Отговори на тема  [ 18047 мнения ]  Отиди на страница Предишна  1 ... 191, 192, 193, 194, 195, 196, 197 ... 1204  Следваща
Новини от цивилизования свят
Кефят ме, как да не ме кефят :D .
Пет Сеп 27, 2013 1:42 am
Рек - точно така - плутония трудно постига критична маса в нормално състояние - защото критичната маса не е само в килограмите ами и в плътността - изглежда плътността му не е достатъчна в нормално състояние и затова се налага с имплозия да му поувеличат малко плътността.
http://en.wikipedia.org/wiki/Critical_mass
"Until detonation is desired, a nuclear weapon must be kept subcritical. In the case of a uranium bomb, this can be achieved by keeping the fuel in a number of separate pieces, each below the critical size either because they are too small or unfavorably shaped. To produce detonation, the uranium is brought together rapidly. In Little Boy, this was achieved by firing a piece of uranium (a 'doughnut'), down a gun barrel onto another piece, (a 'spike'), a design referred to as a gun-type fission weapon.
A theoretical 100% pure Pu-239 weapon could also be constructed as a gun-type weapon, like the Manhattan Project's proposed Thin Man design. In reality, this is impractical because even "weapons grade" Pu-239 is contaminated with a small amount of Pu-240, which has a strong propensity toward spontaneous fission. Because of this, a reasonably sized gun-type weapon would suffer nuclear reaction before the masses of plutonium would be in a position for a full-fledged explosion to occur.
Instead, the plutonium is present as a subcritical sphere (or other shape), which may or may not be hollow. Detonation is produced by exploding a shaped charge surrounding the sphere, increasing the density (and collapsing the cavity, if present) to produce a prompt critical configuration. This is known as an implosion type weapon."
Пет Сеп 27, 2013 10:15 am
тука много хора взривяваме влакове, но не мислех че и бомбаджии се навъртат
Пет Сеп 27, 2013 10:39 am
Така е, щото има свобода на словото. Иначе вече половината форум щеше да търка наровете в Гуантанамо.
Пет Сеп 27, 2013 11:13 am
Dimitar написа:
Представяш ли си такъв ужас в юесей да се случи?
Пет Сеп 27, 2013 3:07 pm
Cekins написа:
Рек - точно така
Както казах, не ми се влиза в подробности и не ми се обяснява. :) Като цяло, достатъчно е да събереш двете плутониеви полусфери за да постигнеш опасна за живота критична маса, или дори да доближиш достатъчно близо неутронен отражател.
http://en.wikipedia.org/wiki/Louis_Slotin#Criticality_accident
http://en.wikipedia.org/wiki/Harry_K._Daghlian,_Jr.#Criticality_accident
Пет Сеп 27, 2013 3:19 pm
Реконструктор написа:
Dimitar написа:
Въобще не мога да си го представя даже, особено със сегашния главнокомандващ, дето му връчиха нобелова награда за мир :D .
Пет Сеп 27, 2013 11:34 pm
Абе на вас може да ви се размине, ама тоя път качването ми на самолета да не се отложи вместо с 1 час с 1-2 години :)
Съб Сеп 28, 2013 12:24 am
http://anonybulgaria.wordpress.com/2013 ... %BB%D0%B4/
Съб Сеп 28, 2013 8:43 am
Dimitar написа:
Ами ако ти кажа, че абсолютно същите ядрени учения са се провели първо в САЩ и чак след това в СССР?
Пон Сеп 30, 2013 3:54 pm
Дай един линк да видим де, сега така веднъж на 3 дена по една дума ли ще пишеш :) .
Пон Сеп 30, 2013 4:02 pm
Всъщност снимката, която пратих, е от операция Buster-Jangle.
А това е списък с известните американски ядрени експерименти с войници.
Пон Сеп 30, 2013 4:18 pm
Найс :D .
Пон Сеп 30, 2013 9:22 pm
Е ама те това и по ТВ са го давали, не помня по Дискавъри или Нешънъл но имаше филмче за тия експерименти.
Вто Окт 01, 2013 12:44 am
да, даваха го, имаше цял филм за всички ядрени експерименти, последните 3 подземни, не си спомням точните цифри но беше нещо такова:
1. ядрена бомба - 1мегатон - бум - вижда се огромен взрив
2. ядрена бомба - 2мегатона - бум - вижда се все едно планина се повдига
3. водородна бомба - 5 мегатона - бум - целия хоризонт се повдига, след взрива има ново езеро на картата, уплашени военните си проверяват сметките, оказало се че има допълнителна реакция в резултат на която бомбата не е 5 а е 15 мегатона...
тогава решили да спрат с експериментите....
а най шокиращото е как са казвали на войниците че само прахта е радиоактивна, и като се изтръскат от нея са в безопасност.....
Вто Окт 01, 2013 8:20 am
