Полезни Еклипс плъгини за ARM девелопмънт
Мнение Полезни Еклипс плъгини за ARM девелопмънт
Идеята ми е в тази тема да съберем полезни и изпитани плъгини за Еклипс свързани с ARM девелопмънт.
Ако някой се сеща и за други - тук е местото да сподели :-)
GNU ARM Eclipse Plug-in
This plug-in is an Eclipse CDT Manged Build Extension for GNU ARM Toolchains like CodeSourcery G++ Lite, GNUARM, WinARM, Yagarto, devkitPro, Summon
- simplify project management (no need to create makefiles)
- support major ARM toolchains (Sourcery G++ Lite, GNUARM)
- runs on Windows, GNU/Linux, Mac OS X
http://sourceforge.net/projects/gnuarmeclipse/
Eclipse Embedded Systems Register View
The Register view allows the structured display and modification of peripheral register values. The view should work with any 32bit target that stores data in little endian byte order and mapps its register into memory address space.
http://sourceforge.net/projects/embsysregview/
MicroXplorer - MCU graphical configuration tool for STM32 MCU
MicroXplorer is a graphical tool enabling users to configure an STM32 MCU very easily and generate the corresponding initialization code.
http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1533/PF251717?s_searchtype=partnumber
Eclox - Doxygen
Eclox is a simple doxygen frontend plug-in for eclipse. It aims to provide a slim and sleek integration of the code documentation process into eclipse by providing a high-level graphical user interface over doxygen.
http://home.gna.org/eclox/
Eclox (Doxygen Eclipse) - http://download.gna.org/eclox/update
Бинаритата примерно от тук:
[url]http://ftp.stack.nl/pub/users/dimitri/doxygen-1.8.3.1-setup.exe
[/url]
Чет Апр 25, 2013 10:38 am
Мнение Re: Полезни Еклипс плъгини за ARM девелопмънт
Рек ковни я.
Чет Апр 25, 2013 10:42 am
не забравяйте добрия стар зилин:
Zylin CDT site - http://opensource.zylin.com/zylincdt
Чет Апр 25, 2013 11:00 am
Да добавя няколко:
- Bracketeer - форматира кода добавяйки коментар на затварящите скоби, по-добра индикация на отговарящата скоба
- Subclipce / Subversive - SVN плъгини, и двата си имат дребни кусури но са поне на нивото на костенурката
Пет Апр 26, 2013 9:26 am
Регистриран на: Пет Авг 07, 2009 4:58 pm
Egit мисля, че не го видях да е споменат - за работа с Git е. Става, ако човек предпочита да работи с менютата, а не с cmd prompt. Стори ми се орязано, като функционалност, спрямо конзолата и не съм го ползвал.
Чет Сеп 11, 2014 1:39 pm
http://toem.de/index.php/projects/impulse
изглежда интересно, не съм го пробвал
Съб Мар 11, 2017 10:58 pm
Има ли плъгин за симулатор, че не върви за някои бързи проби да закачам платка с дебъгер?
Нед Мар 12, 2017 3:22 am
Има симулатори на АРМ, но ще ти е по-лесно да закачиш платка отколкото да ги подкараш. Освен това с перифериите е мъка... Поради тия причини никога не съм се мъчил, нито съм чул някой да ползва такива неща. Ползват ги за андроиди и тем подобни, ама там е друга бира.
Нед Мар 12, 2017 1:45 pm
На мен периферии не ми трябват - само ядрото. Дай линк към някои да видя за какво става въпрос.
Нед Мар 12, 2017 3:38 pm
от опън сорса QEMU-то мисля е най-известно, но нали ти казвам че не съм се занимавал изобщо... Ако успееш да подкараш нещо, сподели ;-)
Нед Мар 12, 2017 3:47 pm
Сега се боря с едни опън сорсове за IoT, дето ми късат нервите яко, та като свърша с тях ще пробвам и ще докладвам :) .
Нед Мар 12, 2017 4:08 pm
Сигурно знаете че, GNU ARM Embedded Toolchain може да се изтегли и от сайта на ARM при това готов компилиран и за линукс и за уиндоус, но аз го открих снощи :)
При това е с GCC 6.3 за разлика от Launchpad където е 5-ца или от официалното хранилище на убунту където пък е 4 нещо си.
Нед Юли 02, 2017 7:32 pm
michev написа:
Може и сам да си го build-неш - трябва ти един готов скрипт дето си прави всичко (дърпа сорсове, компилира и т.н.) и към час някъде на по читава машина.
Нед Юли 02, 2017 7:58 pm
Компилирането на тулчейн и поддръжката му е работа за хора които или нямат избор или имат прекалено много свободно време :). Аз време за губене нямам. Само си представи какъв кошмар ще е подобно занимание под уиндоус. Мисля темата е точно затова - да се споделят готови решения - в случая мисля че може да се има вяра на ARM че ще поддържат тулчейна в работещ вид.
Та да споделя конкретната сглобка за STM32 която тествах -
Eclipse Oxygen Release (4.7.0)
GNU ARM Eclipse Plug-in, който вече Емил е дал. По време на инсталацията на плъгина има още 10-тина пакета които могат да се инсталират. Единия от тях е GNU ARM C/C++ Packs, който изглежда като "Eclipse Embedded Systems Register View".
Тулчейна вече е споменат - последният към момента от страницата на ARM.
J-link 9.3 със софт версия 6.12f.
Нед Юли 02, 2017 11:19 pm
ай ся! компилирането на тулчейн на съвременна машина е двайсетина минути, най-много.
и понякога наистина се налага да знаеш как точно е компилиран.
пример - случката на пирев с пакетираните битови полета в структури
признавам си, че никога не съм го правил в джам. аз джама го ползвам само заради ментора, солида и ексела 8)
но в нормална ОС е тривиално да си компилираш някой крос компилатор. пък и модата там се мени толкова бързо, че не можеш дори и да следиш какво са барнали. затова е нормално да имаш качени 10 и повече тулчейна...
особено с днешната наложителна смяна на gcc с CLANG. там е ебаси кашата, поне в ARM губернията. всеки ден има десетки фиксове.
Пон Юли 03, 2017 9:53 am
Потребители разглеждащи този форум: 0 регистрирани и 21 госта
