Отговори на тема  [ 45 мнения ]  Отиди на страница 1, 2, 3  Следваща
Нова версия на CCS
Мнение Нова версия на CCS
Ние за ARM си говорим , но все още и PIC си ползваме така че за заинтересуваните 3.325, доста неща са пооправени в сравнение с 3.221
3.222 PCW debugger now shows port status in the peripheral window
3.222 Some optimization improvments have been made and some bugs fixed
3.222 Baud rate generation for parts with 16 bit generators is improved
3.222 Fuse names for some chips have been updated to avoid confusion
3.222 The programming algorithm for 12 bits parts has been updated
3.222 A bug in PCB (12 bit parts) floating point math is fixed
3.223 A problem with I2C_START() on some parts is fixed
3.223 Formatting inconsistancies with %U and %D are fixed
3.223 LCD support for the newest parts with direct LCD drive has been added
3.223 Help file brougth up to date with the newest features
3.223 A problem with the evaluation of (!bitvar==1) in some expresions is fixed
3.223 Some optimization improvments have been made
3.224 Duplicate #defines in some header files are corrected
3.224 A problem with the %02d format in printf is fixed
3.224 Built in functions have been updated for the newest parts
3.225 The #type has been expanded to allow a default address space to be specified
3.225 The capability to read an encrypted include file has been added
3.225 PCW allows the generation of an encrypted include file for distribution
3.225 A bug with rotate_right/left when using arrays with expression indexes is fixed
3.225 Some formatting issues with %LD are fixed
3.225 User defined functions in a #ORG DEFAULT block are now always included in ROM
3.225 A bug in TYPEMOD with ranges spanning over 256 bytes is fixed
3.225 A bug in relational expressions involving both int32's and floats is fixed
3.226 A bug involving reference parametters in inline functions that are nested structures is fixed
3.226 The I2C master algorithems have been updated to make multi-master more robust
3.226 A PIC18 optimization bug causing incorrect bank switching is fixed
3.226 A PIC18 problem when SWITCH is used inside and outside an ISR is fixed
3.226 PCW Wizard updated for the newest chips
3.227 Various improvments have been added to the PCW IDE
3.227 A number of new example files have been added
3.228 New function added to help jump from a bootloader ISR to the application ISR
3.229 LCD_SYMBOL now allows 1-16 segments per symbol
3.229 #error now allows warning and information level messages
3.229 Built in functions have been updated for the newest parts
3.230 A number of new example files have been added
3.230 Device definitions have been cleaned up for some parts
3.231 New function added: I2C_ISR_STATE()
3.231 I2C_START() has been improved for use in multi_master mode
3.231 New function added: _MUL
3.231 New printf specifications %g and %w added and %f improved
3.231 New #INT_* option: HIGH for more complete handling of PIC18 high priority interrupts
3.232 printf %f now puts a leading 0 for numbers less than 1
3.232 A number of new example files have been added
3.232 A limit on the number of #rom directives has been removed
3.233 A problem with #ZERO_RAM on parts with 4K of RAM is fixed
3.233 The %f, %w and %g formats have been adjusted to be more consistant
3.233 %w now accepts signed numbers
3.234 Still more %f adjustments. It should now solve everyones problems.
3.234 More return results added to RESTART_CAUSE() for many chips
3.235 A PIC18 optimization problem has been fixed
3.235 An ADC problem with 16C774 like chips is fixed
3.235 An undeserved syntax error involving forward structure declarations is fixed
3.235 A problem with high priority interrupts on some chips is fixed
3.235 Problems with setup_wdt() and setup_oscillator on some new chips is fixed
3.235 The compiler now tolerates a .PJT file that is marked read-only
3.235 Extra, non-applicable information in errors and warnings has been removed
3.235 PCW now highlights INT8 properly
p.s. .. файла е където си беше и преди, на eldevice.net
Нед Окт 30, 2005 5:38 am
За 3.235 говориш предполагам :wink: Магарето вижда всичко :D
Нед Окт 30, 2005 3:21 pm
Да ... ама мног ми се отдава да обръщам или променям числа като пиша ...лоша работа :)
Нед Окт 30, 2005 7:33 pm
Регистриран на: Пет Фев 04, 2005 3:18 pm
Местоположение: Sofia
Има ли откъде да се дръпне :?:
Сря Ное 02, 2005 10:53 am
Има да ... eldevice.net/upload/ccs
Чет Ное 03, 2005 3:14 am
Местоположение: US
ToHu, мерсим за новата версия. Между другото, CCS планират да пуснат през първото 3-месечие на 2006 обновена развойна среда, която да има много нови екстри. Същевременно ако някой има идеи, какво трябва да има, може да им предложи на support@ccsinfo.com . Повече по въпроса на http://www.ccsinfo.com/news.shtml
Пет Ное 04, 2005 3:08 am
Местоположение: Varna
Здравейте! Нещо допълнително има ли при лекуването?
Заредих първо 3.235 , задвижих пача, но ми дава когато компилирам, че трябва да преинсталирам файловете на компилатора. Преминах на по ниската версия, тръгна да компилира, но след 2 влизания ми написа проблем с един от DLL-лите. Какво съм оплескал не знам. Моля ви помогнете.
Успех :)
http://ds-portfolio.com/bg/
Нед Апр 16, 2006 4:47 pm
Вероятно си пропуснал, че на тоя пач трябва няколко пъти да му натиснеш "next" щото пачва повече от един файл (аз понякога забравям и само по един път, т.е. пачва се само компилатора, а PCW си стои здраво)
PS: Модерната версия в момента е 3.245, доста проблеми (в повечето случаи с портовете) с 18-ките ми се решиха откакто я сложих
Нед Апр 16, 2006 4:49 pm
Благодаря! Тръгна. Пача коригира само един файл, но едва при повторно натискане казва, че е пачнато успешно (може това последното и да съм го прескочил с cancel). Далеко съм от 18-ките и ще остана на тази версия.
Сега остава и да пропиша на него.
Успех :)
Нед Апр 16, 2006 5:25 pm
снана ми интересно...
можете ли да кажете на колко време излиза нова версия? два пъти на ден, на три дена или всяка седмица?
някои от грешките звучат доста смущаващо за нещо, което има 230 версии:
как успявате да работите с това чудо? :roll:
спомням си една приказка от далечното минало: "знаеш ли какво прави командата print тази седмица?"
Нед Апр 16, 2006 6:23 pm
Абе свиква се почти толкова лесно колкото и с бъговете на PIC18...не е фатално, миналата седмица имах например една случка в листинга:
set_tris_b(0xF1);
.....................movlw  11
.....................movwf 0xF92
Нед Апр 16, 2006 6:32 pm
Местоположение: Стара Загора
Ужас!! 8O Тея изроди са за убиване... и пари даже искат за тва нещо :guillotine:
И2Ц функциите може и да са оправени за "some parts", за други обаче явно не са... писах си собствени .
Пон Апр 17, 2006 9:32 am
Мен лично ме устройва CCS, като се има предвид що за животно е пика и как всичко в него е "подредено" прилежно , даже много добре са се справили от CCS направо отлично , мисля че в сверата на пиковете е може би най достъпният и бързонаучаващ се компилатор на Ц със сравнително много големи възможности. Да благодарим на ТоНи за това, че сподели с нас компилатора си :-)
Чет Апр 27, 2006 11:20 pm
Профил YIM
Местоположение: US
Някой има ли по-нова версия от 3.241 ? Оказва се, че в 3.241 има грешки при адресация от рода на :
int8 chn;
an[chn].complete = 1;
където an e структура, а complete е битово поле в тази структура.
Пет Апр 28, 2006 10:10 am
Имам 3.245. Ако те устройва, дай някаква входна точка.
Пет Апр 28, 2006 10:29 am
