Дата и час: Вто Ное 24, 2026 10:52 pm
нова работна станция ....
 Re: нова работна станция ....
А среброто има по-добра топлопроводимост от медта...
| Сря Окт 11, 2023 9:16 am |
за 5 кила недекларирано сребро със сигурност ще гледа света на квадратчета. за мед може да се измъкне само с плащане.
| Сря Окт 11, 2023 9:20 am |
al_at
Регистриран на: Пет Апр 13, 2018 4:00 pm Мнения: 1694 Местоположение: София
А диамантът - още по-добра топлопроводимост и от среброто - около 5 пъти
| Сря Окт 11, 2023 9:32 am |
Да, но се фрезова трудно...
| Сря Окт 11, 2023 9:46 am |
palavrov
Хубаво обяснение защо Мак е бърз:  |  |  |  | Цитат: For those wondering why the M2 Ultra is so fast, or the M1 & M2 series in general, it's because inference's main bottleneck is memory bandwidth, not compute power. And the M2 Ultra has a bandwidth of 800 GB/s which is about 8 times faster than an average modern desktop CPU (dual-channel DDR4-6400 offers a bandwidth of 102 GB/s).
This high bandwidth is really a result of Apple having designed a unified memory architecture for the M1 and M2 chips. Typically on a laptop or desktop, the CPU and GPU have distinct memory systems: high-bandwidth (but relatively low-capacity) graphics memory, and relatively low-bandwidth (but high-capacity) CPU memory. Apple decided to simplify that and instead implemented a single high-bandwidth memory system shared by the CPU and GPU. The only downside is that such high-bandwidth memory had to be tightly integrated in the M2 package, so the maximum capacity is limited. For example whether you spend 5,600 USD (cheapest Mac Studio machine with M2 Utra and 192 GB) or $10k+ (maxed out Mac Pro), you will only ever get 192 GB RAM max. For that amount, a PC could get 1024 GB RAM (5× more!) But on the other hand, if your workload, like inference, doesn't need more than 192 GB, then that's great. Personally I think Apple made the right tradeoff here. 800 GB/s of memory bandwidth on a general purpose CPU, on a single socket, has never been done before (to my knowledge.) |  |  |  |  |
т.е. Тони заради бързия достъп до паметта дори и с емулацията на х86 може кад-а ти да работи по читаво на мак отколкото на наточено ПЦ - иска пробване. Ако тръгне габаритите на Мак Студио са без проблем за куфар а Мак Мини може да влезе и по голям джоб на яке.
| Пет Окт 13, 2023 2:04 am |
Мда, канали има това е ясно, но при када не помагат според моите тестове, не знам какво толкова смята при ребилд, и то не знае според мен, недъгаво написан софт. Примерно ако нейде свети някаква грвшчица, без значение каква, но особенно ако е мейт /връзка / може не за кафе а за вечеря с 3 блюда да имаш време. Няма да казвам че 50% от времето е нот респондинг но ако почакаш се освества  Това е резултата от модерните драскачи, не мога да си представя в игрите сцени с хиляди обекти и текстури и физика се рендират риъл Тайм. С по 150-200 фпс а тъпия кад с 1000 просто детайла прави ребилд по 5 Мин ....ако игрите се пишеха от тима на солид спокойно можеха да се играят на иглен принтер, със сигурност печата щеше да е по-бърз от рендеринга.
| Пет Окт 13, 2023 3:40 am |
palavrov
| Съб Окт 14, 2023 12:23 am |
мда и тази е доста интересна
| Съб Окт 14, 2023 12:50 am |
palavrov
Още една малка кутия: https://www.youtube.com/watch?v=lN8Vkcu0RxoНа видеото конфигурацията е доста скопена откъм бързодействие, но предполагам, че би могло да се напъне. Хубавото е, че има списък с малки кутия, захранване, вентилатори и т.н. дъно и процесор може да сменяш. Edit: https://www.youtube.com/watch?v=RhRTpjqEkJk още една малка конфигурация от същия канал
| Чет Окт 19, 2023 11:20 pm |
palavrov
Последно - още една скопена конфигурация в малка кутия, има потенциал и за по бърз процесор. https://www.youtube.com/watch?v=TcaclKVvJjkИ този има други варианти в канала си. С това приключвам, ако досега не си си харесал компоненти проблема не ти е в компонентите
| Пон Окт 23, 2023 12:02 pm |
Всички тия линкове са доста интересни, набелязал съм няколко кутийчета, радиатора от предния пост изглежда интересен. За радиатора си мислех и нещо друго, не ми е голям проблем вентилатора да надстърча, с цел да имам по-високо ребро, мога да му направя външно кутийче което да позволява лесно разкачане ако имам проблем докато го транспортирам. Като цяло повечето кутии от твоите линкове изглеждат по-удачни от тази която имам в момента, макар и по-дебели. Позволяват монтаж на нормална карта, сега съм ограничен до нископрофилна, което пък ме лимитира доста. Гледам новите 14900 процесори, може би е най-разумното, вярно доста по скъпо от 13-те но като честота дават максимума. Нямам никакво намерение да използвам всичките ядра, перформънс ядрата са достатъчни. Както писах в момента имам 6 ядра, без хипертрейдинг и работи перфектно, дори и солида работи прилично но не бих отказал подобрение, със всичко останало нямам никакъв проблем. Почвам да се чудя за какво да им на тия потребители всички тия купища ядра, какво правят с тях. Да ако рендиш, или имаш тежки симулации да, но това са някакви мижави проценти от всички потребители, ясно гейминга ама това ли е двигател ...да се чуди човек.
| Пон Окт 23, 2023 5:06 pm |
palavrov
Ми маркетинг. Хората кълват на по големи цифри ... иначе счетоводни програми вървяха прилично добре, че и по добре едно време на 4.77МХц правец 16 а сега искат гигабайти, гигахерци. Калпав софтуер, кво да правиш ... хардуеристите не могат да насмогнат на мекуеристите.
| Пон Окт 23, 2023 5:18 pm |
gicho
Аз наскоро за лично си взех 13-та генерация (още я нямаше 14-та) и съм доволен, но, предполагам сте го коментирали, охлаждането си е голям кахър. Аз съм с и7 и 280мм хубаво водно е на ръба - като му се отпуснат юздите юнакът се оглежда за къде 300 вата. За секунди удря почти 100 градуса и почва леко да тротва. С и9 нещата ще са още по-сериозни. При мен лимита беше че исках micro-atx система с по-компактна кутия и макса беше 360мм водно преко сили и с риск да трябва да играе шлайфа. Това го казвам с идеята че големите честоти ги стигат на едно ядро и при правилно дъно и охлаждане - аз смених само фрейма на дъното с алуминиев, но, доколкото четох, махането на капачката (IHS) и подходяща плочка за водното правят сериозна разлика - на 300вт е логично тая пършива тенекия да е проблемна. Но там пак е цифра инвестиция - ако търсиш максимума си заслужава да се погледне. Иначе риска да се скопи заради температурите е много висок. Многото ядра са полезни за ... всичко, което може да се възползва от много ядра. При мен най-ярко се проявява на билдване, архивиране и подобни, както и контейнери и виртуалки на заден план. Иначе е светкавица и в другите неща, но там нямам обективни измервания. Много РАМ - почнах с 64Г с идеята да сложа още толкова (той проца повече от 128 не може), но понеже ползвам Линукс не съм виждал още момент да отиде над 32 и отлагам допълването. Бързо ССД (990 2Т) с моментален ъпдейт на фирмуера и всичко спинка. Друг интересен аспект е че ме сърби вътрешно да си оправям моя код да "пасва" на много ядра и да е кеш-френдли - готина посока е и е полезно като знания за всеки дивелопър, дори и ако работи в ембедед - ама това друга тема. С тая машина мога да меря доста варианти - не е като старото ми лично двуядрено лаптопче... Много ми се искаше 7950х но викам да не разпъвам бюджета чак толкова.
| Чет Ное 02, 2023 10:21 am |
palavrov
Гичо аз взех 7950х с 128ГБ и 2 по 2ТБ 990 - бюджета беше ОК - около 2к евра (без ДДС) от които половината бяха заради моя си глупост и недоглеждане - най наточеното асуско геймърско дъно за 1000 (с ДДС) - още ме яд ама каквото такова. Ако разделя сумата за 20-на години откакто не съм взимал десктоп си е направо евтино а инвестицията като работи човек се избива бързо.
Я сподели как ъпдейтна фирмуера на ССД-то под линукс?
И какво точно имаш в предвид да си оправяш твоя код да пасва на многото ядра? Той Тони май приключи с тази тема та може да я цапаме или пък да отвориш нова, че ми е интересно това с многото ядра.
| Чет Ное 02, 2023 11:40 am |
michev
Инсталираш windows... шегувам се  В страницата с фърмуерите на Самсунг има ISO файлове за самостоятелно обновяване на фърмуера - теглиш, записваш на флашка, буутваш и следваш указанията. Ако си с прясно произведено SSD - няма да имаш нужда от обновяване. Преди около месец взех точно такова и си дойде с последният наличен фърмуер. Иначе за лаптоп vs десктоп машина - понеже ползвам и двете, дори последно поколение интелски процесор на лаптоп се усеща по-лагав от значително по-старо но на десктоп. Не съм бенчвал, но усещането е такова. Ако трябва да купувам в момента десктоп - вероятно бих заложил и аз на АМД. В момента разни хора твърдят, че интел са направили някакви промени (от някой друго поколение насам) в десктоп процесорите си, като са изкарали част от тях на външен чип по дънната платка, което ги правело някак си спънати в определени дейности. При мобилните ми процесори все още всичко си било в тях и подобен проблем не се бил наблюдавал. И понеже дискутирахте NUC-ове и разни подобни мини PC-та - гледайте внимателно, защото някой от тях са точно с лаптопски процесори, което ги обезсмисля като покупка.
| Чет Ное 02, 2023 1:04 pm |
Потребители разглеждащи този форум: Google [Bot] и 32 госта |
