рутера ми е с бъгнато меню
Мнение рутера ми е с бъгнато меню
:? това изплю при вход Netgear 192.168.0.1 Admin Login Page – 192.168.0.1 Router Configuration Center
https://www.netgear.com/support/product ... ion%202.16
<html> <head> <meta name="description" content="WGR614_2022"> <meta http-equiv="content-type" content="text/html;charset=ISO-8859-1"> <title> NETGEAR-Router</title> </head> <frameset rows="130,*"> <frame src="MNU_top.htm" name="topframe" noresize scrolling="no" marginwidth="0" marginheight="0" framespacing="0" frameborder="1"> <frameset cols="170,60%,40%"> <frame src="MNU_menu.htm" name="contents" noresize frameborder="1" marginwidth="0" marginheight="0" scrolling="auto"> <frame src="WIZ_sel.htm" name="formframe" frameborder="1" marginwidth="0" marginheight="0" scrolling="auto"> <frame src="MNU_blank.htm" name="helpframe" frameborder="1" marginwidth="0" marginheight="0" scrolling="auto"> </frameset> <noframes> <body> <p>Bitte rьsten Sie auf einen Browser ab Version 4 auf, damit Sie dieses Konfigurationsprogramm nutzen (und viele groЯartige Sites im Internet anzeigen) kцnnen. </body> </noframes> </frameset> </html>
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
If the wireless router fails to restart or the power light continues to blink or turns solid amber,
the unit may be defective. If the error persists, you might have a hardware problem and should
contact technical support.
Последна промяна am stereo на Сря Юни 19, 2019 8:06 pm, променена общо 2 пъти
Сря Юни 19, 2019 7:43 pm
Мнение Re: рутера ми е с бъгнато меню
Изчисти кеша на browser-а. Ако не помогне - reset. Ако и това не помогне - в най-близкия ламаринен кашон...
Сря Юни 19, 2019 7:55 pm
Оня ден един така се беше скапал, линксис с качен ddwrt, направих му ресет и се освети.
Сря Юни 19, 2019 8:38 pm
хъмм...тъпото е,че само лисицата го вижда като адрес и плюе това-всеки друг браузър не го вижда при логната лисица-явно има ограничение по сесии за юзъри-админи...ще я затворя и ще пробвам хром и опера,после ресет и флаш през еспиай;джейтаг
поздрави с https://youtu.be/TrXcPVEtghQ
Сря Юни 19, 2019 10:16 pm
Ъмчи ресетни го де - казаха ти хората.
Преди години някой ми беше сменил админ-паролата и някои други настройки - все неща за които обикновения юзър не би се усетил, аз го набарах някак си интуитивно.
Сря Юни 19, 2019 10:25 pm
И след ресета исти хуй...но има еспиай и джейтаг за флашИзображение :arrow: https://youtu.be/VyiITrDdJWM?t=221
Последна промяна am stereo на Пет Юни 21, 2019 7:25 pm, променена общо 1 път
Пет Юни 21, 2019 7:06 pm
Ами да може да запишеш флаша ама трябва да намериш дъмп. А едва ли си се сетил да го прочетеш докато е работел. Но може в някой руски сайт да има...
Пет Юни 21, 2019 7:12 pm
Напиши модел и версия.
Пет Юни 21, 2019 8:26 pm
WGR614v2 — 54 Mbps Wireless Router
Model / Version: WGR614 v2
СЕГА го ползвам за свитч само и вчера буря с токов удар-оп заби и като суич тъпунгера-нямат логика да проверят състоянието на портовете и да се самостартират от фърмуера...незнам смарт суичовете могат ли го
Пон Юни 24, 2019 12:00 pm
Нямам такава версия. Не знам дали си заслужава това архивно нещо да се възстановява.
Сря Юни 26, 2019 10:02 am
а,на сайта му-линка в първия пост или при руснаците
Сря Юни 26, 2019 6:02 pm
Рутера ползва boot loader, който чете и записва файла от сайта. Ако го запишеш директно дори и на правилното отместване не тръгва. Трябва ти dump на целия flash. Ако намериш за твоя модел сменяш му mac адреса (с hex редактор се намира лесно) с този от кутията и става.
Сря Юни 26, 2019 6:30 pm
Колко ненужни усилия за ремонта на боклук за 10лв. :wink:
Сря Юни 26, 2019 8:09 pm
syscop написа:
да,така е и при дъната при флаш :arrow: https://weborus.com/guide-flash-bios-sp ... rogrammer/
after receiving a blank SPI chip bought on the Internet, after flashing it, nothing works. This means that the motherboard needs the MAC address (written on the back of the motherboard). It will then be necessary to find the way to add it in the Bios with a hexadecimal editor.https://www.onlinehexeditor.com/
Сря Юни 26, 2019 8:43 pm
Няма проблем с mac адреса на файла, който намериш - в същия сегмент от мрежата едва ли ще е рутера, от който е смъкнат. По-удобно е да ползваш оригиналния - не търсиш с какво да го пишеш :)
Сря Юни 26, 2019 9:00 pm
Потребители разглеждащи този форум: Google [Bot] и 2 госта
