Дата и час: Нед Окт 18, 2026 2:27 am
Grubi
 Re: PADS VX
Добре - ето програма 08.00 -08.30 - Шведска маса 08.30-10.00 - Въведение 15 мин кафе и закуска 10.15-12 - Тема 1 12-13 Лек обяд 13-14.30 - Тема 2 14.30-14.45 кафе и закуска 14.45-17 - Тема 3 17-21 - Дискусия, пържоли и т.н. 21-24 Практика И така една седмица...Харесва ли ви?
| Пет Яну 06, 2023 6:42 pm |
 Re: PADS VX
aaaaa 21-24 за каква точно практика става въпрос, има ли нещо общо със шведките от шведската маса ... или то шведките нямаха общо с масата ...
| Пет Яну 06, 2023 8:30 pm |
Grubi
 Re: PADS VX
Стига с разводняването на темата...писане/чертане на домашното, за който иска да получи екстра точки
| Пет Яну 06, 2023 10:16 pm |
HSB
 Re: PADS VX 2.13
New Features Introduced in PADS VX.2.13
This is primarily a release aimed at adding new functionality and fixing customers’ logged defects - Service Requests (SRs). The following new products, features, and enhancements are introduced in the PADS VX.2.13 release.PADS AMSPADS AMS includes the following updates in release PADS VX.2.13. SPICE Syntax CheckerRelease VX.2.12 introduced the SPICE syntax checker, which checks non-PSpice models for syntax errors based on the PADS AMS required syntax. Release VX.2.13 updates the checker with syntax checks and support for additional SPICE models. The syntax checker can run automatically at simulator startup, or from a dialog started from the new Simulation > Check Spice Model menu option. To view the menu option, set the following Windows environment variable: SV_ADVANCED=1.PSpice Converter UpdatesCircuit net names starting with “+” and “-“ are properly converted to PADS AMS syntax. For example +VSIG and -VSIG will be converted to N+VSIG and N-VSIG, respectively. And in some commands that require minimum and maximum limits, PSpice allows the definition orderto be min then max, or max then min. PADS AMS only supports min then max, so the PSpice converter now corrects the order as needed.Simulation Progress Counter UpdatesThe simulation progress counter, which is visible in the lower left-hand corner of the PADS AMS window during a simulation, now accommodates analyses that combine the .SWEEP and .EXTRACT commands.
2PADS VX.2.13 Release HighlightsMarch 2023 Tutorial UpdatesTutorial updates include changes to the SPICE Import, Parametric Analysis, S-Parameter, and FFT tutorials. All tutorials are available from the Help > AMS Tutorials > Tutorial Index menu option.HyperLynx® DRCHyperLynx DRC adds some important new functionality and defect fixes. The sections below provide details on some of the new capabilities.New Rules Reference Via LocationRule enhancements •Diff Impedance— Support physical net check•Clamshell rules— Allow ignoring termination/last segment check for DDR5
•Diff Pair — Able to account pin package length •Net Crossing Gap Quick Check— Added Min Area rule parameterOther major improvements•Exploring violations while multiple violations are highlighted in the board viewer •Stackup files can be read by specifying a command line switch or AOM call •Models (ibis, ref, or qpl) can be read by specifying a command line switch or AOM calls • AOM reference now includes Python examplesHyperLynx SI/PI/ThermalThis release contains improvements in SERDES analysis.SERDES•PAM4 measurements/reporting improvements •Time domain plots •Frequency domain plots for .s1p, transfer functions, and CTLE •Integration of newest ADMS
PADS VX.2.13 Release Highlights3March 2023 Automation EnhancementsAdvanced Coupling/Crosstalk Settings•Coupling.GetRightPlaneSeparation •Coupling.SetRightPlaneSeparation•Coupling.GetLeftPlaneSeparation•Coupling.SetLeftPlaneSeparationModels •Pin.RemoveModel Simulators •Simulator.ProbePosition o hlSimProbeAtPino hlSimProbeAtDieo hlSimProbeByModelApplication •Application.CloseFileApp Explorer EnhancementsBoard Viewer•Access Board Viewer with Nets, Components, Layers, Pins, and Materials•Allow cross probing the model from status messages•Double-click to zoom to selected objects•Enable Cross-Probing of Nets from the Pulse Response Report •Filter Components from selected Nets Automatically•Added a context menu to the List Filter Widgets •Faster rendering by removing extra via pads from the display model •Intelligently color the model based on significant features 4PADS VX.2.13 Release HighlightsMarch 2023 DC Drop Enhancements•New Parameterso Analysis: DC Drop or Resistance (or both) o VRM Equivalent Resistance o VRM Reference Neto VRM Reference Deviceo Current Per Pin o Series Passiveso Series Passive Resistance o Sink Pins to Exclude •Allow a list of numbers to be entered for the DC Dropo Series Passive Resistance o VRM Voltageo VRM Equivalent Resistance o Sink Currento Sink Resistance parametersSerDes App Enhancements •Robustness; Better information messages and progress reporting Pulse Response Enhancements •Added a "Min P-Ratio vs. Net Name" bar chart to the Report •Added cross-probing for Nets and Pins in both tables •Updated the default value for "Run Crosstalk" •Updated the default values for some of the PBS (.pbs) file optionsGeneral •New "Show Directory History" button to see previous folders used •Clear values from cells •Runtime Summary and Details in reports •Automatically create a Log File
| Чет Апр 13, 2023 7:40 pm |
HSB
 Re: PADS VX
Info Днес за проба инсталнах ПАДС Стандарт 2.13 със упдеит 1 .( това е тхе лаитест анд тхе греитест за момента ) на един дърт Делл поне 10г е ама с някво Интелско И7 все пак Генератора от ЕФА за Експедишън 2.11 работи и ми направи фаил за всички инсталрани неща. Схемата и леоута бачкат ,друго не съм отварял и
Повече не съм ръчкал ,инак работя на работата с 2.12 и всичко засега е ОК.
| Чет Авг 31, 2023 12:40 am |
Grubi
 Re: PADS VX
Интересно какви са разликите в цените на лицензите (2023) между PADS, Orcad и Altium?
| Чет Авг 31, 2023 9:08 am |
HSB
 Re: PADS VX
Инфото е от 9 Окт 2022 Hey AAbbCCC, I wanted to let you know that we are no longer to offer PADS Standard Licenses. The Updated pricing for our new fiscal year for PADS Pro is as followed for your request of 3 Perpetual Licenses, as we have a promotion going now: - (3) PADS Professional Ap SW o (3) Perpetual Site Float Licenses: $31,020 with $6,207 in first year support Let me know if you’d like to see a formal quote. Thanks! ХХХХХХ ХХХХХХХ, Inside Sales Rep Siemens EDA +1(503) ****** ХХХХХХХХ@mentor.com www.siemens.com/software10 340 на лиценз.... И пак за инфо Алтиума днес ,за справка е Perpetual Perpetual licenses allow you to use the software forever for as long as you comply with all license agreement terms. You are entitled to updates for as long as you keep the license on an Altium Subscription Level. From USD 11,870
| Чет Авг 31, 2023 9:51 am |
Grubi
 Re: PADS VX
Благодаря!
| Чет Авг 31, 2023 11:23 am |
HSB
 Re: PADS VX
Днес съм все още болен – баси и вирусите и т.н ...оправям се но по бавно отколкото очаквах. Та така и так си седя в къщи рекох да екпериментирам
Инсталиране на ПАДС 2.14 на ПЦ ( Дърт ДЕЛЛ 6420 с И7 процесор,неиде произведен 2015 )
2.14 е само то ,все още няма упдеити.Ще приложа PADS Release Notes -Software Version: PADS VX.2.14September 2023 Та които иска да се образова какво има вътре.
Инсталва се пакета ,по време на инстала има едно меню което чрез което може ръчно да се кликне какво да се инсталва -препоръчвам да се прегледа , аз го правя винаги и Кликам на всичко ,в момента експериментирам да видя лекарството дали ще направи каквото трябва. Обикновено дава че нямаме инсталиран лиценз и трябва да се кликне на SKIP и да се избегне в началото софта които сетва лицензните неща. Като се инсталне всичко – рестарт на ПЦ то за вски случаи . Ако се запусне менторски сървер – килваме го от таскмениджъра.
Слагаме лекарството в няква папка на Диск Ц – по дефолт всичко се инсталва на
C:\MentorGraphics
Доколкото помня препоръчват лекарството да е на C:\ диск , но работи и ако се пусне и от C:\лекарство например От друг диск не съм пробвал. Лекарството го взех от пакета на Експедишън VX 2.11 oт руския тракер.Като се запусне пише
V13.20.65 2024 by EFА
Накрая дава резултат , запазвате си го някъде тоя текст фаил.Да спомена пак че преди правеше за10 г напред валидност , сега е за 3 години. Може би лимитация коята софта гледа - не знам, но ако притрябва ще си сковем нов фаил след 3 години.
Другото което леко също ме смути е, че дава ми дава глешка че не може да оверврите фаил (пак ТХТ) които е в C:/users/app….. но когато ръчно ида там ,няма проблем- ТХТ фаила си е там и мога да правя каквото си искам с него.
Тук е момента да спомена че пускането на install license file не дава резултат, отваря се прозорец и изчезва. Тва не знам дали е от Ментарджите или е проблем на моито ПЦ -ако някои пробва да каже . Поради тая причина ,преминавам към ръчно сетване на лиценза – Копрам фаила е тука : C:\MentorGraphics\license_files После във environmental variables
Се прави ентри
Variable Value MGLS_LICENSE_FILE C:\MentorGraphics\license_files\license.txt
Рестарт на ПЦ то .
FYI
Сетингите – ментрични ,цветове, точки,чертички ,шрифтове седят в
C:\MentorGraphics\PADSVX.2.12\SDD_HOME\Programs
За схемата – powerlogic.ini За ПЦБ то - powerpcb.ini
Обаче не става с копиране от старата версия - за това ще има друго упътване.
SCH / PCB/ Либ конвертора/ кам-кад => работят ,друго не пробвах ,но предполагам че работи всичко за което има лиценз.
| Нед Фев 25, 2024 12:08 am |
HSB
 Re: PADS VX
PADS2.15_Release Highlights_Sep2024
New Features Introduced in PADS VX.2.15 - четете на страничка 3 . Моя коментар - упдеитите са само на симулацията.
| Чет Ное 14, 2024 5:22 am |
HSB
 Re: PADS VX
PADS2.16 - излезнало е Април 2025 и в момента най новия ЪПДЕИТ 3 от Аугуст 2025 Има някакви бъгни фикснати но в момента не ми се чете а и забравих да дръпна релис фаила
| Сря Сеп 17, 2025 3:55 am |
HSB
 Re: PADS VX
PADS2.17 PADS™Release Highlights Software Version: PADS VX.2.17October 2025
няма 1 дума за новости в ПЦб и схемата - новите неща са в симулацията и в лицензирането. По памет имаше и лечение за SALT но аз лично не съм го пробвал.
The PADS VX.2.17 release utilizes the SALT (Siemens Advanced Licensing Technology) MSL software version 4.4.3. that utilizes FlexNet® v11.19.5 Customers upgrading from previous HyperLynx versions to PADS HyperLynx VX.2.17 must upgrade to this newer version of the Siemens Licensing Server if not already on v4.3 or higher.
| Нед Яну 04, 2026 12:28 am |
HSB
 Re: PADS VX
PADS2.18 PADS™Release Highlights
Има някакви упдеити в симулацията - в схемата и ПЦБто нищо ново.
| Сря Май 06, 2026 3:47 am |
 Re: PADS VX
че сименс (по-точно сименс-бизнес) ги придобиха за да правят 'бизнес' с лицензи, а не да се набутват с разходи в развитие. естествено, най-важната работа е да се преборят с лицензирането - да минеш на годишен абонамент, че кинтите да капят непрекъснато. а, и клюкаренето до кораба-майка също е значително 'подобрение'.
то не че има и кой знае какво да се подобрява... и май вече няма кой да ръчка по развоя. най-много да сменят цвета на някоя иконка, за по-сериозни 'революции' предполагам не са им останали хора.
мен лично ме мъчи (рядко) една промяна в автоматичното разпознаване на диф-двойки. в 9.х се държи както ми е удобно, в VX смениха поведението, което според тях е логично, но понякога е вредно и няма как да се преодолее.
другото мъчително нещо са скриптовете. забравени даже и от боговете (М$) версии на езици, на които инките може би са пресмятали пирамидите си (съмнително, камъняците си седят и до днес). не че на object-fortran щеше да е по-лесно/ясно. ееех, ако можеха М$ да ъпдейтват всеки месец пирамидите... всички камъни на планетата щяха да омекнат. от друга страна, ако барнат нещо, всички стари скриптове ще умрат.
ти поне им поглеждаш анонсите. мен отдавна не ме интересуват. и май се оказва, че основната промяна в новата версия е... номера на версията?
погледнато от високо, нуждата от такива софтуери почти изчезна. 'големите камъни' са недостъпен строителен материал за простосмърните. само избрани единици получават достатъчно информация да зидат с тях. почти същото е и с FPGA. откакто ги глътнаха разните му сини, червени, зелени, пенпени, да сложиш FPGA трябва да имаш много сериозна аргументация.
остана евентуално SoC, но и там тенденцията е към замиране. паметите станаха доста елестични откъм капризност. дизайните даже понякога и работят. критерият 'работи' се сведе до 'бутна лайнукс'.
ST за MPx пуснаха алтиумски 'заготовки' на рутирана памет. през експорта към HL ги изсимулирах. получи се коледна елхичка, в която преобладават оранжевите цветове, има и доста червено и почти никакво зелено. ама хората си ги ползват, рутят си с алтиума и се кефят колко готино било.
| Чет Май 07, 2026 3:09 am |
HSB
 Re: PADS VX
Ами ве още ми е интерсно и затова. Според мене света е тръгнал към огомно изглупяване...амам каквото това е. Още преди бая време ментарджите казахе че не продават нови лицензи за ПАДС,обаче явно има много хора дето го ползват и преполагам по тая причина трябва поне да се правят че го поддържат.
В мизерната фирма дето работя минаваме от ПАДс на Дип Шеет софтуер и ако че от 2022 не сме плащали за съпорт ментарджита ми отговориха не следващия ден за един много стар проблем дето го бях забравил че го има щото тва става само в много архивни версии- съпорта име все още на ниво.
Grid Values Are Stored as Even Numbers Because of 2 Mil Database
PADS Standard & Standard Plus
PADS Logic requires grid values to be entered as even numbers. When the message appears this indicates that you have a number entered as an odd value.
To correct this:
Go to Tools > Options > General tab and change your value(s) to an even number. The range of acceptable values is listed below: Design value: [2 2000] Labels and Text value: [2 2000] Display Grid value: [10 9998] Minimum display width value: [0 250]
The message for the minimum display width will not occur unless you have entered an odd value greater than 250. Minimum display widths values less than 250 are allowed to be even or odd.
If the error message prevents you from making edits to the values follow the below steps:
Exit from the Options dialog. Go to File > Export. Provide a file name and location for the ASCII file, click Save. On the ASCII export dialog, click the Select All button and click OK. Open the ASCII file in Notepad. Look for the line USERGRID. The first value is the Design grid, the second value is the Labels and Text grid. Change these to acceptable values. Look for DOTGRID. The value represents the Display Grid. Change this to an acceptable value. Save the ASCII file. In PADS Logic, go to File > New. Delete the existing title block. Go to File > Import and load the ASCII file. Recheck Tools > Options > Design. You should no longer receive any errors.
Regards, Jххххх, Customer Support Engineer Siemens DISW Global Customer Support & Success
| Чет Май 14, 2026 3:47 am |
