Отговори на тема  [ 3905 мнения ]  Отиди на страница Предишна  1 ... 149, 150, 151, 152, 153, 154, 155 ... 261  Следваща
St са обявили нова серия МЦУ. Изглежда ми интересно, но няма големи подробности и предлагане за сега. Като им пуснат поне демо платки - ще се види. Вероятно са подобрили технологичният процес и консумацията. Също май са им единствените обявени в долният 32 битов сегмент автомобилни?
STM32G0 Series
STM32G0 Entry-level Arm® Cortex®-M0+ MCUs
The new STM32G0 Series is not simply another Arm® Cortex®-M0+ microcontroller. It sets a new definition of what an efficient microcontroller must offer. This is all about best optimization, down to each and every detail, to offer the best value for your money and allow you to achieve your goals with the minimum BOM cost and the maximum flexibility for upgrades.
The STM32G0x0 Value line is highly competitive in traditional 8-bit and 16-bit markets and embeds an accurate internal clock allowing further cost saving. It eliminates the need to manage different architectures and the associated development overhead.
The STM32G0x1 line provides upgraded features in analog and is IoT ready with upgraded security functions. It offers a wide range of memory sizes, voltage and packages, bringing flexibility to cost-sensitive applications.
The STM32G0 Series enables the one-architecture-fits-all concept and is ready for tomorrow’s needs.
Efficient, robust and simple, the STM32G0 series is available with 16 to 512 Kbytes of Flash memory in 8- to 100-pin packages, satisfying the needs of a large variety of applications and segments.
https://www.st.com/content/st_com/en/support/learning/stm32-education/stm32g0-online-training.html
https://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32-mainstream-mcus/stm32g0-series.html
Адд:
При автомобилните мощни-
SPC57 M Line MCUs are based on the Power Architecture® core designed for entry-line powertrain (PWT) applications such as motorbikes and engine management systems (EMS) for 2-cylinder motors. They are particularly tailored to answer both the upcoming (2020/2023) new environmental standard requirements and the new safety regulations for motorbikes.
https://www.st.com/content/st_com/en/products/automotive-microcontrollers/spc5-32-bit-automotive-mcus/spc5-mcus-for-high-performance-applications/spc57-m-line-mcus.htm
Сря Дек 26, 2018 4:59 am
аудиофилски ЦАП-ове
32 бита, не се уточнява какви точно са - integer или float. ако се съди по ~129dB DNR са по-скоро 24 integer.
малко съм изтървал модата с преминаването на '32 бита float', но явно има потенциал за растеж в брошурите - преминаване към класически 5-байта float (40 бита), после към double (64 или дори 72 бита), и накрая към 'научния float' на IBM от 128 бита.
не бях посещавал сайта на ESS отдавна. интересни липси се наблюдават.
примерно - има схема и платка за ES9018, но няма чаршаф с конкретни числа.
Съб Яну 19, 2019 10:27 am
То това стана стандартна практика. Не знам какво толкова крият. На мен ще ми се наложи да пиша публикации за да получа достъп до чаршафите на някои от нашите чипове...
Съб Яну 19, 2019 10:38 am
ами при вас наистина има какво да се крие, дори за десктоп и лаптоп чипове.
а за сървърните ако се разрови, ще трябва бая голям вентилатор, за да разпраши такова количество лайна :P и никакви оправдания с ГРУ и хуавей няма да са достатъчни. но си зависи от аудиторията.
а аудиофилията е по-скоро религия вече. важно е числото, споменато в някой форум или ревю в тубата. чаршафите са ненужни за масовата публика, защото по принцип (1) не могат да ги разберат; (2) числата в тях нямат значение, важното е как звучи; (3) инженерните разсъждения са анАтема.
Съб Яну 19, 2019 11:18 am
Te новите процесорчета са 32бита основно, та би трябвало да се справят с данните? Те са 32 бита, но от там нататък какво се изкарва аналогово да напълни децибелите е отделен въпрос. А и какво ще ги захранва като сигнал с толковата битове. Ползвахме Ти 24битов с много входове изходи. То може би и DSP ще му трябва?
Едит- пише, че има някои основни DSP функции?
Съб Яну 19, 2019 11:44 am
Някой аудиофили имат лошо мнение за Sabre-то на ESS и предпочитат/препоръчват по-класически модели от още по-класически фирми.
Съб Яну 19, 2019 11:49 pm
4185_en_banner_cr.jpg [ 17.27 KiB | Прегледано 5588 пъти ]
Някой беше питал май за рутерески гигабитов чип.
Ti май са пуснали (обявили) подходящ, поне според мен
AM6548 (PREVIEW)
Sitara Processor: Quad Arm Cortex-A53 & Dual Arm Cortex-R5F, Gigabit PRU-ICSS, 3D Graphics
Supports Lockstep Mode
16KB ICache, 16KB DCache, and 64KB RAM per R5F Core
Industrial Subsystem:
Three Gigabit Industrial Communication Subsystems (PRU_ICSSG)
Up to two 10/100/1000 Ethernet Ports per PRU_ICSSG
Supports Two SGMII Ports (2)
http://www.ti.com/product/AM6548?HQS=epd-pro-sit-AM65xLaunch-bhp-pf-internal-wwe
Чет Яну 24, 2019 2:36 pm
Рутерски чип с 3Д графика ... накъде е тръгнал тоя свят ...
Чет Яну 24, 2019 11:49 pm
Като чуя името ситара ми се образуват киселини...
Пет Яну 25, 2019 7:51 pm
Intel Phases Out Quark SoCs And Microcontrollers
https://www.cnx-software.com/2019/01/25 ... continued/
Съб Яну 26, 2019 5:03 pm
palavrov написа:
Да- това щях да пиша, че да визуализира на 3Д екран мрежовите връзки
Вто Яну 29, 2019 12:23 pm
Разсъждавате доста тесногръдо. Ако вие нямата нужда от подобна функционалност, то има доста трибуквени организации които с радост биха се възползвали. :D
Вто Яну 29, 2019 12:33 pm
https://www.nordicsemi.com/Products/Low-power-cellular-IoT/nRF9160
Това на хартия ми изглежда страхотно! Отвориха ми работа сега да си преправям дизайна на смартфона :D
Пон Фев 18, 2019 1:34 pm
Тогава виж и това BG77 - еднакъв чипсет с nRF9160
nRF9160 все още е базов и няма дори вграден TCP/IP стек
https://www.comet.bg/files/custom/Quect ... 190108.pdf
Пон Фев 18, 2019 4:54 pm
то на хартия всичко изглежда лъскаво...
а къф му е чипсета, техен или джикитайски
Пон Фев 18, 2019 8:50 pm
Потребители разглеждащи този форум: Google [Bot] и 34 госта
