, че вчера в Москва са подарили на другаря Гагарин нов мерцедес?
Радио "Ереван" отговаря:
- По принцип - да. Но събитието не се е случило в Москва, а в Ленинград. Освен това не става въпрос за другаря Гагарин, а за Иван Иванович Петров; и не е бил мерцедес, а велосипед; и не са му го подарили, а са му го откраднали.
- Има ли живот на Марс?
Радиото отговаря:
- И там няма.
- Какво е това групов секс?
- Групов секс е когато участниците са повече от един!
- С каква операционна система работи "Матрицата"?
- С Windows естествено! Иначе в края на първия филм нямаше да пише "System failure", а втория да се казва "Reloaded"!
Запитали радио Ереван:
- Дали Ева е изневерявала на Адам?
Радиото отговорило:
- Че как иначе, нали човекът е произлязъл от маймуната...
Попитали радио Ереван какво ще се случи, ако всичката глупост от парламента изчезне.
- Нищо в природата не се губи. - отговорили от там. - Като изчезне от някъде, ще се появи на друго място. И там ще бъде новият парламент.
- Ало, радио Ереван?
- Да.
- Оня ден слушах по вашето радио много интересна политическа дискусия. Днес обаче едва-едва ви хващам, много лошо се чува...
- Вече излъчваме от Сибир.
Попитали радио "Ереван" кое е най-ефикасното противозачатъчно средство.
- Лимонада.
- Ами как се прилага - преди акта или след акта?
- Вместо акта...
- Какво трябва да се направи, ако тигър нападне тъща ви?
- Сам си я е нападнал, сам да се и защитава.
- Коя е най-малката партия в България?
Отговорът бил:
- Жената - един член влиза, един излиза.
Попитали радио Ереван: Може ли да се пикае срещу вятъра?
Отговор: Може, но без да си го вадиш навън.
- Може ли човек да пръдне по време на атомна бомбадировка?
- Може, стига да си намери задника! - отговорили от радиото.
- Кога ще настъпи според вас световен глад?
- Когато китайците разберат, че досега са яли само гарнитурата.-отговорили от радиото.
- Кой е най-хубавият град в света?
Отговор:
- Естествено, Ереван.
- А какво ще стане с най-хубавия град, ако американците пуснат атомна бомба върху него?
След дълго мълчание радиото отговаря:
- Тбилиси също е хубав град.
- Каква е разликата между руската сватба и руското погребение?
- Пияните са с един по-малко!
- По какво ще се разбере кога е победил феминизма?
- Когато новините започнат така: "Добър вечер уважаеми зрителки!"
- Каква е разликата между долара и рублата?
- Ами доларът е обезпечен със злато, а рублата - с танкове.
Питат Радио Ереван:
- Защо Армения иска да има министерство на флота, след като няма флот?
Отговор:
- А защо Грузия има министерство на културата?
Попитали радио Ереван как се вари глава на комунист. Отговора бил:
- Главата се слага в една тенджера, затиска се с един камък и се вари докато камъка омекне!
Въпрос: Как наричат мъж, който не употребява презервативи?
Отговор: Татко!
- Какво трябва да има на втора страница от упътването на Москвич, Волга и други подобни соцвозила?
- Разписание на всички автобуси и влакове.
- Какво прави лисицата, когато иска да има малки лисичета?
- Същото, което прави и жената, когато иска да има лисича яка.
- Какво е общото между бременна осмокласничка и трабант?
- И двете са пълен позор за семейството.
Питат радио Ереван:
- Що е кръст върху кръст?
Радиото отговорило:
- Поп върху медицинска сестра!
От Би Би Си попитали радио Ереван:
- Колко получават средно вашите инженери?
След кратка пауза, радиото отговорило с патос:
- А при вас пък, има расизъм...
Прогноза за времето на радио Ереван за "Пролет - Лято"2003":
"На четни дати ще вали, на нечетни няма да вали. Възможно е
точно обратното."
- Може ли от 10 квадратни метра бял плат да се направят долни гащи?
Радиото отговаря след неколкоминутно мълчание:
- Ебати гъза!
Питат радио Ереван:
- Кое му е най-лошото на комунизма?
Радио Ереван отговаря моментално:
- Това, което идва след него!
Радио Ереван мълчи 5 часа и на шестия се обажда:
"Драги радиослушатели, завърши емисията за глухонемите..."
Питат Радио Ереван:
- Може ли да се прави секс в движение?
- Не, защото жената с вдигната пола бяга по-бързо от мъжа със свален панталон.
- Защо булчинските рокли са бели?
Отговор:
- Защото стандартният цвят за кухненско оборудване е белият.
Питат Радио Ереван:
- Българите могат ли да донесат пръст от луната?
Отговорът на радиото е:
- Могат, ама среден...
Попитали радио Ереван: Що е човек?
Радиото стои безмълвно. След месеци отговаря:
- Дълго не намерихме отговор на този въпрос. След консултация с радио Скопие, даваме техния отговор. И така, що е човек?
Отговор: Лайно сo пари.
- А какво е лайно?
Отговор: Човек без пари.
- А какво са пари?
Отговор: Парите са, море дето от лайното правят човек...
- Какво да направя, ако съпругата ми постоянно наднича от кухнята и ми се кара, докато гледам мачове?
Отговор:
- Скъсете й веригата...
:D 8)Попитали радио Ереван:
- Да вярвам ли на приятеля си, който твърди, че жена му е ангел?
- Приятелят ви вдовец ли е?
Някакъв човек се обажда на радио Ереван:
- Добър ден, скъпо мое радио. Аз ви се обаждам, за да се оплача. Ние сме много бедно семейство. Всъщност ние сме толкова бедни, че ползваме едно и също бръснарско ножче четирима души. С това ножче аз и баща ми си бръснем брадите, а майка ми и сестра ми си бръснат краката. Кажете, може ли да е по-лошо?
Радиото помълчало малко и отвърнало:
- Всъщност, да - може да е и по-лошо. Можеше с това ножче вие и баща ви да си бръснете краката, а майка ви и сестра ви да си бръснат брадите...
Попитали радио Ереван може ли първоаприлската шега да мине и за коледен подарък.
Отговорили: "Може, ако се износи нормално..."
- Какво правят младоженците първата брачна нощ?
- Броят парите.
Питат Радио Ереван:
- Каква е приликата между демокрацията и българската демокрация?
Радиото отговоря:
- Като между обикновения стол и електрическия стол.
Питат радио Ереван:
- Има ли опасност от глад на земята?
- Не, освен ако китайците не се научат да ядат с вилици.
- Как, при полов акт, мъжът да накара жената да вика в продължение на два часа?
От радио Ереван отговарят:
- Като си избърше оная работа в пердето...
Сря Май 01, 2019 8:30 pm
Мнение Re: Хумор
Изображениеhttps://www.ghacks.net/2018/10/13/latest-gpu-z-detects-some-fake-nvidia-cards/
Oh no…
My GTX 960 4GB is reported to be fake by GPU-Z
No wonder why when I surfed PHub, it always took me to some church website.. :-/
Чет Май 02, 2019 8:54 am
Мнение Re: Хумор
bongo_x2 написа:
Еленко се приготвя и си отмята по списъка:
1)храна - ок!
2)вода - ок!
3)пари - ок!
4)документи - ок!
Минава колега и го пита:
- На екскурзия ли заминаваш?
- Не, на митницата ще ходя, ще освобождавам три тениски.
А походно легло и завивка?
:D
Съб Май 04, 2019 11:30 am
Мнение Re: Хумор
https://www.facebook.com/yo.its.bred/videos/421791565032213/
Нед Май 05, 2019 2:36 pm
Мнение Re: Хумор
К'во чух по радиото преди да сменя станцията, обръщение към папата: "София е мъдрост!" :rolleyes:
По-запознатите казват "софия", а що за лудница е София фффсички си знаем.
То като да объркаш Атина с Атина - второто е столицата на Гърция, но само наш'те журналя не го знаят.
ПС: а в Уйчиндол що няма дол с... таковата?!
Нед Май 05, 2019 5:55 pm
Потребители разглеждащи този форум: HCL и 71 госта
