гигадървен купон-що е то
Мнение Re: гигадървен купон-що е то
Като гледам работата е сериозна. am stereo се е заел да проектира дънни платки. Я кажи от Интел ли те отсорснаха да им свършиш работата?
Пон Фев 13, 2017 5:27 pm
точно на тия съм едосан сега,щото взе да исчезва лан картата им и сега пак включих кабела в дъното...пфу
Пон Фев 13, 2017 10:32 pm
https://blog.asset-intertech.com/test_d ... signs.html :arrow: ИзображениеXDP Access
ИзображениеTP-XDP 3BR is the latest revision of ITP-XDP hardware. It is used for Run Control and OBS trace collection for Intel processors. It also provides capabilities for some remote platform control through supported platform hooks. Intel ITP PDT software is required - software is sold separately.
https://designintools.intel.com/product ... dapter.htm
3 meter USB2 cable included.
Power adapter and cord set included.
The ITP-XDP 3BR is functionally equivilant to the older ITP-XDP 3B.
The traditional means for doing hardware-assisted debug on Intel designs is via the proprietary 60-pin connector called the XDP (short for eXtended Debug Port). Although it is rather dated, the public Debug Port Design Guide for UP/DP Systems document (June 2006) describes the essence of the JTAG and sideband signals needed to connect to XDP.https://software.intel.com/en-us/forums/watercooler-catchall/topic/309473 :idea: TP60C is a Debug Adapter designed to easily interface to an ITP60C footprint on a circuit board. The ITP60C footprint is a modified version of the ITP-XDP 60 pin debug port footprint and requires additional mounting and alignment holes (see footprint specification). The adapter contains a debug port connector to allow an ITP-XDP 3BR Pod to be plugged in for debug/validation activities. The ITP60C adapter is designed for use in systems where the 60 pin debug port connector has been removed or no-popped on the circuit board. :arrow: https://software.intel.com/en-us/articl ... r-families :roll: ИзображениеFlash Programming
Selected Intel® Atom processor types allow flash memory programming through the JTAG debugger probe. Please consult the release notes for details on supported processors and Flash devices.
Сря Май 15, 2019 8:35 am
http://www.flashtech.com.my/Asset.html
Сря Май 15, 2019 12:36 pm
Местоположение: Бургас
Тия нагъгрените писти ги правят в два случая: единият е за да изравнят дължината на линиите и сигналите да пристигат едновременно, а втория случай е точно обратен- намотаното е закъснителна линия, за да може да има няколко нано-секунди разлика между между светването на зеленото на светофара и клаксона на пернишкия голф.
Сря Май 15, 2019 1:21 pm
ИзображениеIntel / Altera LP6 Logic Programmer Card :arrow: Features:
Generate Programming Waveforms and Voltages for the MPU
Install Into Any Full-Length Computer Expansion Slot
Altera MAX 9000, 7000, 3000A and Classic Programmer
The Intel / Altera LP6 Logic Programmer card generates programming waveforms and voltages for the MPU. The software-controlled card can be installed into any full-length computer expansion slot in an IBM PC or compatible computer. The LP6 card is available as part of PL-ASAP2 or individually.ИзображениеИзображениеALTERA MPU - MASTER PROGRAMMING UNIT. This is the complete "PL-ASAP2" Kit.
Comes with the very rare "Altera LP6" Logic Programming card.
Model "PL-ASAP2". In Mint condition.
Original MPU model. (Windows PC ISA slot is required for the LP6 logic programming card.)
Used in Industrial and Military grade electronics repair or development. Program Vintage Altera CPLD's & also FPGA configuration devices. An essential tool for Industrial or Military infrastructure Maintenance and Repair RMA Labs.
Maintain Embedded systems, PLC's and SBC's that still rely on these Altera components. Apparently you can program Logic devices like the popular Altera Classic, MAX5000, MAX7000, MAX9000 series of CPLD's. It can also be used for programming Altera FLEX series EEPROM configuration devices.
Also used for Re-enabling the JTAG interface on various Altera MAX devices, suffering from JTAG-LOCKOUT. A valuable programming system for Industrial Technicians, or for Military RMA Labs.
See the Altera Website for specific details. http://www.altera.com
Пет Сеп 25, 2020 6:18 pm
