Продава се - Raspberry Pi - ARM GNU/Linux box model B
Регистриран на: Пон Сеп 24, 2012 9:31 am
Мнение Продава се - Raspberry Pi - ARM GNU/Linux box model B
System-on-a-chip (SoC):[1] Broadcom BCM2835 (CPU + GPU + SDRAM) CPU: 700 MHz ARM11 ARM1176JZF-S core GPU: Broadcom VideoCore IV,OpenGL ES 2.0,OpenVG 1080p30 H.264 high-profile encode/decode Memory (SDRAM)iB 256 MiB (previously listed as 128 MiB for model A, but an upgrade to 256 MiB was announced on 29 Feb 2012) USB 2.0 ports: 1(provided by the BCM2835) 2 (via integrated USB hub) Video outputs:[1] Composite video | Composite RCA, HDMI (not at the same time) Audio outputs:[1] TRS connector | 3.5 mm jack, HDMI Audio inputs: none, but a USB mic or sound-card could be added Onboard Storage: Secure Digital|SD / MMC / SDIO card slot Onboard Network:[1] None 10/100 wired Ethernet RJ45 Low-level peripherals: General Purpose Input/Output (GPIO) pins, Serial Peripheral Interface Bus (SPI), I²C, I²S[2], Universal asynchronous receiver/transmitter (UART) Real-time clock:[1] None Power ratings (provisional, from alpha board): 500 mA, (2.5 W) [1] 700 mA, (3.5 W) Power source:[1] 5 V (DC) via Micro USB type B or GPIO header Size: 85.60 mm x 53.98 mm[3] (3.370 × 2.125 in) http://elinux.org/RPi_Hardware
Цена 70 лв. без коментар
Местоположение Плевен.
Изпращам по Еконт. Разходите са за сметка на купувача.
ПРОДАДЕНО
Пон Сеп 24, 2012 11:35 am
