Продавам CUBIETRUCK (CUBIEBOARD 3) пълен комплект -ПРОДАДЕНА
Привет Колеги,
Продавам въпросното мини РС, чисто ново е доставено на 24-08-2014 г. Причина за продажбата е несериозен приятел.
ЦЕНА : 300 лв. /търпи лек коментар/
за връзка тел.0897858466, Л.С или на е-мейл
Малко данни за самото устройство :
ОПЦИИ
Allwinner Tech A20 SOC
SATA supported
54 extended pins
Built-in HDMI/ VGA display interface
Built-in WIFI+BT module
2GB DDR3 RAM
Built-in IR receiver
SPDIF audio interface
СПЕЦИФИКАЦИЯ
All Winner Tech SOC A20ARM® Cortex™-A7 Dual-CoreARM 1.3GHz ® Mali400 MP2 Complies with OpenGL ES 2.0/1.1
2GB DDR3@480MHz (960MTPS)
HDMI&VGA 1080P display output on-board
10M/100M/1G Ethernet
Wifi+BT wireless connection with antenna on-board
SATA 2.0 interface support 2.5’ HDD(for 3.5’ HDD, only need another 12V power input)
Storage solution:8G NAND+MicroSD
2 x USB HOST, 1 x OTG ,1 x Toslink (SPDIF Optical),1 x IR ,4 x LEDs ,1 Headphone, 3 x Keys
PowerDC5V @ 2.5A with HDDsupport Li-battery & RTC
54 extended pins including I2S, I2C, SPI, CVBS, LRADC x2,UART, PS2, PWMx2, TS/CSI, IRDA, LINEIN&FMIN&MICIN, TVINx4 with 2.0 pitch connectors
PCB size: 11cm *8cm*1.4mm,very suite for installing a 2.5’ HDD
КОМПЛЕКТА СЪДЪРЖА:
1.Cubietruck main board x1
2.SATA 2.0 cable x1
3.Mini USB to OTG x1
4.Mini USB cable x1
5.USB to 1.7 mm DC jack cable x1
6.Ewell case /MINI PC/ for CubieTruckx1
7.Ultrathin Heat Sink x1
8.3.5HDD addon packagex1
9.12v 2A EU adapter
10. НDD 160GB inside /refurbished/
