TheWizard
 GSM Android модул
Quectel SC20 -Multi-mode Smart LTE Module with Wi-Fi & Bluetooth
OS Android 5.1 SoC — Qualcomm quad-core 1.1 GHz Flash - 8 Gb Ram - 8 Gb
WLAN 2.4G, 802.11 b/g/n (SC20-CE) 2.4G/5.8G, 802.11 a/b/g/n (SC20-E/-A/-AU/-J)* BT BT2.1+EDR/3.0/4.1 LE GNSS GPS/GLONASS/BeiDou
LCM 4-lane MIPI_DSI, up to 1.5Gbps for each HD (720P) @60fpbs Camera Use MIPI_CSI, up to 1.5Gbps per lane Support two cameras: 2-lane MIPI_CSI for rear camera, up to 8MP 1-lane MIPI_CSI for front camera, up to 2MP Touch Panel Capacitive-screen Audio MP3, AAC, AAC+, eAAC, AMR-NB, - WB, G.711, WMA 9/10 Pro Video Encode: 30fps 720P (H.264), 30fps WVGA (MPEG-4/VP8) Decode: 30fps 1080P (H.264/MPEG-4/VP8/H.265 DivX4/5/6), 30fps WVGA (H.263) USB 2.0 Device ×1, high Speed, 480Mbps I2C ×3 USIM ×2, support 1.8/2.95V GPIO ×25 UART ×2, high-speed UARTs SDIO ×1, 3.0, 4bit SDIO PWRKEY Antenna 4 pads for Main Antenna, Diversity Antenna, GNSS Antenna and Wi-Fi/BT Antenna, respectively ADC ×3 (BAT_SNS, BAT_THERM, ADC)
Approval CCC/CE*/FCC*/GCF*/PTCRB*/AT&T*/ACMA RCM*/Verizon*
| Пет Яну 27, 2017 12:47 pm |
Grubi
 Re: GSM Android модул
Къде го продават това и колко струва? Линк някакъв?
| Пет Яну 27, 2017 12:59 pm |
MYXATA
| Пет Яну 27, 2017 1:02 pm |
TheWizard
за информация COMET
| Пет Яну 27, 2017 1:04 pm |
Grubi
Илко да каже значи...
| Пет Яну 27, 2017 1:07 pm |
Ужастъ. Андроид. Това не го ли забраниха бре?
| Пет Яну 27, 2017 1:25 pm |
Grubi
не и по зле става  професорите само за това ме питат, как да си показват измерванията в телефона
| Пет Яну 27, 2017 4:16 pm |
ike
Този Smart LTE модул може ли да работи с GSM операторите в Европа?
| Пет Яну 27, 2017 5:30 pm |
ilkor
SC20-CE - китайска версияFDD LTE: B1/B3/B8 TDD LTE: B38/B39/B40/B41 TDSCDMA: B34/B39 EVDO/CDMA: BC0 WCDMA: B1/B8 GSM: 900/1800MHz SC20-E - европейска версияFDD LTE: B1/B3/B5/B7/B8/B20 TDD LTE: B38/B40/B41 WCDMA: B1/B5/B8 GSM: 850/900/1800/1900MHz SC20-A САЩFDD LTE: B2/B4/B5/B7/B12/B13/B25/B26 WCDMA: B1/B2/B4/B5/B8 GSM: 850/1900MHz SC20-AU АвстралияFDD LTE: B1/B3/B5/B7/B8/B28 TDD LTE: B40 WCDMA: B1/B2/B5/B8 GSM: 850/900/1800/1900MHz SC20-J ЯпонияFDD LTE: B1/B3/B8/B18/B19/B26 TDD LTE: B41 WCDMA: B1/B6/B19 Документация: http://www.quectel.com/Qdownload/SC20.html
| Пет Яну 27, 2017 7:23 pm |
деца, обърнете внимание на звездичките в редчето Approval. WiFi е SIMO
Илко, благодаря за бързата информация. дали знаеш какво е поведението на модула, когато върви (войс) кол по едната СИМ карта, какво става с другата? дали върви сигнализация (връща BUSY) или е пълен ступор (абоната е недостъпен)?
дали имат планове, освен андроид, да пуснат и нещо друго (лайнукс, примерно)
| Пет Яну 27, 2017 8:49 pm |
TheWizard
Звездичките значат - Under development - демек ще го бъде.... копирах текста за бърза информация Ами той си е линукс с андроид шарения... не съм чел подробна информация за "софта" и възможностите, но сигурно може и да има (после) линукс плюс и без шарения Без шарения, сигурно може да се спре зареждането на андроид часта и да си остане на терминал линукс
| Пет Яну 27, 2017 9:08 pm |
gicho
| Съб Яну 28, 2017 7:33 pm |
radolin
Ето тук има събрана информация и мейлинг лист на хора, които се интересуват от подобни модули: http://osmocom.org/projects/quectel-modems/wiki
| Сря Фев 01, 2017 12:58 am |
