Дата и час: Вто Ное 24, 2026 9:03 pm
Wise
 Re: Носталгия
А това чудо помните ли? https://en.wikipedia.org/wiki/File:Elka6521.jpg  Всички платки с германиеви транзистори!
| Сря Юни 05, 2019 3:36 pm |
lcr
 Re: Носталгия
Гледам транзисторни или с CMOS схеми. Имало ли е модели с TTL схеми?
| Сря Юни 05, 2019 3:54 pm |
Stoi
Регистриран на: Чет Авг 27, 2015 11:54 am Мнения: 546
 Re: Носталгия
https://www.oldcalculatormuseum.com/casioas-l.html" The AS-L uses a four-chip chipset to make up the "CPU" of the machine. These chips are made by Hitachi, and have part numbers HD3210, HD3211, HD3212, and HD3214. The HD3210 handles keyboard management; the HD3211 contains the main timing and general control logic; the HD3212 contains the Arithmetic-Logic Unit; and the HD3214 contains the shift registers that make up the working registers of the calculator. A fifth large-scale device (HN3203) is a ROM (Read-Only Memory) that contains the microcoded program that operates the calculator. All of these devices are made with ceramic packages with metal lids to cover the chip itself. Along with the large-scale chips, there are a number of other plastic-packaged IC's in the machine which provide glue and display drive functions. These include three oddly-packaged Toshiba T4097 Nixie tube driver devices, a NEC uPD116(BCD to 1-of-10 decoder for the Nixie tubes), a NEC uPD13(Buffer/Driver), seven Hitachi HD3227(Shift Register) IC's, and one Toshiba T1191(Keyboard Encoder). The twelve-digit Nixie tube array is located in a small subassembly, with a metal support structure for the Nixie tubes and a circuit board with the connections for the Nixie tubes. The display subassembly connects to the main board via hand-wired interconnects. Each Nixie tube contains the digits zero through nine along with a right-hand decimal point. Situated at the left end of the display panel is a small incandescent lamp that lights through an orange-colored lens in the shape of a '-' symbol to indicate a negative number in the display. "
_________________www.ev-bg.com
| Сря Юни 05, 2019 3:59 pm |
 Re: Носталгия
тази сметачка не ползва транзистори/тригери както е модерно днес. примерно: брояч до 10 без транзистори
| Сря Юни 05, 2019 4:17 pm |
 Re: Носталгия
сега кажи че го имаш и в килера
| Сря Юни 05, 2019 7:59 pm |
 Re: Носталгия
В някое мазе още имам платки от нея. Навремето ги ползвах за източник на транзистори или на силиконова паста.
| Чет Юни 06, 2019 12:01 am |
 Re: Носталгия
Хех докато търсех снимка на една бобинка ми попадна това. Не е фабрично ама ме върна в ученическите години, това ми беше първият поялник с терморегулатор, не помня от къде бях намерил дръжка, май едни братовчеди дето бяха отишли да учат в западна германия я довлякоха.
| Чет Юни 06, 2019 12:39 am |
 Re: Носталгия
Буржоа!
| Чет Юни 06, 2019 12:59 am |
 Re: Носталгия
То добре че бяха сложил цокли, потенциометъра е сменян 2-3 пъти, ОУ-то и то. Плексигласа не помня от къде го бях докопал, 10-ка, май от архива срещу баба ми, тма имаше фото лабораторийка с някава работилничка към нея, а може и от тия дето правеха табелите с лозунгите да е било, бяха точно зад довара, както си личи минала е два основни ремонта, първо беше синя, после като с епоявиха спрейове стана черна  Сега като се замисля, това е след преработката, първата дръжка се включваше на 5-цата, втората я купувах някъде 93-94 от Брадван във Варна, ама що не съм оставил старата букса не знам, сигурно съм нямал под ръка и ми е досвидяло да махам от другата или ме е домързяло ... а тая 5-ца ако кажа от къде съм я извадил, сигурно ще бъда линчуван ... имах едно хитачи, че и доста хубаво, и си работеше, ама голям зор да сложа букса дето да е за панел ... та пи вода, сложих му една соц DIN-5 а неговата се появи тука
| Чет Юни 06, 2019 1:23 am |
 Re: Носталгия
TR-161 в поялник? изкормена аудио петИца? аудиофилите ще те анатемосат. и много чарколяк, бре
моя първи поялник за регулировка беше от 6 лв. траф, мощен диод и тиристор, потенциометър с линеен плъзгач, всичко запоено направо на изводите на трафа. не помня как съм направил фазовото управление, но надали са били повече от 2-3 транзистора. по онова време нито ги имаш с шепи, нито владеех силата с интегралните схеми. ама е било петнайсетина години преди твоето платче.
| Чет Юни 06, 2019 7:40 am |
 Re: Носталгия
Тиристора е каквото съм имал, тоя грец и него го бях извлякъл от нещо вносно, то всичко е сваляно от някъде, оу-то е ново ама е след смяната на дръжките, първото не беше 741, май 709 не помня, каквото съм имал. Другото е uA723, а на другият радиатор нямам спомен какво има. По едно време след смяната на дръжката бях публикувал схемата в РТЕ, това ще да е било 94-95 може би, знам ли.
| Чет Юни 06, 2019 7:48 am |
Private
Регистриран на: Сря Мар 12, 2008 9:22 am Мнения: 1521 Местоположение: София
 Re: Носталгия
От мен адмирации за професионалното оформяне на кабелния сноп - с оплетка.
_________________ -= All our life, we are beta testers =-
| Чет Юни 06, 2019 8:53 am |
 Re: Носталгия
Ооо това нищо не е, аз дълго време точно така ги правех, чак до новия век че и след това, каквото и да си говорим това е най-сигурният начин, опашки, спирали, ленти ... това са ала бализми, те в това е истината.
| Чет Юни 06, 2019 9:18 am |
lcr
 Re: Носталгия
Носталгията си е носталгия, но свинската опашка и топлият силикон са двете най-велики открития за последните 30 г.
| Чет Юни 06, 2019 11:02 am |
 Re: Носталгия
Ахам - както казваш един бивш колега - Където свършва инженера - започва силикона. Ама немам нерви да правя такива оплетки. Какво и има на спиралата? Иначе всичко в кабелни канали или гофрета.
| Чет Юни 06, 2019 11:06 am |
Потребители разглеждащи този форум: 0 регистрирани и 20 госта |
