ATmega16 и LCD дисплей- какво бъркам?
Регистриран на: Пет Яну 16, 2015 12:34 pm
Мнение ATmega16 и LCD дисплей- какво бъркам?
Здравейте,
от 1 седмица се мъча да "подкарам" LCD дисплей с един ATmega16, но без успех. Все още съм начинаещ и за това използвам готова програма от нета. Ето я:
// Program to display a single alphabet ‘A’ on LCD
LCD data transfer through 8 bit mode
Writing a single letter A on LCD
LCD DATA port----PORT A
ctrl port------PORT B
rs-------PB0
rw-------PB1
en-------PB2
#define F_CPU 4000000UL
#include<avr/io.h>
#include<util/delay.h>
#define LCD_DATA PORTA // LCD data port
#define ctrl PORTB
#define en PB2 // enable signal
#define rw PB1 // read/write signal
#define rs PB0 // register select signal
void LCD_cmd(unsigned char cmd);
void init_LCD(void);
void LCD_write(unsigned char data);
int main()
DDRA=0xff; // making LCD_DATA port as output port
DDRB=0x07; // making signal as out put
DDRC=0xFF;
PORTC=0xFF; // индикация, че микроконтролера работи
_delay_ms(500);
PORTC=0x00;
_delay_ms(500);
PORTC=0xFF;
_delay_ms(500);
PORTC=0x00;
_delay_ms(500);
init_LCD(); // initialization of LCD
_delay_ms(50); // delay of 50 milli seconds
LCD_write('A'); // call a function to write A on LCD
_delay_ms(500);
PORTC=0x00;
_delay_ms(500);
PORTC=0xFF;
_delay_ms(500);
PORTC=0x00;
_delay_ms(500);
return 0;
void init_LCD(void)
LCD_cmd(0x38); // initialization of 16X2 LCD in 8bit mode
_delay_ms(1);
LCD_cmd(0x01); // clear LCD
_delay_ms(1);
LCD_cmd(0x0E); // cursor ON
_delay_ms(1);
LCD_cmd(0x80); // ---8 go to first line and --0 is for 0th position
_delay_ms(1);
return;
LCD_DATA=cmd;
ctrl =(0<<rs)|(0<<rw)|(1<<en); // RS and RW as LOW and EN as HIGH
_delay_ms(1);
ctrl =(0<<rs)|(0<<rw)|(0<<en); // RS, RW , LOW and EN as LOW
_delay_ms(50);
return;
LCD_DATA= data;
ctrl = (1<<rs)|(0<<rw)|(1<<en); // RW as LOW and RS, EN as HIGH
_delay_ms(1);
ctrl = (1<<rs)|(0<<rw)|(0<<en); // EN and RW as LOW and RS HIGH
_delay_ms(50); // delay to get things executed
return ;
Явно бъркам нещо с фусовете, но как ли не ги въртях (използвах и калкулатора). На порт "C" съм сложил светодиод, който индикира, че все пак контролера работи. Програмата е взета от тук: http://www.engineersgarage.com/embedded/avr-microcontroller-projects/interface-lcd-circuit Увеличавах и времената между различните команди, пробвах и с други готови кодове, но пак без успех. Дисплеите са 2бр. C16217A и са чисто нови. Вече нямам идеи, моля помагайте!
Пет Яну 16, 2015 1:09 pm
Мнение Re: ATmega16 и LCD дисплей- какво бъркам?
Купи си това: http://www.ebay.com/itm/1P-HOT-USB-Nano ... 3f41c2b5ef
И пробвай с него.
Иначе проблема може да е в:
1. фусовете
2. самата програма
3. свързването на ATmega16 (кондензатори, ресет, кварц ...)
4. свързването на LCD-то.
5. Контраста на LCD-то.
6. инициализацията на LCD-то.
7. нито едно от изброените.
Пет Яну 16, 2015 2:09 pm
1. фусовете
2. самата програма // Пробвал съм с различни готови програми
3. свързването на ATmega16 (кондензатори, ресет, кварц ...) // Използвам вътрешния RC осцилатор, но съм пробвал и с различни кварцове.
4. свързването на LCD-то. // Със сигурност проблема не е тук
5. Контраста на LCD-то. // Използвам тример 10k ohm м/у +5v и GND
Захранването е стабилизирано, но както казах използвам светодиод, който индикира, че контролера работи.
Възможно ли е LCD драйвера да е различен? Доколкото знам има стандарт въведен от Hitachi
Пет Яну 16, 2015 2:41 pm
Има стандарт но всеки си го тълкува както си знае. Инициализацията на новите LCD-та се различава малко от на Hitachi и не са съвместими.
Пет Яну 16, 2015 2:58 pm
Регистриран на: Чет Окт 02, 2008 10:24 pm
Погледни инициализацията от Ардуино библиотеките за HD44780
ако дисплея е такъв де.
Реда и таймингите на командите за 8-бит режим.
https://code.google.com/p/arduino/sourc ... rystal.cpp
Пет Яну 16, 2015 3:07 pm
Няма смисъл от 8 битов режим. Да скача направо на 4 битов.
Пет Яну 16, 2015 3:23 pm
Ще купя дисплей, който да съм сигурен че е с този HD44780 драйвер. Силно се надявам причината да е в него. До няколко дена ще пиша за резултата.
Пет Яну 16, 2015 8:31 pm
Инициализацията нещо не ми харесва, вижда ми се малко постна. Първоначално имаше няколко команди дето искаха по 5 милисекунди пауза. Това по спомен де, нямам пред мен таблицата да погледна.
Пет Яну 16, 2015 9:37 pm
Регистриран на: Сря Фев 06, 2013 10:25 am
цък
Пет Яну 16, 2015 10:36 pm
Я пробвай да замениш твоята функция с тази.
void init_LCD(void)
LCD_cmd(0x38);
_delay_ms(50);
LCD_cmd(0x38);
_delay_ms(10);
LCD_cmd(0x38);
_delay_ms(10);
LCD_cmd(0x6);
_delay_ms(10);
LCD_cmd(0x14);
_delay_ms(10);
LCD_cmd(0xf);
_delay_ms(10);
LCD_cmd(0x1);
_delay_ms(10);
Пет Яну 16, 2015 11:06 pm
Най после успях. Използвах линка на колегата vgeorgiev. Благодаря на всички които се опитахте да помогнете. Форума е интересен, надявам се и аз скоро да успея да помагам със съвети :)
Нед Яну 18, 2015 11:32 pm
ike написа:
Да, и аз съм забелязал, че има девиации. Фактически всеки производител си има некви особености. Като цяло съм на принципа - слагам стандартния драйвер и купувам LCD-та докато не попадна на такова, дето върви с драйвера. :)
Пон Яну 19, 2015 9:41 pm
Аз си ги писах процедурите, но за х52 (АТ8052)
Сря Яну 21, 2015 6:14 pm
