Проблем със SSD
Мнение Проблем със SSD
Диска е OCZ TRION 100 в гаранция.
Спря да работи, общо време на ползване 2 месеца. ОС Вин7 64+виртуалки.
Не се разпознава от биос. Закачайки друг диск си работи нормално.
Заради последно правен архив преди седмица имам несъхранени данни.
Бих ги възстановил за около 2-3 дни, но това време не ми се губи отново.
Има ли оправяне на такъв диск заради данните?
Пон Фев 06, 2017 8:29 pm
Мнение Re: Проблем със SSD
Hiren's? disk?
Пон Фев 06, 2017 8:44 pm
Искай си парите.
https://www.newegg.com/Product/Product. ... 6820228135
Cons: Stops working
Cons: -Not extremely fast -Stopped working after only a year of use
Cons: completely inoperable within months
Cons: I'm a computer repair tech and I bought 5 of these for my stock in November of 2015. 3 of the 5 have failed by today's date 7/1/2016.
Cons: Bought this 7/15 from Newegg for 79.99. Built a new budget computer for my daughter. At that time was looking for an inexpensive SSD. Everything ran fine for 10 month, it completely died. Only had Win7 os and nothing else. Checked connections and in bios the ssd doesn't even exist. What a piece of JUNK. Will probably buy Samsung or crucial. Hopefully paying a little more will last longer.
Other Thoughts: I'm not going to write any pros/cons as it's a hard drive, but I had this sense 10/2015 and today I woke to see my PC at a screen saying boot media missing, the drive has died. I saying junk and avoid as this is a SSD, the ONLY I've ever had fail.
Cons: Drives completely dead and unresponsive at all after 7 short months. I guess that is what I get when you put something in a RAID 0. So I will not be recovering anything at all from these guys. I guess I should have seen this coming when my Windows boot files started to disappear.
Cons: 1 out of 5 eggs Bought 5 of these drives for a K-12. 2 of the 5 have died since October 6, 2015 02/04/2016
Cons: Failed in three months, won't show in bios. Failed catastrophically with no hope of recovering any data off the drive.
stefan63 какъв Hiren's диска си е направил харакири.
Пон Фев 06, 2017 8:48 pm
OCZ TRION или OCZ TESLA? Наскоро разправях че това е най-опасното на SSD-тата.
Ники, ако изобщо не се разпознава от компота, едва ли някакъв софтуер може да го съживи - вътре му е умряло FTL-а, и може дори и да не boot-ва докрай, за да има връзка с околния свят.
Пон Фев 06, 2017 9:38 pm
Дотук разбрахме
- дъното бутва от друг диск
- дъното не бутва от тоя диск.
Пон Фев 06, 2017 9:56 pm
Ама не се и разпознава от това дъно -> а като USB диск или на друго дъно?
Пон Фев 06, 2017 10:17 pm
Boot-ването, за което съм писал, е за вътрешния firmware в диска. Може да не стига изобщо до частта, в която влиза в работен режим и почва да отработва ATA и прочее протоколи. Има дори теоретичен шанс част от кода да е на NAND, и да е залипсвал.
Пон Фев 06, 2017 10:21 pm
bongo_x2 написа:
Пон Фев 06, 2017 10:30 pm
За първи път ми се скапва диск.
Погледнах Хирен-а но никога не съм го ползвал за такава ситуация и от прегледа не видях/разбрах кое ми трябва.
Разглобих единствения си USB3 идск, оказа се че е закован да е само УСБ, и няма как в момента да го заменя/пробвам с повредения.
На друг лаптоп с ССД, повредения също не се разпознава-> "Hard disk not installed".
Нямам ясна представа от конструкцията на SSD-та.
Ако е чип който е по захранването на диска, ще рискувам гаранцията му, ако е на чипове памет които мога да сваля и да прочета също.
Но за неща които не познавам не си струва времето..
Пон Фев 06, 2017 10:40 pm
Едва ли имаш шанс с отварянето на ССД хардуера.
Ръчкай биоса.
Пон Фев 06, 2017 10:44 pm
woody,
Ако под НАНД имаш предвид някой SPI/паралелен разпознаваем чип, на който може да му се подскаже какво да бутне, след като се наспя ще разглобя диска, м,,,,та й на гаранцията..
Пон Фев 06, 2017 10:51 pm
Ники: не, не това имам предвид, а че имаш нещо което или трябва да изхвърлиш, или да върнеш гаранционно за нова бройка. Данните, с голяма вероятност, просто ги отпиши.
Пон Фев 06, 2017 10:54 pm
Случката ме кара да задам въпроси.
От прочита в нета и мнението на woody, заради кофти случайност съм купил/ползвал неправилен диск.
Явно ще купя друг диск, най вероятно от споменати в друга тема Samsung Evo...
За да не попадам пак в ситуация на убит диск да обясня.
Когато сглобих системата уж за кратко сложих този диск.
Освен основната сисетма висят и две виртуалки на XP.
В Вин7 има програма монитор която показва натоварване на проц, диск, нет и т.н.
Направи ми впечатление че заради виртуалките има непрекъснат може би монотонен обмен с диска, като периода в момента не мога да уточня без да съм в системата.
Възможно ли е с този множествен достъп до диска да се съкращава времето на живот?
Пон Фев 06, 2017 11:15 pm
Всеки запис (и на теория и четенето) скъсява живота на NAND-овете, но при теб по-скоро е бъгав firmware и евентуално падане на захранването/ресет в неподходящ момент.
Ако те притеснява животът, при работещо SSD можеш да му гледаш вътрешните броячи.
Пон Фев 06, 2017 11:59 pm
Като изключа момента на инсталация, когато е имало няколко рестарта за ден, след влизането в нормална работа, за двата месеца употреба, рестартите са били между 2-5 дни.
Т.е. в нормален режим 10-15 рестарта за тези два месеца, в останалото време работа-слиип.
Имам дискове в подобен режим, 12 години(PATA/САТА)и 3 години SSD(ADATA250) и др., работещи без проблем, няма как тези рестарти да тежат.
Не ми се иска да призная, че пренебрегвайки предварително проучване и архивиране, съм уцелил куц диск.
В моемнта на синия екран компа не е рестартиран поне ден.
Вто Фев 07, 2017 12:21 am
