Дата и час: Сря Ное 25, 2026 7:13 pm
bobi13
Регистриран на: Сря Авг 07, 2013 1:11 am Мнения: 41
 Re: Проблем с таймер
#include "c8051F020.h" #include <intrins.h> //#include "delay.h"
unsigned char bdata BUT1FL = 0x100; sbit BUT1FL_0 = BUT1FL^0; sbit BUT1FL_1 = BUT1FL^1; sbit BUT1FL_2 = BUT1FL^2; sbit BUT1FL_3 = BUT1FL^3; sbit BUT1FL_4 = BUT1FL^4; sbit BUT1FL_5 = BUT1FL^5; sbit BUT1FL_6 = BUT1FL^6; sbit BUT1FL_7 = BUT1FL^7;
unsigned char bdata BUT2FL = 0x101; sbit BUT2FL_0 = BUT2FL^0; sbit BUT2FL_1 = BUT2FL^1; sbit BUT2FL_2 = BUT2FL^2; sbit BUT2FL_3 = BUT2FL^3; sbit BUT2FL_4 = BUT2FL^4; sbit BUT2FL_5 = BUT2FL^5; sbit BUT2FL_6 = BUT2FL^6; sbit BUT2FL_7 = BUT2FL^7;
unsigned char bdata FFP = 0x102; sbit FFP_0 = FFP^0; sbit FFP_1 = FFP^1; sbit FFP_2 = FFP^2; sbit FFP_3 = FFP^3; sbit FFP_4 = FFP^4; sbit FFP_5 = FFP^5; sbit FFP_6 = FFP^6; sbit FFP_7 = FFP^7;
unsigned char bdata FSS = 0x103; sbit FSS_0 = FSS^0; sbit FSS_1 = FSS^1; sbit FSS_2 = FSS^2; sbit FSS_3 = FSS^3; sbit FSS_4 = FSS^4; sbit FSS_5 = FSS^5; sbit FSS_6 = FSS^6; sbit FSS_7 = FSS^7; unsigned char bdata CNTFSSB4 = 0x104; unsigned char bdata CNTB2 = 0x105; unsigned char bdata CNTB1 = 0x106; unsigned char bdata CNTFFPB3 = 0x107; void but_plus(); // Button up void butplus (); void but_minus(); // Button down void butminus (); void but_FP(); // Button frquency/pulse selector void but_Start_Stop(); void Start_Stop(); void Master_button();
sbit FP = P1^5; // Frequency/Pulse width selector sbit Start = P1^6; // Start/stop button for signal sbit Plus = P2^3; // Plus sbit Minus = P2^4; // Minus sbit Valve_on = P0^5;//output for valve
sbit LED = P1^7; // Pulse indicator
unsigned char c; unsigned int CNTIMP; unsigned int CNTIMP1; unsigned int CNTFRQ;
unsigned int FRQ1; unsigned int FRQ;
#define LCD_DATA P3 sbit LCD_RS = P0^2; sbit LCD_EN = P0^4;
unsigned char data_ind[3]; char init_value; #define lcd_delay 400
void delay(unsigned int j)//Просто закъснение за инициализацията на ЛЦД-то. минава само веднъж когато се инициализира { unsigned int i=0; for(i=0;i<j;i++); }
void itoa(int number) // превръщам шестайсетично в десетично { data_ind[2] = '\0'; data_ind[1] = (number%10); data_ind[0] = ((number%100) - data_ind[1])/10;
data_ind[1] = data_ind[1] + '0'; data_ind[0] = data_ind[0] + '0';
void LCD_show() { itoa(CNTFRQ); // Записва стойстта на клетктата CNTFRQ в масива. lcd_goto(0x00); lcd_puts("FRQ");
lcd_goto(0x05); lcd_puts(data_ind);
lcd_goto(0x09); lcd_puts("Hz");
itoa(CNTIMP); lcd_goto(0x40); lcd_puts("PWM");
lcd_goto(0x45); lcd_puts(data_ind); lcd_goto(0x49); lcd_puts("ms"); }
void Start_Stop(void) // Функция за стартиране на Т1 за да започне да генерира импулс с определени параметри { if (Start==0) { TR1=1; //Enable } else { TR1=0; // Disable }
void FP_Selector(void) // Изписвам на дисплея какво искам да променям - честота или импулс {
if (FP==0) { // Start only Timer0 lcd_goto(0x4d); lcd_puts(" "); lcd_goto(0x4e); lcd_puts(" "); lcd_goto(0x0d); lcd_puts("<<");
} else { lcd_goto(0x0d); lcd_puts(" "); lcd_goto(0x0e); lcd_puts(" "); lcd_goto(0x4d); lcd_puts("<<");
void Timer_Init() { TMOD = 0x11; // Timer0/Timer1 16 bit IP = 0x08; // Най- висок приоритет на Т1 OSCICN = 0x07; // 16Мхц вътрешен осцилатор WDTCN = 0xDE; WDTCN = 0xAD; IE = 0x8A; // timer0/1 interrupt
void Port_init() {
P0MDOUT = 0x3C; P1MDOUT = 0x06; P2MDOUT = 0x18; P3MDOUT = 0x0F; XBR2 = 0x40;
void main(void) { TR0=0; // TR1=0; //TL1 = 0x65; //Lower Byte //TH1 = 0xFD; //Upper Byte // TH1 = 0xFA; //1ms // TL1 = 0xCB; // TH0 = 0xE5;//5ms // TL0 = 0xF5; Port_init(); Timer_Init(); lcd_init(); TR0=1; Valve_on = 1; CNTFRQ = 1; // Начална ст-ст на честота CNTIMP =1; // Начална ст-ст на импулс
while(1);
void timer1_ISR(void) interrupt 3 // Таймер на 1мс, когато се стартира герерира прекъсване на 1мс, което ми представлява стъпката с която променям импулса {
TH1 = 0xFA; //1ms TL1 = 0xCB;
FRQ1 = FRQ1 - 1; if(FRQ1 == 0) { Valve_on = 1; // valve OFF FRQ1=FRQ; CNTIMP1=CNTIMP; CNTIMP1++; } CNTIMP1 = CNTIMP1 - 1; if(CNTIMP1 == 0) { CNTIMP1=CNTIMP; Valve_on = 0; // valve ON
} } void timer0_ISR (void) interrupt 1 { TH0 = 0xE5;//5ms TL0 = 0xF5;
Master_button();// Следя дали има вдигнат флаг, че е натиснат някой от бутонитте - плюс, минус, старт/стоп LCD_show();// Извежда надпис на LCD FP_Selector();//Изписвам на дисплея какво искам да променям - честота или импулс but_plus();//Чрез флагове следя дали бутона е наистина настиснат или е някакъв артефакт. Вътре има брояч, като след всяко минаване през бутона се намалява - CNTB1=1; В този случай ще направи 10мс закъснение преди да го обработи. Същото се отнася и за другите два бутона отдолу. but_minus();// but_Start_Stop();//
} void Master_button() {
if(Plus==0) { BUT1FL_7=1; } else { BUT1FL=0; } if(Minus==0) { BUT2FL_7=1; } else { BUT2FL=0; }
if(Start==0) { FSS_7=1; } else { FSS=0; }
void broiach_FRQ() // Функция, която ми определя каква честота ще подам. { FRQ = 1000/CNTFRQ;//брояч за честотата в зависимост от таймер 1. Формулата е почти вярна. Има отклоение в честота като я гледам на осцилоскопа FRQ1 = FRQ;
void butplus () // Броя за увеличаване на честота и импулса в зависимост от положение на бутона FP - честота или импулс. От тук се взимат стойностите за да се покажат на екрана CNTFRQ и CNTIMP. В зависимост от това колко пъти съм натиснал бутона с толкова ще се увеличи съответната променлива {
if (FP==0) { if(CNTFRQ==30) {;} else { CNTFRQ = CNTFRQ+1; broiach_FRQ();
} } else //PWM { if(CNTIMP==30) {;} else { CNTIMP = CNTIMP+1; } } }
void butminus () // Бутон за намаляване на стойността. Същата логика като бутон плюс { if (FP==0) { if(CNTFRQ==1) {;} else { CNTFRQ = CNTFRQ-1; broiach_FRQ();
} } else //PWM { if(CNTIMP==1) {;} else { CNTIMP = CNTIMP-1;
BUTTON FLAG ======================================*/ // Чрез флагове определям дали наистина бутона е натиснат, ако не е натиснат просто я прескача. Преминава през бутоните на всеки 5мс, в зависимост от таймер 1 void but_Start_Stop () // BUTTON FREQ OR PWM { if(FSS_7==1) { if(FSS_5==0) { if(FSS_0==0) //Стартира 10мс закъснение за проверка дали наистина е натиснат бутона { FSS_0=1; CNTFSSB4=2; } else { if (FSS_2==1) { FSS_5=1; // Start = ~Start; Start_Stop(); } else { CNTFSSB4--; if(CNTFSSB4==0) { FSS_2=1; } } } } } else { Start_Stop(); } }
void but_plus () { if(BUT1FL_7==1) { if(BUT1FL_5==0) { if(BUT1FL_0==0) { BUT1FL_0=1; CNTB1=1; } else { if (BUT1FL_2==1) { BUT1FL_5=1; butplus(); } else { CNTB1--; if(CNTB1==0) { BUT1FL_2=1; } }}}}}
void but_minus () { if(BUT2FL_7==1) { if(BUT2FL_5==0) { if(BUT2FL_0==0) { BUT2FL_0=1; CNTB2=1; }
else { if (BUT2FL_2==1) { BUT2FL_5=1; butminus(); } else { CNTB2--; if(CNTB2==0) { BUT2FL_2=1; } }}}}}
| Вто Сеп 08, 2015 7:10 pm |
stefan63
unsigned char bdata CNTFSSB4 = 0x104; Това трябва да е променлива с адрес 0х104 ? Според мен не се пише така.
sbit FP = P1^5; това какво е? Според мен пак е некоректно, ама не съм сигурен, Ц-то го ползвам само за ПК.
500 реда код няма кой да ти прочете. Отделно правиш копи/пасте и разместането на Ц се губи - има бутон за постване на код. Намери темата за дебоунсването и я прочети.
| Вто Сеп 08, 2015 7:22 pm |
bobi13
sbit FP = P1^5; Това е начин на обяванене на компилатора. В този случай бутона се напира на пин 5 порт 1 Това трябва да е променлива с адрес 0х104 ? - Да това означава и така се пише поне тук.
| Вто Сеп 08, 2015 7:25 pm |
stefan63
Качи описанието , дето го пише това . За мене е инициализиране ,ама какво разбирам аз от Ц, де.
| Вто Сеп 08, 2015 7:29 pm |
stefan63
И да обяваваш адрес на променлива в Ц - трябва да имаш сериозна причина .
| Вто Сеп 08, 2015 7:31 pm |
bobi13
за да знам точно къде съм сложил променливата, може и без адреса, но мисля че това не пречи. Файала който съм качил е описано за дефиницията на порта. Погледни // Keil C51 // http://www.keil.com#elif defined __C51__
| Вто Сеп 08, 2015 7:37 pm |
stefan63
Виждам това #define SBIT(name, addr, bit) sbit name = addr^bit
Може би твоите дефиниции за битове да са верни. Аз не бих го написал така - бих ползвал "define" , но сигурно някой по-сведущ ще го коментира по-добре.
В този файл не зърнах как unsigned char xxx=0x104; описва променлива с адрес 104х. За мене е друго.
| Вто Сеп 08, 2015 7:48 pm |
bobi13
Няма го, но просто го знам, че в този компилатор е така. Ползвал съм го няколко пъти без проблем
| Вто Сеп 08, 2015 7:59 pm |
stefan63
| Вто Сеп 08, 2015 8:08 pm |
bobi13
Да, същото е.
| Вто Сеп 08, 2015 8:11 pm |
stefan63
Тогава unsigned char bdata CNTFSSB4 = 0x104; присвоява нещо (най вероятно 4) на някаква променлива.
| Вто Сеп 08, 2015 8:18 pm |
bobi13
Казвам му къде се намира дадена променлива в адреса. unsigned char bdata BUT1FL = 0x100; // адрес sbit BUT1FL_0 = BUT1FL^0; // на бит 0 се намира BUT1FL_0. sbit BUT1FL_1 = BUT1FL^1; Подобно е писането като в h файловете за микроконтролерите. Например това е взето от h файла на моят контролер  |  |  |  | Код: // SPI0CN 0xF8 SBIT (SPIF, SFR_SPI0CN, 7); // SPI 0 Interrupt Flag SBIT (WCOL, SFR_SPI0CN, 6); // SPI 0 Write Collision Flag SBIT (MODF, SFR_SPI0CN, 5); // SPI 0 Mode Fault Flag SBIT (RXOVRN, SFR_SPI0CN, 4); // SPI 0 Rx Overrun Flag SBIT (TXBSY, SFR_SPI0CN, 3); // SPI 0 Tx Busy Flag SBIT (SLVSEL, SFR_SPI0CN, 2); // SPI 0 Slave Select SBIT (MSTEN, SFR_SPI0CN, 1); // SPI 0 Master Enable SBIT (SPIEN, SFR_SPI0CN, 0); // SPI 0 SPI Enable |  |  |  |  |
| Вто Сеп 08, 2015 8:30 pm |
stefan63
това не е вярно, за останалото - не знам.
| Вто Сеп 08, 2015 8:40 pm |
nordic
Регистриран на: Пон Дек 22, 2014 10:53 pm Мнения: 4
The bdata memory type may be used to declare variables only. You may not declare bdata functions. This memory is directly accessed using 8-bit addresses and is the on-chip bit-addressable RAM of the 8051. Variables declared with the bdata type are bit-addressable and may be read and written using bit instructions.
Variables declared bdata are located in the BDATA memory class.
| Вто Сеп 08, 2015 8:42 pm |
stefan63
Е, това на класическия '51 са 16 байта-128 бита, ако не се лъжа. Не виждам смисъл на процесор с xdata 4kB да разчиташ на тази памет, още повече на Ц. Трябва да си много навътре в нещата ,за да опреш до това. От друга страна - разполагането на битови флагове позволява (на компилатора )използването на битовите особености/обработка на '51 . Та зависи де.
| Вто Сеп 08, 2015 8:58 pm |
