DOSBox + CADSTAR 7 (DOS)
Мнение DOSBox + CADSTAR 7 (DOS)
1. Download DOSBox from official web site: https://www.dosbox.com/download.php?main=1
2. Install it
3. Find the file: dosbox-0.74.conf (C:\Users\*******\AppData\Local\DOSBox\dosbox-0.74.conf)
4. Scroll to the end of file and will see:
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
For example if folder CADSTAR is on D:\CADSTAR have to move to D:\dosprogs\CADSTAR
This is necessary about CADSTAR not for DOS
Add this:
[autoexec]
mount c d:\dosprogs\
PATH C:\CADSTAR;C:\CADSTAR\SYSTEM;C:\CADSTAR\USER;C:\CADSTAR\LIBRARY
5. Run DOSBox
6. Will see:
Z:\>mount c d:\dosprogs\
Drive C is mounted as local directory d:\dosprogs\
Z:\>PATH C:\CADSTAR;C:\CADSTAR\SYSTEM;C:\CADSTAR\USER;C:\CADSTAR\LIBRARY
Z:\>_
Write in DOSBox:
Z:\>c:
Z:\>cd CADSTAR
Z:\CADSTAR>pcb   <- run CADSTAR
7. Have fun!
click many times CTRL+F12 to increase CPU speed or use INTRO
click ALT+ENTER to switch to full screen
Сря Мар 08, 2017 7:43 pm
Регистриран на: Чет Окт 13, 2016 7:59 am
Мнение Re: DOSBox + CADSTAR 7 (DOS)
Някой да има по архивите RACAL-REDAC CADSTAR MK7.6 ? ;)
Пон Дек 30, 2024 3:46 pm
Потребители разглеждащи този форум: 0 регистрирани и 21 госта
