Дата и час: Сря Ное 25, 2026 2:23 pm
[ 8 мнения ] |
Как да се инициализира диспеля като 16x1
kostov
Регистриран на: Нед Юни 03, 2012 10:28 pm Мнения: 99
Какво трябва да се промени в инициализиращата подпрограма, за да работи 16х1 дисплеят в 16х1 режим. Програмата в микроконтролера PIC16F628A работи като за 16х1 дисплей, но дясната половина на изображението не се изобразява.  |  |  |  | Код: ; ; ***************************************************************************** ; * * ; * Purpose: Power on initialization of Liquid Crystal Display. The LCD * ; * controller chip must be equivalent to an Hitachi 44780. The * ; * LCD is assumed to be a 8x1 or a 16x1 display. * ; * * ; * Input: None * ; * * ; * Output: None * ; * * ; ***************************************************************************** ;
init_LCD call wait_64ms ; Wait for LCD to power up movlw CMD_RESET_LCD ; LCD init instruction (First) movwf PORTB ; Send to LCD via RB3..RB0 bsf PORTB,LCD_e ; Set the LCD E line high, call wait_64ms ; wait a "long" time, bcf PORTB,LCD_e ; and then Clear E movlw CMD_RESET_LCD ; LCD init instruction (Second) movwf PORTB ; Send to LCD via RB3..RB0 bsf PORTB,LCD_e ; Set E high, call wait_32ms ; wait a while, bcf PORTB,LCD_e ; and then Clear E movlw CMD_RESET_LCD ; LCD init instruction (Third) movwf PORTB ; Send to LCD via RB3..RB0 bsf PORTB,LCD_e ; Set E high, call wait_32ms ; wait a while, bcf PORTB,LCD_e ; and then Clear E movlw PICEL_IFC1 ; Set the LCD for 4-bit mode I/O movwf PORTB ; Send to LCD via RB3..RB0 bsf PORTB,LCD_e ; Set E high, call wait_16ms ; wait a while, bcf PORTB,LCD_e ; and then Clear E movlw PICEL_IFC2 ; Set operational characteristics of LCD call cmnd2LCD ; Send command in w to LCD movlw PICEL_DISPLAY_OFF ; Display off, cursor and blink off call cmnd2LCD ; Send command to LCD movlw CMD_CLEAR_LCD ; Clear and reset cursor call cmnd2LCD ; Send command in w to LCD movlw PICEL_CURSOR_RT ; Set cursor to move right, no display shift call cmnd2LCD ; Send command in w to LCD
movlw PICEL_DISPLAY_ON ; Display on, cursor on, blink off call cmnd2LCD ; Send command to LCD return ; Done!
| Нед Дек 02, 2012 8:23 pm |
ji4ka
 Re: Как да се инициализира диспеля като 16x1
Втората половина на дисплея започва на друг адрес , в даташита на дисплея трябва да се види изместването колко беше. Това не касае изнициализацията ,а адресацията на символите в дисплейния РАМ.
| Нед Дек 02, 2012 9:16 pm |
ike
Вторите 8 символа са на адрес 40(втори ред). Диспля трябва да се инициализира, като двуредов 5х8.
| Нед Дек 02, 2012 10:15 pm |
kostov
Ето го целият код, ако някой може да помогне къде и какво трябва да се промени: Ето и datasheet-а на дисплея: AC161AYA
| Нед Дек 02, 2012 11:14 pm |
didofen
Регистриран на: Вто Юни 27, 2006 11:13 am Мнения: 381 Местоположение: Варна
като прибавиш старшата единица, указваща адрес за индикация, става 0xC0
| Пон Дек 03, 2012 9:53 am |
kostov
Понеже не разбирам от програмиране, моля ако може някой да преправи кода с необходимите промени. Благодаря предварително!
| Пон Дек 03, 2012 8:27 pm |
ji4ka
Какво ти се изписва при калибрацията с бутона? Последните 8 квадратчета светят ли? Светят - в смисъл да се виждат черните им точки при засилен контраст.
| Пон Дек 03, 2012 11:02 pm |
kostov
10,000. като най-лявата позиция е свободна. С контраста не съм пробвал, в момента съм зашил една по-нова версия на сорса и с нея работи нормално. При нея поне лесно се избира типа дисплей - с коментиране и откоментиране на съответен ред. Само функциите са малко по-други.
| Пон Дек 03, 2012 11:28 pm |
[ 8 мнения ] |
