Отговори на тема  [ 155 мнения ]  Отиди на страница Предишна  1 ... 6, 7, 8, 9, 10, 11  Следваща
PADS VX
Местоположение: Phoenix AZ
Мнение Re: PADS VX
Free PADS ODA Library - Updated March 18, 2022
Ако на някой му притрябва да се обажда 14 Мб е .
UMMARY
The fully documented starter library comprises more than 11,000 parts including 1700+ xDX symbols and 1000+ IPC-compliant and manufacturer-recommended PADS decals.
Features:
IPC-7351B compliant
Large variety of device types
Clearly defined partitions for easy navigation
Manufacturer part number, checked by Valor NPI for footprint accuracy
All part numbers qualified for use in schematic and layout
Manufacturer part numbers verified as current
Descriptions of the standards used to create the library
Fully compatible with PADS VX and PADS 9.5
Library administration support
Included with the download are:
Central library for PADS integrated flow
PADS netlist library
xDX Databook database and configurations for integrated and netlist flows
Project templates for creating new xDX Designer projects
User Guide
PADS content for Integrated Projects:
Central Library file containing:
PADS Parts
PADS PCB footprints
Designer symbols
Designer Integrated project template with pointers to included files:
borders.ini
CentLib.prp
speccomp.ini
Access database for PADS DataBook (Databook.mdb)
PADS DataBook Configuration file (PADS_Integrated.dbc)
PDF instructions for library setup
PADS content for Netlist Projects:
PADS Layout library files
PADS Part types
PADS PCB footprints
Designer symbol libraries
Designer Netlist project template with pointers to included files:
borders.ini
netlist.prp
speccomp.ini
Access database for PADS DataBook(Databook.mdb)
PADS DataBook Configuration file(PADS_Net_List.dbc)
Note: PADS Logic symbols are not created for the ODA Library
П.С - абе тия от Оптимума са се по обаъркали ама какво да се прави .
Значи това за Интегрирания път - не съм го пробвал но изглежда ок ..
Но това коео те за нетлист не е баш то ама да речем поне корпусите могат да се ползват .. в ПАДС95 такива амбалажи с датабаза и от сорта няма.
Пет Апр 08, 2022 7:40 pm
Мнение Re: PADS VX
Упдеитнах се до ПАДС 2.12 с упдате 1
Нищо особено ,само са направили падащите менюта малко по друго .
Инак потърсих хак в рутракера има 2.11
Новото е че Хакерите са сковали нов тул които пише че може да скове и лиценз за SALT
Siemens Advanced Licensing Technology (SALT) FAQ - Updated June 16, 2022
General
Q: Why are Siemens EDA/DISW applications moving from Mentor Standard Licensing to SALT
A: Within Siemens EDA/DISW, there are almost 100 different license generators being used and maintaining them all gets more difficult every year.
This is not only difficult to maintain on the Siemens side but also difficult for customers to maintain in their runtime environments.
Over the next few years, these will be replaced and all the Siemens EDADISW tools will eventually use the same system.
This is an opportunity to re-engineer licensing using the best parts of each system, simplify license delivery and reduce administration efforts in customer environments.
Q: What are some of the key changes related to SALT?
A: SALT provides the following:
A new API that developers can use to check out both mgcld and saltd licenses.
SALT includes the Siemens License Server (SLS) installer that installs three vendor daemons (mgcld, ugslmd and saltd) in a common location, imports their respective license files and starts their respective license managers.
This ensures that customers have a solution to manage their newly enabled SALT applications as well as legacy applications.
A single license environment variable, SALT_LICENSE_SERVER, for referencing license servers and license files.
Q: How can I tell if the product I'm using is using SALT or mgcld vs saltd licenses?
A: <?>
Пет Окт 07, 2022 9:20 pm
Мнение Re: PADS VX
Инфото е от преди 2 дена
Hey AAbbCCC,
I wanted to let you know that we are no longer to offer PADS Standard Licenses. The Updated pricing for our new fiscal year for PADS Pro is as followed for your request of 3 Perpetual Licenses, as we have a promotion going now:
- (3) PADS Professional Ap SW
o (3) Perpetual Site Float Licenses: $31,020 with $6,207 in first year support
Let me know if you’d like to see a formal quote. Thanks!
ХХХХХХ ХХХХХХХ, Inside Sales Rep
Siemens EDA
+1(503) ******
ХХХХХХХХ@mentor.com
www.siemens.com/software
10 340 на лиценз....
И пак за инфо Алтиума днес ,за справка е
Perpetual
Perpetual licenses allow you to use the software forever for as long as you comply with all license agreement terms. You are entitled to updates for as long as you keep the license on an Altium Subscription Level.
From USD 11,870
Сря Окт 12, 2022 12:05 am
Мнение Re: PADS VX
Става все по-забавно...
Сря Окт 12, 2022 10:13 am
Мнение Re: PADS VX
Обаче ако че да речем софта е готов - цената веднага я актуализират ....
Някакси ако правиш всичко от нищо ...аиде е това е цената ,но при положение че са само упдеити на даден продукт .... просто помпането на цента показва колко маимуни са на хранилка и как акционерите в тия фирми не искат да си намалят печалбата......
Сря Окт 12, 2022 7:44 pm
Мнение Re: PADS VX
още един фючър - откак минаха на абонамент, не можеш да го прекараш през еврофинансиране като разход.
Нед Ное 20, 2022 7:03 am
Мнение Re: PADS VX
Има 3 треининга дето пише че са без пари - някои да се логне и да види дали може да се ползва.
Аз отидах на таз страничка и предварително се ЛОГ ОФФ и уж и без да съм логнат на съпорт саита ми дава да ги ползвам
https://training.plm.automation.siemens ... earch=PADS
PADS Professional training library will offer a complete portfolio of learning paths for schematic design, constraint definition,
PCB layout, and library creation and management. Free On-Demand Training for PADS Customers.
Enter discount code: PADSODT for free access to these PADS training libraries.
This learning path supports designers using the PADS Standard Layout tool in a Netlist flow. It focuses on all areas of PCB design using PADS Layout.
This library will show you how to use PADS Standard Plus to design PCB boards. It contains learning paths for schematic and PCB design.
Чет Яну 05, 2023 1:28 am
Мнение Re: PADS VX
Не става нещо, иска по 480 пари за всеки курс...
Чет Яну 05, 2023 6:44 pm
Мнение Re: PADS VX
за толкова пари ще ти дойда на крака да ти ги преподам
а ако си дойдеш на наша почва, и половината да ги изядем и изпием, ще ни трябват яки диети след 'обучението'
Чет Яну 05, 2023 7:06 pm
Мнение Re: PADS VX
Записвам се на твоя курс, трябва да привлечем още участници.
Може да е диетичен курс, не е нужно да качваме 100кг отгоре...
Чет Яну 05, 2023 11:05 pm
Мнение Re: PADS VX
:) Grubi, не разваляй хубавата оферта!
Пет Яну 06, 2023 10:33 am
Мнение Re: PADS VX
яките лепила са двукомпонентни (нещо+втвърдител)
така че, за да се получи як резултат, трябва да се комбинира лекция, твърдо гориво и въглехидратен пластификатор (примерно вратни пържоли). не мисля, че (само) с репички и марули някой ще се почувства щастлив :P
Пет Яну 06, 2023 11:53 am
Мнение Re: PADS VX
от пържоли, салати и ракия никой не е надебелял, или поне аз не знам
виж от бял хляб и бонбони... но нас не ни трябват
Пет Яну 06, 2023 12:35 pm
Мнение Re: PADS VX
добре де - разширявам офертата: ще изпека и една погача, поне да се снимаме с нея
Пет Яну 06, 2023 12:39 pm
Мнение Re: PADS VX
А пържоли и компютри трудно се съчетават...
Може би е по-удачно компютрите да останат за друг път?
Пет Яну 06, 2023 12:41 pm
