Продава се - Raspberry Pi - model B
Регистриран на: Вто Окт 16, 2012 1:23 pm
Мнение Продава се - Raspberry Pi - model B
System-on-a-chip (SoC):[1] Broadcom BCM2835 (CPU + GPU + SDRAM) CPU: 700 MHz ARM11 ARM1176JZF-S core GPU: Broadcom VideoCore IV,OpenGL ES 2.0,OpenVG 1080p30 H.264 high-profile encode/decode Memory (SDRAM)iB 256 MiB USB 2.0 ports: 1(provided by the BCM2835) 2 (via integrated USB hub) Video outputs:[1] Composite video | Composite RCA, HDMI (not at the same time) Audio outputs:[1] TRS connector | 3.5 mm jack, HDMI Audio inputs: none, but a USB mic or sound-card could be added Onboard Storage: Secure Digital|SD / MMC / SDIO card slot Onboard Network:[1] None 10/100 wired Ethernet RJ45.
Цена 80лв. без коментар
Местоположение Плевен.
Изпращам по Еконт. Разходите са за сметка на купувача.
Вто Окт 16, 2012 1:39 pm
