GSM Android модул
Мнение GSM Android модул
Quectel SC20 -Multi-mode Smart LTE Module with Wi-Fi & Bluetooth
OS Android 5.1
SoC — Qualcomm quad-core 1.1 GHz
Flash - 8 Gb
Ram - 8 Gb
WLAN 2.4G, 802.11 b/g/n (SC20-CE)
2.4G/5.8G, 802.11 a/b/g/n (SC20-E/-A/-AU/-J)*
BT BT2.1+EDR/3.0/4.1 LE
GNSS GPS/GLONASS/BeiDou
LCM 4-lane MIPI_DSI, up to 1.5Gbps for each
HD (720P) @60fpbs
Camera Use MIPI_CSI, up to 1.5Gbps per lane
Support two cameras:
2-lane MIPI_CSI for rear camera, up to 8MP
1-lane MIPI_CSI for front camera, up to 2MP
Touch Panel Capacitive-screen
Audio MP3, AAC, AAC+, eAAC, AMR-NB, - WB, G.711,
WMA 9/10 Pro
Video Encode: 30fps 720P (H.264), 30fps WVGA (MPEG-4/VP8)
Decode: 30fps 1080P (H.264/MPEG-4/VP8/H.265
DivX4/5/6), 30fps WVGA (H.263)
USB 2.0 Device ×1, high Speed, 480Mbps
I2C ×3
USIM ×2, support 1.8/2.95V
GPIO ×25
UART ×2, high-speed UARTs
SDIO ×1, 3.0, 4bit SDIO
PWRKEY
Antenna 4 pads for Main Antenna, Diversity Antenna, GNSS Antenna
and Wi-Fi/BT Antenna, respectively
ADC ×3 (BAT_SNS, BAT_THERM, ADC)
Approval CCC/CE*/FCC*/GCF*/PTCRB*/AT&T*/ACMA RCM*/Verizon*
20170127_081840.jpg [ 4.44 MiB | Прегледано 6257 пъти ]
20170127_081826.jpg [ 4.84 MiB | Прегледано 6257 пъти ]
Пет Яну 27, 2017 12:47 pm
Мнение Re: GSM Android модул
Къде го продават това и колко струва? Линк някакъв?
Пет Яну 27, 2017 12:59 pm
http://www.quectel.com/company/distributors.aspx
Пет Яну 27, 2017 1:02 pm
за информация COMET
Пет Яну 27, 2017 1:04 pm
Илко да каже значи...
Пет Яну 27, 2017 1:07 pm
Ужастъ. Андроид. Това не го ли забраниха бре? :D
Пет Яну 27, 2017 1:25 pm
не и по зле става :) професорите само за това ме питат, как да си показват измерванията в телефона
Пет Яну 27, 2017 4:16 pm
Този Smart LTE модул може ли да работи с GSM операторите в Европа?
Пет Яну 27, 2017 5:30 pm
SC20-CE - китайска версия
FDD LTE: B1/B3/B8
TDD LTE: B38/B39/B40/B41
TDSCDMA: B34/B39
EVDO/CDMA: BC0
WCDMA: B1/B8
GSM: 900/1800MHz
SC20-E - европейска версия
FDD LTE: B1/B3/B5/B7/B8/B20
TDD LTE: B38/B40/B41
WCDMA: B1/B5/B8
GSM: 850/900/1800/1900MHz
SC20-A САЩ
FDD LTE: B2/B4/B5/B7/B12/B13/B25/B26
WCDMA: B1/B2/B4/B5/B8
GSM: 850/1900MHz
SC20-AU Австралия
FDD LTE: B1/B3/B5/B7/B8/B28
TDD LTE: B40
WCDMA: B1/B2/B5/B8
SC20-J Япония
FDD LTE: B1/B3/B8/B18/B19/B26
TDD LTE: B41
WCDMA: B1/B6/B19
Документация:
http://www.quectel.com/Qdownload/SC20.html
Пет Яну 27, 2017 7:23 pm
деца, обърнете внимание на звездичките в редчето Approval.
WiFi е SIMO
Илко,
благодаря за бързата информация.
дали знаеш какво е поведението на модула, когато върви (войс) кол по едната СИМ карта, какво става с другата?
дали върви сигнализация (връща BUSY) или е пълен ступор (абоната е недостъпен)?
дали имат планове, освен андроид, да пуснат и нещо друго (лайнукс, примерно)
Пет Яну 27, 2017 8:49 pm
Звездичките значат - Under development - демек ще го бъде.... копирах текста за бърза информация
Ами той си е линукс с андроид шарения... не съм чел подробна информация за "софта" и възможностите, но сигурно може и да има (после) линукс плюс и без шарения
Без шарения, сигурно може да се спре зареждането на андроид часта и да си остане на терминал линукс
Пет Яну 27, 2017 9:08 pm
Алтернатива е това - пак е с Qualcomm, макар и по-скромен, и линукс:
https://www.sierrawireless.com/products-and-solutions/embedded-solutions/iot-modules/
https://www.sierrawireless.com/products-and-solutions/embedded-solutions/open-source-initiatives/
Съб Яну 28, 2017 7:33 pm
Ето тук има събрана информация и мейлинг лист на хора, които се интересуват от подобни модули:
http://osmocom.org/projects/quectel-modems/wiki
Сря Фев 01, 2017 12:58 am
